Analogic Clcok with the gauges of nextion HMI
PostPosted: Fri Dec 18, 2020 12:07 pm    Post subject: Analogic Clcok with the gauges of nextion HMI Reply with quote
Hi
This video shows the interest of using the "intelligent" Nextion .
the gauges have the possibility to be transparent, i.e. the hand is displayed but not the background.
This considerably reduces the number of programme lines.
Moreover I used the internal RTC which frees an I2C port.
Again this is possible only with the "intelligente Nextion display
[img][/img]
Video here : https://youtu.be/rZ9rJepxNWU
code here :
JP Wink
PostPosted: Fri Dec 18, 2020 9:19 pm    Post subject: Reply with quote
thank you for sharing JP.
Time is going fast in the video Very Happy
It looks smooth.
In 2021 i will check out nextion too.
PostPosted: Sun Dec 20, 2020 2:25 pm    Post subject: a little bug Reply with quote
the intervals are sometimes difficult to handle. it's just arithmetic and I made a little mistake that my 9 year old granddaughter won't forgive me. Wink the correct sub in nextiontimedate.inc for hour is:
Sub Gaugehour()                                             'pour calculer l'angle de la gauge minutes en fonctions des minutes
   Local Fxmin As Word
   Local Fxhour As Word
  Fxhour = Jhour
   Select Case Fxhour
       Case 0 To 8
       Fxhour = Fxhour * 30 : Fxhour = Fxhour + 90
      Case 9 To 12
         Fxhour = Fxhour -9 : Fxhour = Fxhour * 30          'sans les minutes
      Case 13 To 20
          Fxhour = Fxhour - 12
           Fxhour = Fxhour + 90                             'sans les minutes
          Case 21 To 23
          Fxhour = Fxhour - 21 : Fxhour = Fxhour * 30
   End Select
   Fxmin = Jminute : Fxmin = Fxmin \ 2                      'on ajoute le décalage des minutes ,
   ' 60 minutes de décallage dans l'heure  pleine pour 30 degrés Donc division entière des minutes
   ' Et Incément Toutes Les 2 Minutes.
   Fxhour = Fxhour + Fxmin
  Call Nex_gaugeval( "z1" , Fxhour)
End Sub
PostPosted: Sun Dec 27, 2020 6:44 pm    Post subject: letter weighing with a HX711 Reply with quote
I have added a letter weighing function to my clock.
I was helped by Mikael from the Bascom.de forum. You can see the software I used as an inspiration.
https://bascomforum.de/index.php?thread/1644-load-cell-sensor-hx711/&postID=27108#post27108
many thanks to him for this very simple way to do
I use a DFROBOT SEN160 1Kg module from GoTronic to do it
the Video :
https://youtu.be/-D6NelyDm-U
the code :
I remark the dim because they are put in the main program.
''HX711 weight----------------------------------------------
Sub Hx711()
'HX711 Wägezellen-Sensor michael@bascomforum.de
   Call Nex_page(2)                                         'give here the name of the weight page==============
   Waitms 100
'Dim Wert As Long                                            'Wandlerwert        Converter value        Valeur du convertisseur
'Dim C As Byte At Wert Overlay                            'serielles Byte LSB
'Dim B As Byte At Wert + 1 Overlay
'Dim A As Byte At Wert + 2 Overlay                           'serielles Byte MSB
'Dim X As Byte At Wert + 3 Overlay                           'MSB im Long
'Dim Tara As Long                                            'Offset
'Dim Wert_final As Long                                      'Rechnungsvariable
'Const Faktor = 1989
   Clock Alias Portc.5                                         ' the clock
   Config Clock = Output
   D_in Alias Pinc.4                                        ' data in
   Config D_in = Input
   Tara = 0
      For Ibyte = 7 To 0 Step -1
         Clock = 1
         Waitus 2
         A.ibyte = D_in
         Waitus 1
         Clock = 0
      If A.7 = 1 Then
         X = 255
      Else
         X = 0
         Clock = 1
         Waitus 2
         B.ibyte = D_in
         Waitus 1
         Clock = 0
         Clock = 1
         Waitus 2
         C.ibyte = D_in
         Waitus 1
         Clock = 0
      Clock = 1                                                '25 Clocks
      Waitus 2
      Waitus 1
      Clock = 0
      Waitms 20
      Device_id = 0
      Call Nex_returntime()
      Select Case Device_id
         Case 1                                             'tare
            Tara = Wert
            Debug #usb , "tare:" ; Wert
            Device_id = 0
            Wait 1
           Case 2                                           'retour
             Exit Sub
      End Select
      Waitms 200
      If Tara = 0 Then Call Nex_text( "t3" , "Zero ?" , Black , White , 4)
      Call Weighing()
End Sub
Sub Weighing()
   If Tara > 0 Then
      Wert = Wert - Tara                                    'Offset abziehen    'deduct offset (tare) , soustraire le décalage
   If Tara = 0 Then
       Debug #usb , "mesure vide " ; Wert
      Exit Sub
  Wert_final = Wert / Faktor                                'Faktor für metrische Gramm   Factor for metric grams        ' facteur pour les grammes
   Wert_final = Abs(wert_final)
   Debug #usb , "Wert_final " ; Wert_final
   Sentence = Str(wert_final) : Sentence = Sentence + " g"
   Call Nex_text( "t3" , Sentence , Black , White , 4)
   Device_id = 0
End Sub
PostPosted: Mon Dec 28, 2020 10:53 am    Post subject: Reply with quote
hi JP
thanks for the video and this addition.
it seems to be very accurate.
Ha Michael , he can do about anything with bascom Very Happy
PostPosted: Mon Dec 28, 2020 11:01 am    Post subject: Reply with quote
yes that right . Mikael use overlay and with this sample I understand overlay with the MSB and LSB Wink
JP
