TMC2130 Stepper Driver in standalone mode
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
snow
PostPosted: Tue Jun 23, 2020 5:50 am    Post subject: TMC2130 Stepper Driver in standalone mode Reply with quote
Hi. This is more of an electronic question than a Bascom issue.
I've got a issue with a TMC2130 stepper driver module running in standalone mode. I can get the motor turning fine with the step/dir pins. I am wanting to keep an eye on the motor with the DIAG0 and DIAG1 pins on the module. DIAG0 pin is for Reset and stall detect and DIAG1 is for motor index.
I can't get the pin's to do anything. DIAG0 requires pullup of 100k or less and DIAG1 requires pull down on of 50k..
On page 72 of the data sheet it says DIAG0 should pull low on reset. I can't get any of these 2 DIAG pins to do anything. I can get the step mode working correctly by changing the CFG1-2 pins around
Ive got CFG0 pin Gnd, CFG3 pin High, CFG4 pin Gnd, CFG5 pin High
CFG1-2 pins are step modes (full step,half etc)
Cheers
Snow
PostPosted: Tue Jun 23, 2020 12:24 pm    Post subject: Re: TMC2130 Stepper Driver in standalone mode Reply with quote
In fact there is no relation to Bascom at all, why do you intentionally post it in the wrong part of the forum then?
RTFM, page 85, quote:
Figure 24.1 Standalone operation with TMC2130 (pins shown with their standalone mode names)
GCONF settings:
GCONF.diag0_error = 1: DIAG0 works in open drain mode and signals driver error.
GCONF.diag1_index = 1: DIAG1 works in open drain mode and signals microstep table index position.
No and yes.
Stall detect and other options are active if configured via SPI, in standalone operation SPI is off and I read the data sheet the way, that only functions as mentioned are active, i.e. driver error and motor index.
The motor index may trigger, but you miss it by making DIAG1 useless with a pull-down.
... and DIAG1 requires pull down on of 50k.
'Pulldown, PMD, PDD' according data sheet sounds a bit deceptive.
These pins can work in open-drain or in push-pull mode, in 'standalone mode' open-drain is active.
The open-drain stages as shown at page 72 pull both to ground, to get some signal change, pull-ups must be used.
Understandable, if a pull-down is connected parallel to an open-drain and reset of the stepper controller simply may not show up while in operation.
snow
PostPosted: Tue Jun 23, 2020 9:23 pm    Post subject: Reply with quote
Thanks for your reply
Because I'm using a Bascom to control the micro to handle the smarts of running this module and you people are very helpful. Is there another forum that is great for electronic help?
Ive tried leaving both DAIG pins float, pulled high and low with resistors but nothing changes when I get pull the module reset pin high. The module's reset pin works as it lets the motor freewheel and soon as I take the pin low the motor locks and moved when I trigger the Step pin
Thanks
PostPosted: Tue Jun 23, 2020 10:00 pm    Post subject: Reply with quote
This site provides an appropriate forum section:
AVR
AVR hardware related. Here you can discuss topics that are not directly BASCOM related. But are related to the AVR.
You may notice that page 72 speaks about a power-on reset, while you are pulling the reset pin high.
DIAG0 always shows a power-on reset condition by pulling low during a reset condition.
That's not the same.
Also pulling DIAG0 low at power-on reset may result in a quite short pulse, so I'd check with an oscilloscope.
snow
PostPosted: Tue Jun 23, 2020 11:21 pm    Post subject: Reply with quote
as per datasheet pg72
PDD=100k pulldown
PMD=50k to VCC/2
My VCC is 5v
I've got the DIAG0 pin tied to 2.5v with a 52k resistor as per the data sheet on page 72 . When I hold the reset pin on the module High the DIAG0 pin just stays at 2.5v on the scope. By the looks of the Schematic it should go to VCC under reset condition
I've tried a different module but the results at the same.
I cannot see anything on the scope, even if i one shot capture it and set the trigger at 2.6v
Thoughts?
PostPosted: Wed Jun 24, 2020 9:02 am    Post subject: Reply with quote
when posting in the BASCOM-AVR forum there should be at least some BASCOM code shown.
And when it is about a chip, include a link to the PDF as well.
PostPosted: Wed Jun 24, 2020 9:25 am    Post subject: Reply with quote
PDD=100k pulldown
PMD=50k to VCC/2
You need to read my replies.
Which reset pin? By looking up a module, I did not find any.
https://wiki.fysetc.com/TMC2130/
the module's reset pin works as it lets the motor freewheel
Sounds not like a dedicated reset, more like the 'driver enable' input.
Of course the module can provide a reset pin, which, quote from the data sheet:
In order to reset the chip to power on defaults, any of the supply voltages monitored by internal reset circuitry (VSA, +5VOUT or VCC_IO) must be cycled. VCC is not monitored.
cycles any of these voltages.
It's your job to link to the module you use, it's not mine to guess it, all I see is the chip's schematic and the chip does not have a dedicated reset-pin.
Surely not, neither from schematic, nor from quote page 72:
'Reset condition' is read in context with the first part of the sentence, which specifies 'power-on reset'.
Which schematic exactly, the one on page 72?
From this schematic a signal called 'power-on reset' connects to an OR-gate.
In standalone mode the signal 'diag0_pushpull' is inactive, thus connecting the gate's output to the mosfet's gate, while the mosfet's source is connected to ground.
A signal level high for 'power-on reset' will result in a high at the mosfet's gate and this will pull DIAG0 to ground.
Did you check at switching power-on? As said your module's reset pin may not be what you think it is.
Attached two excerpts from the data sheet, one of them shows DIAG1 is open-drain/pull-up too.
As the data sheet tells two times about pull-down, it's contradictory.
I'm all for pull-up because of the schematic and table.
snow
PostPosted: Thu Jun 25, 2020 3:14 am    Post subject: Reply with quote
Hi Thanks for your reply
Here's a list of information I SHOULD HAVE included in my earlier post as pointed out.. my fault totally
Product Name: SlientStepStick
Chipset: TMC2130-LA
Product link
https://www.trinamic.com/fileadmin/assets/Products/Eval_Drawings/SilentStepStick-TMC2130_v10.pdf
Chipset Datasheet
https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2130_datasheet_Rev1.12.pdf
Yes product does NOT have an external reset pin as you stated . I mistakenly call it that . I was meaning enable pin
Theses are my setting on config pins
I have closed the SPI jumper put it into standalone mode.
Motor power is Vm pin = 5v
Vio Pin=5v
CFG0= GND
CFG1= 5v Step rate (Halfstepping)
CFG2=Gnd
CFG3= 5v
CFG4= GND as per layout drawing
CFG5=5v as per layout drawing
Standalone mode configuration on page 85 of chipset datasheet
I was trying to get DIAG0 pin connected for driver error and stall checking. The module is running the motor fine but was i was trying to add a few error checking features to my code.
Thanks for you help
PostPosted: Thu Jun 25, 2020 10:34 am    Post subject: Reply with quote
Like I thought. This disables the power stages, but does not reset the TMC2130.
You've waited for a reaction to an action that never happened.
I wrote that already, in standalone mode the signals connected to the diags are GCONF.diag0_error and GCONF.diag1_index, nothing else.
Driver error is set by default in standalone mode, stall checking is off.
For this purpose you need to leave standalone mode 2 and switch to Step/Direction Driver mode 1, where you can access GCONF and others via SPI.
It comes not clear from the data sheet, if it works to set registers bits like GCONF.diag0_stall in mode 1, and keep the bit set after switching back to mode 2.
Try it out, if you wanna know.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
