Software UART parity error detection
dk9uv
PostPosted: Mon Jun 08, 2020 9:07 am    Post subject: Software UART parity error detection Reply with quote
I wonder if it is possible to detect parity errors when using the software uart?
I changed the software uart example from BASCOM help to 7 bits and even parity (and port pins and crystal frequency).
Using the terminal programm Tera Term even and odd parity are both accepted and return the same result.
Best regards
Chris
$regfile = "m168def.dat"
$crystal = 7372800
$hwstack = 128
$swstack = 128
$framesize = 128
Dim B As Byte
Waitms 100
'Open a TRANSMIT channel for output
Open "comd.1:19200,7,e,1" For Output As #1
Print #1 , "serial output"
'Now open a RECEIVE channel for input
Open "comd.0:19200,7,e,1" For Input As #2
'Since there is no relation between the input and output pin
'there is NO ECHO while keys are typed
Print #1 , "Press any alpha numerical key"
'With INKEY() we can check if there is data available
'To use it with the software UART you must provide the channel
   'Store in byte
   B = Inkey(#2)
   'When the value > 0 we got something
   If B > 0 Then
      Print #1 , Chr(b)                         'Print the character
Close #2                                         'Close the channels
Close #1
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.8.2 )
Paulvk
PostPosted: Mon Jun 08, 2020 12:00 pm    Post subject: Reply with quote
Hello Chris dk9uv
Are you trying to detect transmission errors?
If so can you use CRC which I have made code for already.
Regards Paul vk2pl
dk9uv
PostPosted: Mon Jun 08, 2020 1:55 pm    Post subject: Reply with quote
Hi Paul,
thanks for the quick reply.
The reason I am asking is that I want to implement the SDI-12 protocol which is used for some sensors. SDI-12 uses 7 bit and even parity.
CRC can optionally be included, see SDI-12 specification: http://www.sdi-12.org/current_specification/SDI-12_version-1_4-Jan-10-2019.pdf
and I have implemented that already.
I was just curious to know if I can detect parity errors as well.
So far I have never used parity, normally I take 8,N,1 settings for UART and use CRC.
With best regards
Chris
