Timer does not start immediately
atmega64
PostPosted: Thu Nov 26, 2020 4:34 pm    Post subject: Timer does not start immediately Reply with quote
with the following code,
when I switch from a low frequency to a high frequency (for example Cpwmfreq = 50)
the timer does not start immediately but after a few seconds ... why?
$regfile = "m1284def.dat"
$crystal = 16000000
$hwstack = 48
$swstack = 40
$framesize = 48
$baud = 19200
Dim Cpwmfreq , Dutycicle As Word
Dim Cpwmfreqsng As Single
Config Single = Scientific , Digits = 1
   Cpwmfreqsng = Cpwmfreq / 10
   Cpwmfreqsng = Cpwmfreqsng - 0.5
   Cpwmfreqsng = Cpwmfreqsng * 3120
   Cpwmfreq = Round(cpwmfreqsng)
   Cpwmfreq = 17160 - Cpwmfreq
   Enable Timer1
   Tccr1a = &B10000010
   Tccr1b = &B00011101
   Icr1 = Cpwmfreq                                       '3120
   Cpwmfreq = Cpwmfreq / 100
   Dutycicle = Cpwmfreq * Dutycicle
   Pwm1a = Dutycicle
Evert :-)
PostPosted: Thu Nov 26, 2020 4:51 pm    Post subject: Reply with quote
Cpwmfreq is in this stage 0.
Dividing zero by 10 will give nothing.
Here is Cpwmfreqsng -1560.
Rounding makes the -1560 , 63976 positive.
Why are you starting with all variable empty?
atmega64
PostPosted: Thu Nov 26, 2020 5:04 pm    Post subject: Reply with quote
sorry but the input code is missing ...
obviously Cpwmfreq is never zero and never negative
the value of Cpwmfreq ranges from 5 to 50
PostPosted: Thu Nov 26, 2020 7:30 pm    Post subject: Reply with quote
If your timer is for example at 4000 and you set 30 then compare match dont fire till Timer reach its end which is 65535 >4s @1024 prescale.
So maybe try Timer1 = 0 so after 30 compare will arrive quicly Wink
If you "Enable Timer1" then you enable interrupt from it. So you can always update registers in the interrupt routine cause Timer have always 0 then.
atmega64
PostPosted: Fri Nov 27, 2020 10:40 am    Post subject: Reply with quote
hi,
well, I added
load timer1, Cpwmfreq
seems to work well now ...
what do you think about it?
updated code:
$crystal = 16000000
$hwstack = 48
$swstack = 40
$framesize = 48
$baud = 19200
   Enable Timer1
   load timer1, Cpwmfreq   '<<<<<<
   Tccr1a = &B10000010
   Tccr1b = &B00011101
   Pwm1a = Dutycicle
PostPosted: Sat Nov 28, 2020 7:41 am    Post subject: Reply with quote
Load Timer means 65535 - Cpwmfreq
So first Compare will fire Cpwmfreq * 2 I think because first Timer must count ex. 30 into 0 and then next 30 to Compare. Think twice Very Happy
atmega64
PostPosted: Mon Nov 30, 2020 8:10 am    Post subject: Reply with quote
Yes, OK...
but with this system, now the timer response is acceptable ...
could it still be improved?
