Gosub (I), Goto (I), Call (I)
jure_m
PostPosted: Fri Sep 25, 2020 9:50 am    Post subject: Gosub (I), Goto (I), Call (I) Reply with quote
my friend is asking is there a way to do in Bascom Gosub (I), or Goto (I), or Call (I) when the number I is changing from 0 to 10 with minimum usage of MCU resources? He has used IF or Select case, but these take too much of MCU resources.
Jure
PostPosted: Fri Sep 25, 2020 10:56 am    Post subject: Reply with quote
tell your friend to read the help and check out the samples.
especially the ON.. VALUE
Like in the old GW/QB basic ON has a dual purpose : for interrupts but also for numeric values.
The advantage is that no matter the value, the time is always the same. But you can only use numeric values..
