2.0.8.3 Compiler not working
Ev3658
PostPosted: Mon Jul 20, 2020 10:15 am    Post subject: 2.0.8.3 Compiler not working Reply with quote
Hello.
After the update, it stopped flashing.
I assume the compiler doesn't create files.
No files HEX and BIN.
PostPosted: Mon Jul 20, 2020 10:39 am    Post subject: Reply with quote
if you have a problem you need to post code that can be tested.
in case you have a problem with the IDE you best post your configuration file as well.
in any case you want to make sure that the serial from the help about matches that from the on in the register.
and that you enabled the compiler output options. that your target folder is writable. and that there do not files exist that have the read only attribute.
under options you can select the configuration file, or make a copy of it. for example you can copy the 2082 option file so you can use the settings from 2082.
Ev3658
PostPosted: Mon Jul 20, 2020 11:10 am    Post subject: Reply with quote
albertsm wrote:
......copy the 2082 option file .....
Version 2.0.8.2 also stopped compiling. Version 2.0.8.1 works fine.
Any program files stopped compiling (closes the window).
PostPosted: Mon Jul 20, 2020 11:27 am    Post subject: Reply with quote
you best contact support as you do not provide sufficient info here.
