hzz
Posted: Sat Nov 21, 2020 11:36 am Post subject: Error compiling PUT and GET using HW SPID Solved) - Problem |
I'm getting the following compiling error whenever PUT or GET are encountered in the code
Quote: | Error : 61 Line : 56 Label not found [SPI] , |
What is this error?
This is the example I'm testing.
Code: | '____________________________________________________________________________________
$regfile = "xm192a3def.dat" ' ATxmega192A3
$hwstack = 256
$swstack = 128
$framesize = 128
' CONFIG SYSTEM CLOCK
Config Osc = Disabled , Extosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_16kclk , 32khzosc = Enabled , Pllosc = Enabled , Pllsource = Extclock , Pllmul = 2 ' 16x2=32MHz
Config Sysclock = Pll , Prescalea = 1 , Prescalebc = 1_1 ' 32/1=32 MHz
$crystal = 32000000
Const Fclock = 32000000
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled , Hi = Enabled
Config Com1 = 230400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Serialout0 = Buffered , Size = 250 'Buffer de TX1
Open "COM1:" For Binary As #1
Dim Sd_card_ready As Byte
Sd_card_ready = 0
Dim Btemp1 As Byte
Dim File_name_tmp As String * 12
' INI SD CARD
$include "Config_MMCSD_HC.inc"
If Gbdriveerror = 0 Then
$include "Config_AVR-DOS.inc"
Btemp1 = Initfilesystem(1)
If Btemp1 = 0 Then
Sd_card_ready = 1
Print #1 , " SD Card OK"
Print #1 , "Filesystem = " ; Gbfilesystem
' DIR SD CARD
If Sd_card_ready = 1 Then
File_name_tmp = Dir( "*.*")
While Len(file_name_tmp) > 0 ' if there was a file found
Print #1 , File_name_tmp ; " " ; Filedate() ; " " ; Filetime() ; " " ; Filelen()
File_name_tmp = Dir() ' get next
Wend
' WRITE BINARY INTO THE SD CARD
Dim B As Byte , W As Word , L As Long , Sn As Single
Dim Stxt As String * 10
B = 1 : W = 50000 : L = 12345678 : Sn = 123.45 : Stxt = "HOLA"
Print #1 , "B=" ; B ; " W=" ; W ; " L=" ; L ; " Sn=" ; Sn ; " Stxt=" ; Stxt
Open "test.bin" For Binary As #11
Put #11 , B ' write a byte
Close #11
End |
If I remove this line then it compiles and it works. All files in the SD CARD are printed
Note: I'm using hardware SPID so I had to make the following changes:
Code: | Portd_pin6ctrl = &B00_011_000 ' MISO pin pull up
Config Pind.4 = Output ' define here Pin for CS of MMC/SD Card
Mmc_cs Alias Portd.4
Set Mmc_cs
' Define here SS Pin of HW-SPI of the CPU (f.e. Pinb.0 on M128)
Spi_ss Alias Portd.4
'SPI Configuration for XMEGA
'The MMC-XMEGA.LIB expect SPIC
'If you want to use SPID, SPIE or SPIF you NEED TO CHANGE THE MMC-XMEGA.LIB
'It is documented in MMC-XMEGA.LIB where you need to change the Library
Config Spid = Hard , Master = Yes , Mode = 0 , Clockdiv = Clk2 , Data_order = Msb
Open "SPID" For Binary As #11
Const _mmc_spi = Spid_ctrl
In MMC-XMEGA.LIB as indicated, after the line
hzz
Posted: Sat Nov 21, 2020 10:07 pm Post subject: SOLVED? |
It seems that the file handle in PUT and GET cannot be a numeric value.
gives a compiler error despite this is the BASCOM example
Code: | file_handle = 2
PUT #file_handle, Byte | doesn't give a compiler error |
Posted: Sun Nov 22, 2020 2:12 pm Post subject: |
you need some coffee
first of all (or is that second now?) : please always include the files in a ZIP. So that it can be tested without additional assumptions and work.
then did you check this : Open "SPID" For Binary As #11
you open the SPI which is fine for #11
And that will remain open all the time.
So you can not expect that this : Open "test.bin" For Binary As #11
will work.
Why do you assume that will work? And why not using a unique number?
also :
When you use AVR-DOS you can have a unique file number on the fly. Using Freefile() function. _________________ Mark |
hzz
Posted: Sun Nov 22, 2020 7:04 pm Post subject: |
Thanks Mark, I do need a coffe!
Code: | Open "SPID" For Binary As #11 |
I took "Config_MMCSD_HC" from the BASCOM AVR-DOS samples and just changed SPIC to SPID everywhere without even noticing that this file is left open and that I was using the same file number in my code.
