Debounce
KenHorse
PostPosted: Sun Jul 05, 2020 5:10 pm    Post subject: Debounce Reply with quote
No mention made in HELP but can DEBOUNCE be reconfigured during runtime or only at compilation? Specifically, change the amount of time during runtime?
(my suspicion is no)
PostPosted: Sun Jul 05, 2020 5:24 pm    Post subject: Reply with quote
You can find in the Help topic about "Config" where is the table of RE-USABLE configs Wink
KenHorse
PostPosted: Sun Jul 05, 2020 5:33 pm    Post subject: Reply with quote
Thanks.
As I suspected... too bad...darn
JC
PostPosted: Mon Jul 06, 2020 1:04 am    Post subject: Reply with quote
Using all of the "High Level" commands / instructions in Bascom makes coding projects easy, as one can focus on the big picture and not get dragged down worrying about nitty-gritty details.
That said, however, something like Debouncing Push Button Switches is easily done within one's own code, and then one has complete control over the time frame for considering a switch debounced, can vary it for different types of switches, can add auto-repeat flags, or add a piezo beep if it is newly pressed, etc.
Some code is very well written for fast speed, or to conserve memory.
The example below does neither!
It demonstrates debouncing two PB Switches in software.
When PB Sw #1 is pressed, and debounced, it turns on LED #2.
When PB Sw #2 is pressed, and debounced, it turns off LED #2.
Led #1 flashes at 1 Hz to show that the system is alive and running.
A timer/counter is set up to fire an interrupt at 1 KHz, (i.e. once per mSec).
That is used to check the status of the switches and set a debounce flag when
they are pressed and debounced.
One clears the switch's flags within the Main Loop, when an action is performed
for the switch having been pressed.
The Variable PBSwDBVal (Psu Button Switch Debounce Value) is the number of
mSec that the switch must be continuously low for, (without any further
bouncing), before setting the DeBounced Flag.
For a typical switch and project it might be 25 (25 mSec).
For demonstrating the program one can increase it to 255.
At that level a very short press won't be seen as pressed and debounced, and
the LED won't be turned on, (or off).
As the Debounce time duration is a variable, you can set it on the fly, during the program.
You could even have different timeframes for different buttons!
JC
'File: Nano Bosch PCB Testbed V1.bas
'This program demonstrates a simple
'approach to Push Button Switch debouncing
'Doesn't implement autorepeat or piezo beep.
'PBSwDBVal = # of mSec of continuously pressed time
'without any bounce for the Debounce Flag to be set.
'Set = 25 for real projects, (typically)
'Set to 255 to see that fast pushes do get set as
'having been pressed.
'Heartbeat from ISR flashes LED 1 once / second.
'PB Sw1 Turns On  LED#2
'PB Sw2 Turns Off LED#2
'Hardware:
'Arduino Nano:
'Mega328P 5V
'16 MHz External Xtal,
'Blue PCB name: Nano Testbed V1
'PB Switches are tied to Ground, and the
'internal pull-up resistors are enable to
'hold the pin high unless it is pressed.
'The pin is LOW when pressed.
'Port C.2   I  PBSw 2
'Port C.3   I  PBSw 1
'Port D.5   O  LED 2
'Port D.6   O  LED 1
'Port C.1   O  LED 3
'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
   $regfile = "m328pdef.dat"                                'Define the uC
   $crystal = 16000000                                      '16 MHz
   $hwstack = 40                                            'Hardware Stack
   $swstack = 40                                            'Software Stack
   $framesize = 40                                          'Frame Space
   LED1 Alias PortD.6                                       'LED
   LED2 Alias PortD.5                                       'LED
   LED3 Alias PortC.1                                       'LED
   PBSw1 Alias PinC.3                                       'PB Sw #1 Read Input
   PBSw2 Alias PinC.2                                       'PB Sw #2 Read Input
 'Variable Definitions:
   Dim Lpcnt As Word                                        'Loop Counter
   Dim Ttcnt As Word                                        'Tick Toc ISR Counter
   Dim Rvbit As Bit                                         'For Register Setup
   Dim Regdata As Byte                                      'For Register Setup
   Dim Tmpstr As String * 16
   Dim Hbcnt As Word                                        'Hear Beat Counter for LED
   Dim Regval As Byte                                       'Register Value for manual config
   'PB Switch Debounce variables:
   Dim PBSw1DBF as Byte                                     'PB Sw #1 Debounce Flag, 1 = Pressed
   Dim PBSw2DBF as Byte                                     'PB Sw #2 Debounce Flag, 1 = Pressed
   Dim PBSw1Cntr as Byte                                    'Debounce couunter
   Dim PBSw2Cntr as Byte                                    'Debounce couunter
   Dim PBSwDBVal as Byte                                    'Threshold for Debounce, mSec
   Dim Pressed as Byte                                      'PB Sw Status for User stopped pressing
   'Hardware Startup Delay:
   Waitms 500                                               'Power Up Time
   'Configure the Port's Pins for Input or Output mode.
   '0 = Input, 1 = Output
   'Nano Testbed Blue PCB with Bosch Sensor configuration:
   Config Portb = 47                                        'PortB
   Config PortC = 35                                        'PortC
   Config PortD = 246                                       'PortD
   'Hardware startup Flash everything:
   Gosub LEDFlash                                           'Startup flash
   'Enable internal Pull-Up resistors for the two PB Switches
   PortC.3 = 1                                              'PB Sw 1
   PortC.2 = 1                                              'PB Sw 2
   'Config Timer/Counter #0, 8-Bit, for q 1 mSec ISR, (CTC Mode)
   'This is the Master ISR for the Project's timing needs.
   'Clock = 16 MHz, Pre-Scaler = Div by 64
   'Clock into T/C#0 = 16M/64 = 250k
   'Set Top to 250 - 1, (for roll over to 0), for q 1 mSec ISR.
   'First Turn On the Timer/Counter#0 Module.
   'Read the Power Reduction Register, set the Tim0 bit to 0 to Enable it.
   'Then write it back.  This does NOT alter any other module's activity.
   'Bitwise AND with 1101 1111   All bits unchanged, except Bit 5 = 0.
   Regval = Prr                                             'Read in current Power Reduction Register Values
   Regval = Regval And &B11011111                           'Force Bit 5 = 0
   Prr = Regval                                             'Write back the new value
   tccr0a = 2                                               'CTC Mode, No I/O pins active
   tccr0b = 3                                               'Pre-Scaler = Div By 64
   timsk0 = 2                                               'Intr Output Comp A Enabled
   ocr0a = 249                                              'Div by 250
   On Oc0a TicToc                                           'Timer/Counter0 CTC A Intr
Inits:
   Ttcnt = 0                                                'Init Tick Tock ISR Counter
   PBSwDBVal = 25                                           '25 or 255 mSec Debounce Time
Main:
   Enable Interrupts                                        'Global Enable Interrupts
      'Do something useful here
      'Now check the User Interface and act accordingly
      'Check User Interface Push Button Switch flags from debounce routine:
      If PBSw1DBF = 1 then
         'PB Sw #1 is pressed and debounced
         Set LED2
         'Now clear the flag
         PBSw1DBF = 0
      End if
      If PBSw2DBF = 1 then
         'PB Sw #2 is pressed and debounced
         Reset LED2
         'Now clear the flag
         PBSw2DBF = 0
      End if
TicToc:
   'Timer/Counter#0 ISR
   'Master Timer for Project
   'ISR Fires at 1 KHz rate, (once / 1 mSec)
   'HeartBeat LED   Flashes once per Second
   Ttcnt = Ttcnt + 1                                        'Incr
   If Ttcnt < 5 Then
      Set Led1                                              'LED On
   Else
       Reset Led1                                           'LED Off
   If Ttcnt > 999 Then
      Ttcnt = 0                                             'Rollover
   'PB Sw debouncer code
   'On Exit set PBSw1DBF Debounce Flag = 1 if pressed
   'On Exit set PBSw2DBF Debounce Flag = 1 if pressed
   'These Flags are cleared by the Main Loop processing them.
   'PBSwDBVal is set in inits.
   'It is the number of mSec the PB Switch must be pressed
   'continuously without any further bounces before the
   'switch is considered debounced.  e.g. 20
   'Master TicToc ISR fires once per mSec.
   'Process PB Sw#1:
   If PBSw1 = 0 then
      'It is pressed
      PBSw1Cntr = PBSw1Cntr + 1                             'Add 1 mSec
      If PBSw1Cntr >= 255 then                              'Hold so variable doesn't wrap to 0
         PBSw1Cntr = 255
   Else
       'It either isn't pressed, or it bounced
       'So reset the counter and start over
       PBSw1Cntr = 0
   End if
   If PBSw1Cntr >= PBSwDBVal then
      'It is debounced
      PBSw1DBF = 1                                          'Set Debounced Flag
   End if
   'Process PB Sw#2:
   If PBSw2 = 0 then
      'It is pressed
      PBSw2Cntr = PBSw2Cntr + 3                             'Add 3 mSec
      If PBSw2Cntr >= 255 then                              'Hold so variable doesn't wrap to 0
         PBSw2Cntr = 255
   Else
       PBSw2Cntr = 0
   End if
   If PBSw2Cntr >= PBSwDBVal then
      'It is debounced
      PBSw2DBF = 1                                          'Set Debounced Flag
   End if
LEDFlash:
            'Flash LEDs on startup
            For LpCnt = 1 to 3
                Set LED1
                Waitms 75
                Set LED2
                Waitms 75
                Set LED3
                Waitms 75
                Reset LED1
                Waitms 75
                Reset LED2
                Waitms 75
                Reset LED3
                Waitms 75
            Next LpCnt
