ARDUINO UNO_ADC_4_DIGITOS
Goto page Previous  1, 2, 3
Printpix52
PostPosted: Tue Jul 14, 2020 6:31 am    Post subject: Reply with quote
enniom wrote:
An alternative to STR2DIGITS.
$sim
Dim I As Byte , W As Word , Digit As Byte
Dim St_w As String * 6
Dim Wd(5) As Byte At St_w Overlay
W = 12034
St_w = Str(w)
For I = 1 To 5
    Digit = Wd(i) - 48
    Print Digit
E
I will study but I do not know the STR2DIGITS instructions as I had commented companion of the forum and I will tell you later friend.
Thanks for the information.
Very Happy Very Happy
Paulvk
PostPosted: Tue Jul 14, 2020 6:37 am    Post subject: Reply with quote
Some of what I did with 7 segment display
I created an array in eeprom with the digit values.
This let me simply reference the binary display value
I also used serial to parallel 74HC595 drivers
this reduced the number of cpu ports
Below is some code to try to explain what I did
Note I am trying to find a clock I did with four 7 segment displays
You can also see in application note AN #196 me using eeprom this way
Regards Paul
'   so instead of this
  Data &B0110_1111                                         '0
   Data &B0000_0110                                         '1
   Data &B1010_1011                                         '2
   Data &B1000_1111                                         '3
   Data &B1100_0110                                         '4
   Data &B1100_1101                                         '5
   Data &B1110_1101                                         '6
   Data &B0000_0111                                         '7
   Data &B1110_1111                                         '8
   Data &B1100_1111
  'I did this
 'Below $eeprom will store the values in eeprom saving flash space
'If they are the first to store in eeprom then
dim segs(10) as eram byte
'this will refer to the first 10 locations in eeram as the DIM statements
'allocate them in order
'so another
dim cats(10) as eram byte
'refers to bytes 11 onwards and so on
'so now to get the byte for the number 3 all I need to do is
'use segs(3)
$eeprom
   Data &B0000_0110                                         '1  segs(1)
   Data &B1010_1011                                         '2
   Data &B1000_1111                                         '3
   Data &B1100_0110                                         '4
   Data &B1100_1101                                         '5 segs(5)
   Data &B1110_1101                                         '6
   Data &B0000_0111                                         '7
   Data &B1110_1111                                         '8
   Data &B0110_1111                                         '9 segs(9)
   Data &B1100_1111                                         '0 segs(10)
$data
  'note check byte (data) values not tested
Printpix52
PostPosted: Tue Jul 14, 2020 6:48 am    Post subject: Reply with quote
EDC wrote:
For 7SEG LED displays multiplexing you should have 50Hz for each display so for four of them you should calc 4x50Hz=200Hz.
Now look for your speed -> 16MHz/256=62500Hz Now 16bit Timer1 65536-62500=3036. So 62500Hz/3036=20Hz ONLY Crying or Very sad
For 200Hz you should use Prescaler = 2 and Timer1 = 25536
Second thing. Instead this code:
Presenta:
 Timer1 = 62500
 If Cnt < 4 Then
  Incr Cnt
  Else
    Cnt = 1
 If Cnt = 1 Then
  Q1 = 0 : Q2 = 0 : Q3 = 0 : Q4 = 1
  Portd = Lookup(w4 , Tabla)
 If Cnt = 2 Then
  Q1 = 0 : Q2 = 0 : Q3 = 1 : Q4 = 0
  Portd = Lookup(w3 , Tabla)
 If Cnt = 3 Then
  Q1 = 0 : Q2 = 1 : Q3 = 0 : Q4 = 0
  Portd = Lookup(w2 , Tabla)
 If Cnt = 4 Then
  Q1 = 1 : Q2 = 0 : Q3 = 0 : Q4 = 0
  Portd = Lookup(w1 , Tabla)
Use something like this:
Presenta:
 Timer1 = 25536                                             'remember Prescale = 2
 Incr Cnt : If Cnt > 4 Then Cnt = 1
 Select Case Cnt
  Case 1
     Q1 = 0
     Q4 = 1
  Case 2
     Q4 = 0
     Q3 = 1
  Case 3
     Q3 = 0
     Q2 = 1
  Case 4
     Q2 = 0
     Q1 = 1
 End Select
I already tested them with your timer Timer1 = 25536 and I agree with your calculation but it is the same fault as before.
It already works just change but you are very strange because it worked?
 Timer1 = 25536
 If Cnt < 4 Then
   Cnt = Cnt + 1
  Else
   Cnt = 1
These if the 4 digits work well.
Timer1 = 25536
 If Cnt < 5 Then
   Cnt = Cnt + 1
  Else
   Cnt = 1
O-Family
PostPosted: Tue Jul 14, 2020 10:09 am    Post subject: Reply with quote
Why call [Presenta] in the main routine (Do-Loop) without enabling interrupts?
I think your fix just happens to be in sync and the display looks good.
Furthermore, when you look at the picture, it looks like there is a ghost in the next digit.
Printpix52
PostPosted: Thu Jul 16, 2020 7:10 pm    Post subject: Reply with quote
With my new update to 2.0.8.3 it works fine !!!
4 digits more brightness!
Thank you all!!!
2.0.8.3
Page 3 of 3
