Grey Code (possible bug / suggestion)
grasulgras
PostPosted: Mon May 25, 2020 9:36 pm    Post subject: Grey Code (possible bug / suggestion) Reply with quote
Hello, everybody.
Just downloaded BASCOM 2.0.8.2 and it's awesome. Until now i ran version 2.0.7.9 and have made quite some projects on it.
There's a new feature which, to be honest, i really like - code graying. It helps me a lot with Spaghetti Code - which is inevitable in some situations... however, it does not always get the code graying right.
For example, i use interrupts a lot, and it grays redundant code as intended - but, because of that waitms (1000) between the two lines and and interrupt handler which reads the variable at two different times, this graying gets it wrong - that code is not redundant.
It does not affect code execution, it just annoys me when it appears on screen like that.
Is there someway to turn it off, just for certain lines. Even better, maybe enable it for other lines, that the IDE did not autodetect? This is a very useful feature!
PostPosted: Mon May 25, 2020 11:56 pm    Post subject: Reply with quote
I think this is intended to be used after some code is done.
You can Enable/Disable it in the menu tab Edit->Show Dead Code
Im using it for search unused but Dim`ed variables (reused code copy/paste). So only when some part of the code is working I enable "Show Dead Code" for check and disable it again because even new Dim`ed variables that I want to use in the next line are greyed till variable is not used.
PostPosted: Tue May 26, 2020 8:48 am    Post subject: Reply with quote
EDC is right. it is just a tool to be used when the project is done.
It is important that when you find a problem you report it to support with a sample so it can be improved.
