MPU-6050 Not sending data
snow
PostPosted: Thu Dec 17, 2020 5:59 am    Post subject: MPU-6050 Not sending data Reply with quote
Hi
I've got 25 boards back from the assembly crowd. They have has a MPU-6050 Gyro/Accel on the board.
A fairly high amount of the boards, (11/25), The MPU-6050 chip is not sending the correct data back to the micro for processing. The AccelZ MEMS data and the Temperature data is stuck on 0.
I can communicate to the MPU-6050 correctly as I can request the ID address (&H75) and it replies with the correct data. I can also read the PWR_MGMT_1 register and it replies with the correct data.
I'm resetting the device as part of the INIT startup. I'm missing something obviously simple, as I can get other boards running correctly with the same code. Is there a factory setting that I'm missing that need to be added..
$regfile = "m328pbdef.dat"                                     'Field=i Board
$crystal = 16000000                                            'used crystal 16MHZ frequency
$baud = 9600                                                   'use baud rate
$hwstack = 64
$swstack = 128
$framesize = 256
$version 1 , 0 , 182
'Config Serialin = Buffered , Size = 10
'SETUP CONSTANTS
Const Compiler = "Bascom 2.0.8.2"                            'With Local CONSTANS
Const _valcheck = 1                                          'Set ERR=1 whenever VAL() function encounters an illegal numeric string
'SYSTEM MATHS CONSTANTS (Don't modify)
Const On = 1
Const Off = 0
Const True = 1
Const False = 0
Const Pi = 3.1415926
Const Clockwise=0
Const Anticlockwise=1
'PROJECT CONSTANTS
'----------list of MPY-6065 register positions----------
Const WHO_AM_I_MPU6050 = &H75                                 'Should reply &b110100 for the correct chip on the bus  GY-521 Module
Const MPU6050_R = &HD1                                        '1101000 Chip address if ADO pin is grounded + 1 for read bit  = 11010001 (hex D1)
Const MPU6050_W = &HD0                                        '1101000 Chip address if ADO pin is grounded + 0 for write bit = 11010000 (hex D0)
'SETUP SUBROUTINES
Declare Sub ReadAccel()
'PIN MAPPING
Buzzer Alias PortE.0
 'CONFIGURE I²C bus
Config Scl = Portc.5                                             'I²C clock pin
Config Sda = Portc.4                                             'I²C data bus pin
Config Twi = 400000                                              'I²C bus clock speed   400khz
I2cinit
'CONFIGURE PORTS
 Config Buzzer = Output                 'Board buzzer
'CONFIGURE ADC'S
'Config Adc = Single , Prescaler = Auto , Reference = Avcc
'Start Adc
'DIMENSION UP VARIABLES
Dim AccelTemp as Integer
Dim L_AccelTemp as byte at AccelTemp + 0 overlay
Dim H_AccelTemp as byte at AccelTemp + 1 overlay
Dim Z_Accel as integer
Dim Zl_Accel as byte at Z_Accel + 0 overlay
Dim Zh_Accel as byte at Z_Accel + 1 overlay
Dim MPU6050_WhoAmIAddress as Byte
Dim Tick as byte
Dim RegisterData as byte
'SETUP REQUIRED TIMERS
'SET PORT STATE'S
'LOAD VARIABLES
Buzzer = off
'STARTUP
Gosub InitMPU6050
'***************************  M A I N  *************************************************
   ReadAccel
   If Z_Accel<1000 then    'If blelow threshold turn buzzer on
     Buzzer = on
     waitms 100
     buzzer = off
     waitms 100
   Print "Accel:";Z_Accel
   Print "Pcb Temp:" ; AccelTemp
   Print "Register &H6B:" ; RegisterData            ' Check to see MPU-6050 not stuck in reset
   Print ""
   Wait  1
Sub ReadAccel()
   I2cstart
   I2cwbyte MPU6050_W
   I2cwbyte &H3F
   I2cstart
   I2cwbyte MPU6050_R
   I2crbyte  Zh_Accel , ack
   I2crbyte  Zl_Accel , ack
   I2crbyte  H_AccelTemp ,ack
   I2crbyte  L_AccelTemp , Nack
   I2cstop
   I2cstart
   I2cwbyte MPU6050_W
   I2cwbyte &H6B
   I2cstart
   I2cwbyte MPU6050_R
   I2crbyte RegisterData  , Nack
   I2cstop
End Sub
'=====[ Initilize MPU-6050 ]=========================================================
InitMPU6050:
   I2cstart                                  'Reset device
   I2cwbyte Mpu6050_w
   I2cwbyte &H6B
   I2cwbyte &b10000000
   I2cstop
   wait 1
   I2cstart
   I2cwbyte Mpu6050_w
   I2cwbyte &H6B
   I2cwbyte &b0000010                       'Turn on internal temperature reading and set Clock source
   I2cstop
   wait 1
   I2cstart                                  'Set the slowest sampling rate
   I2cwbyte Mpu6050_w
   I2cwbyte &H19
   I2cwbyte &B11111111
   I2cstart                   'Set full scale reading
   I2cwbyte Mpu6050_w
   I2cwbyte &H1C
   'I2cwbyte  &B000_00_000  '2g's
   'I2cwbyte  &B000_01_000  '4g's
   'I2cwbyte  &B000_10_000  '8g's
   I2cwbyte &B000_11_000  '16g's
    ' Read the WHO_AM_I register
    I2cstart
    I2cwbyte MPU6050_W
    I2cwbyte WHO_AM_I_MPU6050
    I2cstart
    I2cwbyte MPU6050_R
    I2crbyte MPU6050_WhoAmIAddress , Nack
    I2cstop
    Print "Accel Chip &H" ; Hex(MPU6050_WhoAmIAddress)        'If MPU6050_WhoAmIAddress = &H68 chip found
return
Regards Snow
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.3 )
Evert :-)
PostPosted: Thu Dec 17, 2020 1:57 pm    Post subject: Reply with quote
Hi Snow,
My first reply as electronics engineer is what about voltage levels.
The MPU6050 runs at 3.3V and the M328PB needs at 16Mhz >4.5V.
Do you have a good level convertor for the i2c bus?
snow
PostPosted: Thu Dec 17, 2020 8:18 pm    Post subject: Reply with quote
Hi
I'm dropping to 3.3 from 5v with a XC6206P332MR 3.3 volt reg. I've probed it and the voltage seem pretty good 3.305v . On the I^C bus ,I'm using 4.7k pulled up's to 5v.
Just looking on the schematics of a GY521 module that I have been using for the past 2 years on this project. There pull ups are tied to the 3.3 volt line. Maybe that's where my mistake it.??? I'm running a DAC on the same bus that works fine with COMM's etc. , but they are rated to 5v-3.3v by the look of the data sheet.
I can communicate with the MPU-6050 fine... get the Who am I ID , set and re-read the user power registers to make sure they have changed etc..
Maybe it is my pullups?? Didn't really give it much thought as I wouldn't think it wouldn't be an issue (Famous last words)
Cheers Snow
PostPosted: Fri Dec 18, 2020 9:16 pm    Post subject: Reply with quote
i kind of miss this :
$lib "I2C_TWI-MULTI.lib" 'important for using 2 TWI interfaces
or the normal i2c_twi lib reference.
check out the samples\chips\m328PB.bas sample
when having i2c probs : check the ERR variable after the i2c statement. that will give an indication.
