Didnt start in Win11
MichaelB.
PostPosted: Fri Dec 24, 2021 3:34 pm    Post subject: Didnt start in Win11 Reply with quote
Hello,
does anyone have the same Problem with 2084 and Win11 ?
(BASCOM-AVR version : 2.0.8.4 )
PostPosted: Fri Dec 24, 2021 5:29 pm    Post subject: Reply with quote
did you install bascom with administrator right ?
I install 85 beta without any problem
JP Wink
MichaelB.
PostPosted: Fri Dec 24, 2021 6:36 pm    Post subject: Reply with quote
I Install it on a 3.0 USB Stick .
It Worked on my Win10 Computer without any Problems.
And the Second Computer had Win10 before and is Upgraded to Win11.
PostPosted: Fri Dec 24, 2021 9:34 pm    Post subject: Reply with quote
- install with admin rights. on a network PC it is sometimes needed to use a local admin account
- run bascom the first time with admin rights.
after a reboot you could run it with normal user rights.
when you get the error you got it means a component is not properly installed. you can do this manual :
- create a command window with admin rights
- CHDIR to the bascom-avr application folder
- type : REGSVR32 MFC42.DLL
- you should get an OK message.
- type : REGSVR32 SAXCOMM7.OCX
now run the software again.
after all the years it is not clear to me why some users get the error and other dont.
I always test on a VM and it always seems to work right. But of course these are default windows installations without specific settings.
MichaelB.
PostPosted: Fri Dec 24, 2021 10:52 pm    Post subject: Reply with quote
Thanks.
Maybe Win11 deleted the Admin Rights??
I used this 2084 USB Installation many times on Both of my Comupters which changed the Windows versions since 2084 is available.
I had Win7 as i Installed 2084 on my USB Stick. And it Worked all fine with no issues. And now with Win11 i have no Admin Rights anymore??. Wierd :/
This Worked Smile
- type : SAXCOMM7.OCX
"Command is wrong or it canot be found"
MichaelB.
PostPosted: Fri Dec 24, 2021 11:34 pm    Post subject: Reply with quote
Now i got it.
The SAXCOMM7.OCX command need a APP.
The Console said: The shown Programm can not be Found.
PostPosted: Sat Dec 25, 2021 12:20 am    Post subject: Reply with quote
sorry about that, yes :
MichaelB.
PostPosted: Sat Dec 25, 2021 11:24 am    Post subject: Reply with quote
Now it works ! Bascom is Starting.
Thanks Mark Smile
