Using a Byte array with Base64enc and Base64dec
bcunningham
PostPosted: Tue Jul 14, 2020 10:13 pm    Post subject: Using a Byte array with Base64enc and Base64dec Reply with quote
I need to Base64 some data that contains 0's. Is there any way to use a byte array with Base64enc? If I use a byte array as an "overlay" over the string variable, will the Base64enc function stop at the 0's?
Has anyone tried this?
PostPosted: Wed Jul 15, 2020 8:58 am    Post subject: Reply with quote
from the history : history = 2080.001 , base64encode and decode added for blocks/byte arrays
so yes that should work.
