Atmega1284p - OCR3B
mariosm
PostPosted: Tue May 05, 2020 11:35 am    Post subject: Atmega1284p - OCR3B Reply with quote
I want to use OCR3B but not supported on Atmega1284p compiler.
This is the code.
Config Timer3 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 256 , Noise_cancel = 1
Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 256 , Noise_cancel = 1
Config Timer2 = Pwm , Pwm = On , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 256       'we adjust timer
Enable Interrupts                                           'We Allow interruptions
Enable Timer0
Enable Timer1
Enable Timer2
Enable Timer3
Led1 Alias OCR1A                                        'PIN 14 PD5  red
Led2 Alias OCR1B                                          'PIN 13 PD4  green
Led3 Alias OCR2A                                           'PIN 16 PD7  blue
Led4 Alias OCR2B                                         'PIN 15 PD6  white
Led5 Alias OCR3A                                            'PIN  2 PB6
Led6 Alias Ocr3b                                            'PIN  3 PB7
Τhere is a solution on this problem?
Bascom AVR ver 2.0.8.6 full version
PostPosted: Tue May 05, 2020 12:32 pm    Post subject: Reply with quote
In the DAT file for m1284p youll find such [WIO] constans:
COMPARE3A=$98
PWM3A=$98
OCR3A=$98
Like you see they have the same addresses so Compare3a, Pwm3a or Ocr3a means the same.
One line above youll find only :
COMPARE3B=$9a
PWM3B=$9A
So OCR3B is missing but you still can use Compare3b or Pwm3b syntax without any problem Wink
If you want you can add missing OCR3B=$9A into the DAT file by editing it with some Text editor, and Bascom should recognize your syntax then.
