autoguider
Posted: Thu Oct 01, 2020 2:31 pm Post subject: naming not accepted by compiler ? - Solved by $sim removed f |
Dear All,
for an existing application I wanted just to add the functionality that a LED will be turned on as an indicator of a state in the device.
I did the testing in the device circuit and later also in the evaluation board.
I did a small program just to see if the programming/syntx is correct.
Code: |
$lib "mcs.lbx"
$regfile = "m328pdef.dat" ' Specify The Used Micro " ' specify the used micro
$prog &HFF , &HE7 , &HDF , &HF8 ' generated. Take care that the chip supports all fuse bytes.
$crystal = 6144000 ' used crystal frequency 0 error in UART
$hwstack = 64 ' default use 32 for the hardware stack
$swstack = 64 ' default use 10 for the SW stack
$framesize = 64
'$dbg
'$sim
Config Portd.5 = Output 'Pin 11
Alarm_LED Alias Portd.5
Config PortD.7 = Output 'Pin 12
Buzzer Alias PortD.7
Dim i as byte
Buzzer =1
wait 5
Buzzer =0
Wait 2
Buzzer =1
Wait 5
Buzzer =0
for i =1 to 5
Alarm_led= 1
wait 2
Alarm_led =0
Wait 2
Alarm_led =1
Waitms 300
Alarm_led=0
Waitms 300
Alarm_led=1
Waitms 300
Alarm_led =0
wait 3
next i
end |
Program and hardware worked as expected.
Then I checked with my application in which I added the code for Alarm LED and buzzer.
For testing I put some code for the alarm_led and the buzzer into the init soubroutine.
In the simulator it looks well.
In the evaluation board strange things are happening.
The pin D.7 that I aliased with mybuzzer is not activacted at all.
Even more strange when I aliased D.5 as buzzer and D.7 as Alarm_LED D.5 was not activated and the buzzer beeped in the pattern programmed for the Alarm_LED.
When trying to activate D.7 by PortD.7 = 1 nothing happens.
There must be a logical reason.
Here some code:
Configuration:
Code: |
Config PortD.6 = Output
Alarm_LED Alias PortD.6
mybuzzer Alias PortD.7
aftr the configuration and declaration part there is a Goto Main.
First command at the label main is call init.
So init has to be executed befor the endless loop starts.
Here the snippet with the beginning of the init subroutine:
Testmodus is declared as constant with value 0. I use testmodus=1 to skip the wait when using the simulator.
Code: |
Sub Init()
disable interrupts
' beeping
mybuzzer =1
#if testmodus = 0
wait 3
#endif
wait 1
for i= 1 to 2
Alarm_led =1
#if testmodus =0
Wait 5
#endif
Alarm_led =0
#if testmodus =0
Wait 1
#endif
Alarm_led =1
#if testmodus =0
Waitms 200
#endif
Alarm_led =0
#if testmodus =0
waitms 1000
#endif
Alarm_led =1
#if testmodus =0
Waitms 500
#endif
Alarm_led =0
#if testmodus =0
wait 1
#endif
next i
alarm_led =1
#if testmodus =0
wait 10
#endif
alarm_led =0
Ocr0a = UpperLimit_timer_0 'max pulse width
Enable Compare0a ' Timer für 20 ms loop
Enable Timer0
Enable Timer2
The part with the LED is executed well.
My application uses timer0 and timer2.
Here the config of the timers:
Code: |
Config Timer0 = Ctc , Clear_timer = 1 , Prescale = 1024
On Compare0a 20ms_timer0_isr Nosave
'Put TCCR2A Register to 10000001 and TCCR2B Register to 00001001
'CTC Modus, Output pins not connected
' TCCR0A
' 'Bit 7 6 5 4 3 2 1 0
' '(0xB0) COM02A1 COM0A0 COM0B1 COM0B0 WGM01 WGM00
Tccr0a = &B00000010
' 'TCCR0B
' '(0xB1) FOC0A FOC0B WGM02 CS02 CS01 CS00
'Tccr0b = &B00000101
Tccr0b = &B00000000 ' Timer stopped. Will be started in the end of Sub Init
Config Timer2 = Timer, Prescale = 64
On Compare2a Servopuls_isr_t2 Nosave
Tccr2a = &B00000010 'CTC Mode, Output disconnected
Tccr2b = &B00000000 'Timer 2 stopped here will be started by timer0 ISR
According to the datasheet Port D.7 has nothing to do with the timers.
