ARDUINO UNO_ADC_4_DIGITOS
Goto page Previous  1, 2, 3  Next
Printpix52
PostPosted: Sun Jul 12, 2020 3:13 am    Post subject: Reply with quote
Now I understand all the pure logic, friend. I am going to test your program and I will tell you tomorrow because it is already very nights.
Good night!!
Smile Smile
O-Family
PostPosted: Sun Jul 12, 2020 4:01 am    Post subject: Reply with quote
I was able to understand the method you want to achieve.
It's a programming mistake.
   Dim W As Word
   Dim W1 As Word
   Dim W2 As Word
   Dim W3 As Word
   Dim W4 As Word
   W = 1234
   W1 = W / 1000                                            'W1 = 1
   W2 = W Mod 1000                                          'W2 = 234
   W2 = W2 / 100                                            'W2 = 2
   W3 = W Mod 100                                           'W3 = 34
   W3 = W3 / 10                                             'W3 = 3
   W4 = W Mod 10                                            'W4 = 4
   Print W1
   Print W2
   Print W3
   Print W4
   Print
Printpix52
PostPosted: Sun Jul 12, 2020 7:12 pm    Post subject: Reply with quote
Hi!! O_Family!!
Now if I already understand all of them, it is pure logic and mathematics.
All three simulator of yours works fine now I am going to test external card.
PostPosted: Mon Jul 13, 2020 9:57 am    Post subject: Reply with quote
also have a look at STR2DIGITS function.
O-Family
PostPosted: Mon Jul 13, 2020 1:11 pm    Post subject: Reply with quote
Hello, Mark
I overlooked this wonderful function.
Recent additions?
I'll add it to my manual now!
PostPosted: Mon Jul 13, 2020 1:42 pm    Post subject: Reply with quote
i think it exist some time. since version 2.0.5.0
Printpix52
PostPosted: Mon Jul 13, 2020 7:39 pm    Post subject: Reply with quote
Hello everyone the World !!
I already learned them very well mathematically and logically and the simulator works very well.
[img][/img]
Razz Razz
Printpix52
PostPosted: Mon Jul 13, 2020 7:58 pm    Post subject: Reply with quote
At the time of connecting with the digits it works and gives values 0-1023 but there are some digits are weak and others are not, why is it? My card is fine.
Sad
DIGITO___1 _Low_Led
DIGITO___0 _High_Led___OK!!
DIGITO___2_ Low_Led
DIGITO___3_High_Led___OK!!
[img][/img]
Printpix52
PostPosted: Mon Jul 13, 2020 10:37 pm    Post subject: Reply with quote
I did a test for 4 digits all work well then what will it be? Is it not a faulty program or is it not compatible on port D? Question Question
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
'CtrL
 Ddrb.0 = 1
 Portb.0 = 1
 Ddrb.1 = 1
 Portb.1 = 1
 Ddrb.2 = 1
 Portb.2 = 1
 Ddrb.3 = 1
 Portb.3 = 1
'Segmento display
 Ddrd = 255
 Portd = 0
Segmento Alias Portd
Dim I As Byte
  For I = 0 To 15
   Segmento = Lookup(i , Tabla)
   Waitms 1000
  Next I
  For I = 15 To 0 Step -1
   Waitms 1000
  Next I
'Catodo Comun
Tabla:
 Data 63
 Data 6
 Data 91
 Data 79
 Data 102
 Data 109
 Data 124
 Data 7
 Data 127
 Data 103
 Data 119
 Data 124
 Data 57
 Data 94
 Data 121
 Data 113
Printpix52
PostPosted: Tue Jul 14, 2020 12:27 am    Post subject: Reply with quote
Isn't this a program? There are no other ways?
1234
4
3
2
1
Dim W1 As Word
Dim W2 As Word
Dim W3 As Word
Dim W4 As Word
Dim Wx As Word
Dim Wy As Word
Const W = 1234
 Print "W= " ; W
 W1 = W Mod 10
 Print "W1= " ; W1
 Wx = W / 10
 Print "Wx= " ; Wx
 W2 = Wx Mod 10
 Print "W2= " ; W2
 Wy = Wx / 10
 Print "Wy= " ; Wy
 W3 = Wy Mod 10
 Print "W3= " ; W3
 W4 = Wy / 10
 Print "W4= " ; W4
Printpix52
PostPosted: Tue Jul 14, 2020 12:30 am    Post subject: Reply with quote
Are you ok or wrong?
