SAFE attribute for variables
hzz
PostPosted: Sun Aug 02, 2020 12:05 pm    Post subject: SAFE attribute for variables Reply with quote
What does the SAFE attribute do?
BASCOM help explains the problem for which SAFE has been implemented, but it does not explain what SAFE does.
Is it just for the compiler to alert you when the same variable is used inside and outside of an ISR in cases when it could change its value unintentionally?
Does it solve the problem by actually preventing the unintentional change of the variable value in the cases explained?
Does it work only for "Incr" and for variables longer than 1 byte or also for other functions that can be affected by the same problem?
PostPosted: Sun Aug 02, 2020 12:24 pm    Post subject: Reply with quote
The SAFE option will disable interrupts and enables them, whenever you write or read a safe variable.
This means that the compiler will handle it for you. And since variable is any type , it means for all variables.
PostPosted: Sun Aug 02, 2020 12:46 pm    Post subject: Re: SAFE attribute for variables Reply with quote
This statement is wrong, it's explained in the help further down the page, and it shows it is ISR-related only.
SAFE encapsulates variable access by a 'disable interrupts'[varaccess]'restore interrupts status' and assures that a variable's access, which consists out of a sequence of opcodes, is completely done by the accessing code.
'Accessing code' means usually main-code, as within ISR access to variables is limited to interrupt code by default.
hzz
PostPosted: Sun Aug 02, 2020 1:03 pm    Post subject: Reply with quote
This is great.
Although errors due to this problem are very rear, they are also very dificult to debug so thanks!