I also checked on further appearance of D.7 or mybuzzer in the program code. Found nothing.
I have no idea what is happening here.
I guess it is something very basic but I cannot find it for hours.
Update:
I replaced the buzzer by a LED (less noisy)
Then I installed a label progend at the very end of the code.
To see what is happening I programmed the jump to the label.
1st version
Code: |
Sub Init()
disable interrupts
' ' call beep
mybuzzer =0
waitms 200
MyBuzzer =1
dummybyte=0
wait 3
goto progend
#if testmodus = 0
wait 5
#endif
wait 1
The MyBuzzer LED was continuously glowing
Then I modified the code
Code: |
Sub Init()
disable interrupts
' ' call beep
mybuzzer =0
waitms 200
MyBuzzer =1
dummybyte=0
wait 3
#if testmodus = 0
wait 5
#endif
wait 1
Alarm_led =1
#if testmodus =0
Wait 5
#endif
Alarm_led =0
#if testmodus =0
Wait 1
#endif
Alarm_led =1
#if testmodus =0
Waitms 200
#endif
Alarm_led =0
#if testmodus =0
waitms 1000
#endif
Alarm_led =1
#if testmodus =0
Waitms 500
#endif
Alarm_led =0
#if testmodus =0
wait 1
#endif
goto progend
With the result that the MyBuzzer LED was continuously glowing but the Alarm_LED does nothing.
Finally I removed the jump to progend.
Code: |
Sub Init()
disable interrupts
' ' call beep
mybuzzer =0
waitms 200
MyBuzzer =1
dummybyte=0
wait 3
#if testmodus = 0
wait 5
#endif
wait 1
Alarm_led =1
#if testmodus =0
Wait 5
#endif
Alarm_led =0
#if testmodus =0
Wait 1
#endif
Alarm_led =1
#if testmodus =0
Waitms 200
#endif
Alarm_led =0
#if testmodus =0
waitms 1000
#endif
Alarm_led =1
#if testmodus =0
Waitms 500
#endif
Alarm_led =0
#if testmodus =0
wait 1
#endif
There is a short flicker on both LED when pushing the reset button.
Then MyBuzzer LED stays dark and the Alarm LED starts glowing after 7.7 s ( should be 9s?)
Instead of 5s glow it stopped glowing after appr. 3s. Then the pattern is roughly executed.
I do not expect high accuracy but it seems strange.
On the crystal I could read the 6.144 MHz.
Possibly remedy found:
$dbg
$sim
removed from code. 9s timing correct. Both LED glowing. |
Printpix52
Posted: Fri Oct 02, 2020 9:39 pm Post subject: |
Code: | $regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
$sim
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
Printpix52
Posted: Fri Oct 02, 2020 9:58 pm Post subject: |
[img][/img]  |
Posted: Sat Oct 03, 2020 8:36 am Post subject: |
Printpix52 wrote: | In the simulator it looks well.
In the evaluation board strange things are happening. |
Would you explain the sense of your posts? |
Printpix52
Posted: Sat Oct 03, 2020 11:18 pm Post subject: |
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
$sim
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
With the simulator work with "$ sim" and to work with real card deactivate "$ sim" |
Posted: Sun Oct 04, 2020 11:33 am Post subject: |
Printpix52 wrote: | With the simulator work with "$ sim" and to work with real card deactivate "$ sim" | Yes, also the TO found it out.
I've just wondered about your post, as you parrot an already known and solved issue.
Looks like your post is the type of 'Everything was already said, but not by everyone'. |