$crystal = 16000000
$hwstack=40
$swstack=16
$framesize=32
 Ddrb = 255
 Portb = 0
 Q1 Alias Portb.0
 Q2 Alias Portb.1
 Q3 Alias Portb.2
 Q4 Alias Portb.3
 Ddrd = 255
 Portd = 0
 Config Adc = Single , Prescaler = Auto , Reference = Avcc
 Start Adc
 Config Timer1 = Timer , Prescale = 256
 On Timer1 Presenta
 Enable Timer1
 Timer1 = 62500
 Dim W As Word
 Dim W1 As Word
 Dim W2 As Word
 Dim W3 As Word
 Dim W4 As Word
 Dim Wx As Word
 Dim Wy As Word
 Dim Cnt As Word
  W = Getadc(0)
   W = W
  If W > 9999 Then
     W = 1023
  Gosub Separa
  Gosub Presenta
 Separa:
 W1 = W Mod 10
 Wx = W / 10
 W2 = Wx Mod 10
 Wy = Wx / 10
 W3 = Wy Mod 10
 W4 = Wy / 10
 Presenta:
 Timer1 = 62500
 If Cnt < 4 Then
  Incr Cnt
  Else
    Cnt = 1
 If Cnt = 1 Then
  Q1 = 0 : Q2 = 0 : Q3 = 0 : Q4 = 1
  Portd = Lookup(w4 , Tabla)
 If Cnt = 2 Then
  Q1 = 0 : Q2 = 0 : Q3 = 1 : Q4 = 0
  Portd = Lookup(w3 , Tabla)
 If Cnt = 3 Then
  Q1 = 0 : Q2 = 1 : Q3 = 0 : Q4 = 0
  Portd = Lookup(w2 , Tabla)
 If Cnt = 4 Then
  Q1 = 1 : Q2 = 0 : Q3 = 0 : Q4 = 0
  Portd = Lookup(w1 , Tabla)
 Tabla:
 Data 63
 Data 6
 Data 91
 Data 79
 Data 102
 Data 109
 Data 124
 Data 7
 Data 127
 Data 103
O-Family
PostPosted: Tue Jul 14, 2020 1:56 am    Post subject: Reply with quote
When LEDs are dynamically lit (pulse lit) (duty lit), if the display time for each digit is not constant, the light and shade will appear for each digit.
Normally, a periodic interrupt is used to light each digit sequentially with a pulse for a certain period.
Earlier, I told you that if you turn on the light while doing the calculation in the main routine like you, there will be a problem with the processing time, but that is the result.
In addition, when using dynamic lighting, it is necessary to turn off the common signal for each digit, change the segment data, and turn on the common signal.
This blanking period prevents the ghost phenomenon that affects the display of adjacent digits.
enniom
PostPosted: Tue Jul 14, 2020 3:55 am    Post subject: Reply with quote
An alternative to STR2DIGITS.
$sim
Dim I As Byte , W As Word , Digit As Byte
Dim St_w As String * 6
Dim Wd(5) As Byte At St_w Overlay
W = 12034
St_w = Str(w)
For I = 1 To 5
    Digit = Wd(i) - 48
    Print Digit
E
Printpix52
PostPosted: Tue Jul 14, 2020 6:25 am    Post subject: Reply with quote
Thanks Friend O_Family.
I was reading the calculation of the timer, all of them are fine, for me I lack many to study this topic, I am going to study in your tutorial with time and calm.
I already found the flaws you were the program but it works very well since you turn on the 4 digits and I am very happy.
Anyway I already learned the Mod and Lookup instructions how it works ok.
The 4 digits already works very well.
If Cnt < 5 Then
   Cnt = Cnt + 1
  Else
   Cnt = 1
PostPosted: Tue Jul 14, 2020 6:29 am    Post subject: Reply with quote
For 7SEG LED displays multiplexing you should have 50Hz for each display so for four of them you should calc 4x50Hz=200Hz.
Now look for your speed -> 16MHz/256=62500Hz Now 16bit Timer1 65536-62500=3036. So 62500Hz/3036=20Hz ONLY Crying or Very sad
For 200Hz you should use Prescaler = 2 and Timer1 = 25536
Second thing. Instead this code:
Presenta:
 Timer1 = 62500
 If Cnt < 4 Then
  Incr Cnt
  Else
    Cnt = 1
 If Cnt = 1 Then
 If Cnt = 2 Then
 If Cnt = 3 Then
 If Cnt = 4 Then
Use something like this:
Presenta:
 Timer1 = 25536                                             'remember Prescale = 2
 Incr Cnt : If Cnt > 4 Then Cnt = 1
 Select Case Cnt
  Case 1
     Q1 = 0
     Q4 = 1
  Case 2
     Q4 = 0
     Q3 = 1
  Case 3
     Q3 = 0
     Q2 = 1
  Case 4
     Q2 = 0
     Q1 = 1
 End Select
Page 2 of 3
