Posted: Wed Sep 09, 2020 3:33 pm Post subject: Very simple frequency generator
I found very simple frequency generator on Timer1 published by Arek2014 in "Share your working BASCOM-AVR code here" section.
What about Timer2?
Can we do similar thing using Timer2?
Timer1 is 16-bit and Timer2 is 8-bit so I would expect change in frequency range and resolution, this is not a problem.
Original code of Arek2014:
$crystal=8000000 ConfigTimer1=Timer , Prescale =1 ,cleartimer=1, Compare_a =Toggle'generator frequency!!! OC1A 'Ocr1a = 500 dim freq asword dim f asdword EnableInterrupts enabletimer1
f =4000000/ freq 'f crystal / 2 !!! print f ;"Hz"
Ocr1a = freq 'changing dim freq --> change frequency loop
My Code that generates frequency about 28kHz on OC2A output:
