christian_B97
Posted: Fri Nov 27, 2020 8:31 pm Post subject: Probelm with Udpwrite in Bootloader with XMEGA |
Hey guys,
i have following Problem with my Code:
I created a Bootloader for ATMEGA644 and reuse the Code (with little Changes) for the XMEGA128A4AU.
Without " $Loader = &H10000 " all works as expected, my W5500 Module gets an IP via DHCP as on my ATMega644 Modules, but after adding " $Loader = &H10000 " the uC seems to have a Problem with
Code: | Result = Udpwrite(255.255.255.255 , 67 , 0 , Tt(1) , 548 ) |
The uC will never execute the next Line in the Source wich is a print. In Wireshark the Packet is not recived, so i think it is not sent by the W5500. Maybe theres an Problem with SPI or with the TCP/IP in the Bootloader?
As the TCP/IP worked with the ATMEGA very good, i think its an Problem with SPI and the Bootloader?
Code: | Config Spic = Hard, Data_Order = Msb, Master = Yes, Mode = 0 , CLOCKDIV = CLK16, SS = AUTO
Open "Spic" For Binary As #10
Reset PortC.1 '
Waitms 200
Set PortC.1
Waitms 200
Config Tcpip = Noint , Mac = Mac_add(1) , Ip = 0.0.0.0 , Submask = 0.0.0.0 , Gateway = 0.0.0.0 , Localport = 68 , SPI = SPIC , Chip = W5500 , Cs = PortC.4 |
Would be nice if someone could help me with that, the only idea i have right now is to compare SPI output with $Loader and without.
Best Regards
Chris
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.3 ) |
Posted: Mon Nov 30, 2020 3:46 pm Post subject: |
it is always best to first check with the latest version.
for xmega there is a sample :
Code: |
'name : TCPCONNECT_W5500.bas
'copyright : (c) 1995-2020, MCS Electronics
'purpose : test SOCKETCONNECT() function
'micro : xMega64A3
'suited for demo : no, needs library only included in the full version
'commercial addon needed : no
$regfile = "xm64a3def.dat"
$crystal = 32000000
$hwstack = 64 ' default use 32 for the hardware stack
$swstack = 128 'default use 10 for the SW stack
$framesize = 64 'default use 40 for the frame space
'configure the systemclock
'configure UART
Config Spie = Hard , Master = Yes , Mode = 0 , Clockdiv = Clk32 , Data_order = Msb , Ss = Auto
'SPI on Port E is used
'portx.7 - SCK
'portx.6 - MISO
'portx.5 - MOSI
'portx.4 - SS
Waitms 1000
Print "Init , set IP to 192.168.1.88" ' display a message
Config Tcpip = Noint , Mac = 12.128.12.34.56.78 , Ip = 192.168.1.88 , Submask = 255.255.255.0 , Gateway = 192.168.1.1 , Localport = 1000 , Chip = W5500 , Spi = Spie , Cs = Porte.4
Print "Init Done"
dim bResult as Byte
dim wResult1 as Word, wResult2 as Word
Print "TCP demo"
'Ip = Maketcp(173.194.65.101) 'assign IP from google.com or any other IP with a web server that allows a connection
'the next line is used for testing. the line above can be used for a test to a server that responds
Ip=MakeTCP(173.194.65.222) ' use this for a server that does not respond
Print "Connecting to : " ; Ip2str(ip)
'we need to get a TCP socket first
Idx = Getsocket(idx , Sock_stream , 0 , 0) ' get socket for UDP mode, specify port 5000
Print "Socket " ; Idx
bResult = SOCKETCONNECT(idx, IP, 80,1) 'use port 80
'Notice the 4-th parameter which is 1. This means that socketconnect does not wait but returns immedeately !
print "Result : " ; bresult
wResult1 = 0
wResult2 = Socketstat(idx , 0)
if wResult2<>wResult1 then 'status changed
print "STATE : " ; wresult2
wResult1=wResult2
end if
it shows the the setup for SPI E port.
always start with another simple program to check if the module get an IP and can be addressed. _________________ Mark |
christian_B97
Posted: Thu Dec 03, 2020 8:36 pm Post subject: |
in fact from the history ;
history = for usage in bootloader, define a constant named _loader_page
history = the value depends on the size of the chip. when you use $Loader=8000 you set the address to the &H10000 word address. if you divide this by &HFFFF (or shift to the right by 16 places) you end up with 1, the page.
history = a general number would be const _loader_page = (_ROMSIZE &HFFFF) -1
I guess i never got feedback about this feature since it is implemented in w5500 only and only documented in the lib. _________________ Mark |
