Posted: Thu Aug 13, 2020 3:50 pm Post subject: Solved - Simulator "Display Memory Window" not vis
Hi, I was using the simulator.
I noticed the "Display Memory Window" was pinned together with the other windows (inside the main simulator window).
I dragged the Display Memory Window to full left edge. It disappear, now it does not show anymore.
Even if I click the blue "M" button to show/hide, it does not appear.
All this was because the first issue with the "Display Memory window" was the content didn't resize no matter the whole simulator window was maximized.
I tried to detach from the current position. Even detached, on top of main simulator window, it also does not resize, just shows a stretch window to see the contents, and I have to scroll left/right to see the rest of the content, what is very annoying. Because it does not show anymore I can't take a snapshot to show.
I have tried going to menu Options\Environment and click "Default" button but it does not help.
How can I restore the view of the Display Memory Window?
Why the Display Memory Window do not resize to see all the content?
Thanks in Advance!!
Ver. 2.0.8.3
I was able to see a very tiny piece of the window at the left. After many tires, I was able to pull the window again to be visible.
I would recommend having a way in the Simulator window to restore windows positions so to do not happen someone like to me.
Ok, now back the original issue:
The Display Memory Window don't resize, to see the contents.
Now I have a capture to show.