Correcting this, using a diferent file number in my code, PUT and GET can be used with a constant for file number, as expected.
Still I wonder if this Open "SPID" For Binary As #11 is needed in Config_MMCSD_HC and where should it be closed ¿!? |
hzz
Posted: Mon Nov 23, 2020 1:12 am Post subject: |
I must heve something else wrong, the behavior is strange. For instance, Seek doesn't work in the following example. Atached is a zip file including also the "Config_MMCSD_HC.inc" and "Config_AVR-DOS.inc" files used in the example
$hwstack = 256
$swstack = 128
$framesize = 128
$crystal = 32000000
Const Bps_com1 = 230400
Config Com1 = Bps_com1 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
' Config Serialout0 = Buffered , Size = 250 'Buffer de TX1
Sd_card_ready = 0
Dim Btemp1 As Byte
Dim File_number As Byte
Dim P_file_handle As Byte
Dim File_name1 As String * 12
Dim Ltemp As Long
Wait 2
Print #1 ,
Print #1 , "Test SD Card"
' INI SD CARD
If Btemp1 = 0 Then
Sd_card_ready = 1
Print #1 , "SD Card OK"
' Open File
P_file_handle = Freefile()
File_name1 = "Test10.bin" '**************** PUT HERE THE DESIRED FILE NAME
Open File_name1 For Binary As #p_file_handle
' Set starting at position =20
Ltemp = 20
Seek #p_file_handle , Ltemp
' Write data at position 20
Btemp1 = 33
Put #p_file_handle , Btemp1
Print #1 , "Data_byte pos=" ; Loc(#p_file_handle) ' This must be 20 but it is 1 ¿?
' Save data to SD Card and close file
' Flush #p_file_handle ' flush to disk (This is not needed. The data is already flushed when Closing the file)
Close #p_file_handle
End |
I Expected to print:
Quote: | Test SD Card
SD Card OK
Filesystem = 11 (Idon't know what this number means)
Data_byte pos=20
But it prints:
SD Card OK
Filesystem = 11
Data_byte pos=1
hzz
Posted: Tue Nov 24, 2020 2:21 am Post subject: |
I think you miss some basics.
If you have new file which is always binary but with sometimes with another extension then its len depend on how many bytes was entered previously which is NULL/NADA/ZERO
So how you want to point into byte at address 20?
I can tell you that even if you make a empty file "test.txt" on the PC and then search that file with AVR like :
Code: | Dim MyLong As Long
MyLong = Filelen("test.txt")
If MyLong > 0 Then
'you dont find nothing
End If |
You dont find this file because it dont contain one single byte....So how to point into byte No. 20?
Please put some 20 Test bytes like that, then point into 19 and put one more byte. Then, I think Filelen will be still 20 cause then Seek will be working.
Code: | For N = 1 to 20
Put #card , N
Seek #card , 19
Put #card , N
Print Filelen("example.bin") 'should sill be 20 cause 19+new one |
So you should use Filelen first and then point into some existing byte.
Cause im dealing with AVR-DOS often then I can give you one more tip.
If you have array of bytes then you cant put only one byte from the array directly.
A whole array will be written into the file from pointer you choose till the array end.
If you want to write only one byte from it you must use some temporary help byte.
Code: | Dim MyArray(10) As Byte
Put #card , MyArray(4) 'this will put seven bytes
Helpb = MyArray(4)
Put #card , Helpb 'this will put MyArray(4) Byte only |
hzz
Posted: Tue Nov 24, 2020 2:49 am Post subject: |
Thanks!
I thought I could just start writing anywhere in the file and leave empty space at the begining to put a header later. I missed some basics indeed! |
Posted: Tue Nov 24, 2020 9:25 am Post subject: |
from the help for SEEK: In QB/VB you can use seek to make the file bigger. When a file is 100 bytes long, setting the file pointer to 200 will increase the file with 0 bytes. By design this is not the case in AVR-DOS. _________________ Mark |
Posted: Tue Nov 24, 2020 10:02 am Post subject: |
One thing i forgot to answer : the OPEN was and is just a way so the compiler knows which handles belong to a device.
So there is no need to close them. In fact you should not close them.
The only exception is AVR-DOS which uses real dynamic file handles. Here the CLOSE will actually flush buffers and close the file handle so it can be re-opened later. _________________ Mark |
hzz
Posted: Tue Nov 24, 2020 10:32 am Post subject: |
OK.
Although I'm not sure to get it. Shouldn't this code print Data_byte at pos20 is 20?
Code: | If Sd_card_ready = 1 Then
File_name1 = "Test13.bin"
For Btemp1 = 1 To 255
Put #p_file_handle , Btemp1 ' Fill first 255 positions
Next Btemp1
Flush #p_file_handle ' Write data to SD card
Ltemp = 20
Seek #p_file_handle , Ltemp ' Set file pointer at position =20
Get #p_file_handle , Btemp1 ' Get the byte at position 20, which should be =20
Print #1 , "Data_byte at pos" ; Loc(#p_file_handle) ; " is " ; Btemp1
End If |
However it prints Data_byte at pos19 is 0
What is wrong? |
Posted: Tue Nov 24, 2020 12:47 pm Post subject: |
yes you are right. only a close/reopen will let SEEK statement work correct.
i will have a look at it. i dont know if this is by design or a bug. _________________ Mark |
hzz
Posted: Tue Nov 24, 2020 2:56 pm Post subject: |
File_name1 = "Test14.bin"
Next Btemp1
Ltemp = 20
Print #1 , "Data_byte at pos" ; Loc(#p_file_handle) ; " is " ; Btemp1 ' Result: Data_byte at pos20 is 20
Ltemp = 40
Seek #p_file_handle , Ltemp ' Set file pointer at position =40
Btemp1 = 100
Put #p_file_handle , Btemp1, ' put the value 100 at position 40
Ltemp = 40
Get #p_file_handle , Btemp1 ' Get the byte at position 40, which should be =100
End If |
the program above prints
SD Card OK
Filesystem: 11
Data_byte at pos40 is 100
which is Not correct
If I just chage the filename to Test13.bin then it prints:
SD Card OK
Filesystem: 11
Data_byte at pos40 is 100 |
which is correct
Both files Test13.bin and Test14.bin have been created with the program and in both cases the files existed in the SD card before running the program ¿Why the behavior is different?
if I change the program to close Test14.bin before the Seek then the proigram works with Test14.bin also ¿?
Next Btemp1
Close #p_file_handle ' We need to close the file in order for SEEK to work
Ltemp = 20
Ltemp = 40
Btemp1 = 100
Ltemp = 40
End If |
If I remove the two lines
Code: | Close #p_file_handle ' We need to close the file in order for SEEK to work
then the program does not work with Test14.bin but it works with Test13.bin
I have tested it with a different SD Card creating both files with exactly the same code. Then the behavior is the same for both files. In none of them SEEK works if the file is not closed before calling SEEK.
So I wonder what did I do to Test13.bin in the first card that didn't need the file to be closed for SEEK to work.
Also, Do we need to close the file each time SEEK is going to be called? |
Posted: Tue Nov 24, 2020 3:08 pm Post subject: |
As i wrote before the SEEK statement seems to require that the file is closed.
Or with other words, SEEK statement will only work when the file does not change in size.
When an existing file is opened it will work. when you use it to relocate the position after writing data, it will not work.
While the SEEK by design will not let the file grown when you position the file pointer beyond the end, i do not know why it does not update using a FLUSH or after writing data.
it is probably by design but it might be a bug. i will check it later and either document it or change it. _________________ Mark |
hzz
Posted: Tue Nov 24, 2020 4:56 pm Post subject: |
But SEEK does work without closing the file after writing data as in this example:
Next Btemp1
Ltemp = 20
Print #1 , "Data_byte at pos" ; Loc(#p_file_handle) ; " is " ; Btemp1 ' Result:: Data_byte at pos20 is 20 OK
Ltemp = 40
Btemp1 = 100 : Put #p_file_handle , Btemp1, ' put the value 100 at position 40
Btemp1 = 101 : Put #p_file_handle , Btemp1, ' put the value 101 at position 41
Btemp1 = 102 : Put #p_file_handle , Btemp1, ' put the value 102 at position 42
' With the previous PUT's we have changed the pointer without closing the file so the following SEEK should not work
Ltemp = 50
Seek #p_file_handle , Ltemp ' Set file pointer at position =50
Get #p_file_handle , Btemp1 ' Get the byte at position 50, which should be =50
Print #1 , "Data_byte at pos" ; Loc(#p_file_handle) ; " is " ; Btemp1 ' Result Data_byte at pos50 is 50 OK
Ltemp = 40
Print #1 , "Data_byte at pos" ; Loc(#p_file_handle) ; " is " ; Btemp1 ' Result Data_byte at pos40 is 100 OK
Get #p_file_handle , Btemp1 ' Get the byte at position 41, which should be =101
Print #1 , "Data_byte at pos" ; Loc(#p_file_handle) ; " is " ; Btemp1 ' Result Data_byte at pos41 is 101 OK
Get #p_file_handle , Btemp1 ' Get the byte at position 42, which should be =102
Print #1 , "Data_byte at pos" ; Loc(#p_file_handle) ; " is " ; Btemp1 ' Result Data_byte at pos42 is 102 OK
End If |
