Turn off dead code option
snow
PostPosted: Wed Sep 09, 2020 10:46 pm    Post subject: Turn off dead code option Reply with quote
Hi
I'm writing code in a separate module. Since this code is called from another module the code in the IDE is shown as a dead code formatted text.
Is there a way to turn this option off so the code format is the correct colored layout like in a master module??
The only way i have found it to call the main loop from its self and remarked out for compiling.. just a niggle that is all
Const PanFast=4
Const PanSlow=30
Const TiltFast=4
Const TiltSlow =30
HomeAxis  '<======= added for dead code formatting and remarked out for compiling
Sub HomeAxis()
    ' Sub coding...
End Sub
Cheers
Snow
JC
PostPosted: Thu Sep 10, 2020 12:57 am    Post subject: Reply with quote
I think this is what you are asking for:
In the Bascom IDE, Options Tab:
Select Environment
Then Un-select "Syntax highlight"
Then click OK
JC
Edit: Embarassed
See the correct answer, below!
JC
snow
PostPosted: Thu Sep 10, 2020 2:12 am    Post subject: Reply with quote
Thanks. Ill look into it
PostPosted: Thu Sep 10, 2020 8:43 am    Post subject: Reply with quote
this forum has a search function.
anyway, just look under the EDIT menu.
It is 'SHOW DEAD CODE' and 'SHOW EXCLUDED CODE'
just un check these option to turn off the checking.
So why is it there under the menu?
Well you can put the button in a toolbar that way.
The whole idea about this function is to enable it when your code is done. So you can review it.
So this requires a simple enable/disable. Not an option.
