hzz
Posted: Sun Aug 02, 2020 1:09 pm Post subject: Can't open BASCOM AVR files with version 2.0.8.3 |
When I double click on a .prj, .bas or .inc file it alwasys opens with 2.0.8.2 even if I force open with 2.0.8.3
If I rename the 2.0.8.2 folder then these files open with 2.0.8.1 no matter if I set in Windows that they should be opened with 2.0.8.3
V2.0.8.3 opens fine and once it is open I can open .prj, .bas or .inc files from the IDE, but never double clicking on the files
(BASCOM-AVR version : 2.0.8.3 ) |
hzz
Posted: Sun Aug 02, 2020 1:34 pm Post subject: Solved |
I have solved by renaming all my previous versions of BASCOM |
Posted: Sun Aug 02, 2020 7:34 pm Post subject: |
it has nothing to do with bascom. it is the windows file association you need to change.
in explorer right click the prj file and then chose 'open with' _________________ Mark |
hzz
Posted: Sun Aug 02, 2020 11:38 pm Post subject: |
Thanks Mark. Thats what I did. It used to work with previous versions but for some reason Windows didn't want to open the files with 2.0.8.3 until there was no other choice. |
Endy64
Posted: Thu Aug 06, 2020 2:54 pm Post subject: |
PostPosted: Sun Aug 02, 2020 7:34 pm Post subject:
This not work to me also!
In the previous version of the software, this worked, but not in this one. |
Posted: Thu Aug 06, 2020 8:48 pm Post subject: |
which window do you use?
Maybe you need to be admin to set the file association.
The normal way in Windows 10/7 :
Open Control Panel
Control Panel Home
Default Programs
Set Associations
Select a file type in the list and click Change Program.
but again, this is not something that bascom changes. i could do that in the setup but i chose not to mess up bas/prj/inc extension since it could be used by other programs too.
I did consider to include this function in the options however. _________________ Mark |
Endy64
Posted: Sat Aug 08, 2020 7:46 am Post subject: |
albertsm wrote: | which window do you use?
Open Control Panel
Control Panel Home
Default Programs
Set Associations
I did consider to include this function in the options however. |
I’ve tried that too, but it doesn’t work. I cannot set Bascom AVR as the default program. File associattions does not work.
I can make an association with any program but in no way with bascom AVR
The AVR Icon is not in preferred and also is not in other programs.
Even i use
Browse
program files (x86)
MCS electronics
BASCAVR2083
and click on bascavr icon nothing happen.
Also is strange why bascom AVR icon is not present in default program windov.
If i made installation of previus version of bascom is automaticaly there in default programs but with fresh new version the icon disappere.
I use windows 7 ultimate, i try also on win 8 - the same situation. Also Admin doesn't help
Best regards |
six1
Posted: Sat Aug 08, 2020 8:30 am Post subject: |
the easy way is to rename old 2.0.8.2 Folder.
Next Time you click .bas file, windows will ask for default Program to open. Then select new Bascom.exe in 2.0.8.3 Folder
works 100% _________________ For technical reasons, the signature is on the back of this message. |
plouf
Joined: 19 Jan 2012 Posts: 78 Location: Athens,Greece
Posted: Sat Aug 08, 2020 8:32 am Post subject: |
have to agree nothing to do with BASCOM
can you try set up default program for .bas something else , for example notepad ? |
Posted: Sat Aug 08, 2020 11:14 am Post subject: |
make sure to have admin rights and also to check : always use the selected program to open this kind of file
The only change between 2082 and 2083 is that the program is code signed. So you can be sure it is from MCS. Maybe that plays a role. Can not imagine why/how but you never know.
Associations are stored in the registry. you could alter that too but i think that the normal windows function to set/change it, should be used and work. _________________ Mark |
Endy64
Posted: Mon Aug 10, 2020 7:47 am Post subject: |
plouf wrote: | have to agree nothing to do with BASCOM
That's exactly what I did, there was no program association problem with all the other programs. Now I have made an association with Bascom 8051 so I can immediately see that these are bascom programs. Of course, double-clicking does not open the right program.
That's why I'm confused. Why I can make an association with other programs, but I can not with Bascom AVR.
Best regards |
Posted: Mon Aug 10, 2020 8:27 am Post subject: |
Solution 1.
Problem is that Windows don`t load new instance into "icons you may choose" so for new Bascom instance better is choose "search/explore my computer for open this file" and choose EXE file direct in the folder you explore on your computer.
Open this file with -> Choose another application -> More applications -> at the very bottom of the list -> Search another application on this computer
Solution 2.
On my PC`s I have many Bascom instances installed and when I want to change which one should open my *.bas, *.inc files I`m using this simple free program -> LINK.
I`m using it for years and it work for me on the Win7 and Win10 too. This is the quick way for me
Simply find "bas" extention, double click on that showed blue line and change path to the new Bascom instance.
Endy64
Posted: Mon Aug 10, 2020 9:34 am Post subject: |
EDC wrote: | Solution 1.
Solution 2.
Thank you a lot, now is fixed and working!
Best regards.
The other easy way is just renaming the bascavr.exe to bascomavr.exe, and fix the file asociation is no problem. |
Posted: Mon Aug 10, 2020 1:32 pm Post subject: |
great tool EDC.
Nirsoft has many usable tools.
I added an option to bascom to set the file association for bas,prj and inc files. _________________ Mark |
