Xpin slewrate configuration
16mk
PostPosted: Sat Apr 25, 2020 8:21 pm    Post subject: Xpin slewrate configuration Reply with quote
$lib "xmega.lib"
$regfile = "xm16e5def.dat"
$hwstack = 64
$swstack = 40
$framesize = 40
Dim A As Byte
Config Portd.1 = Output
Config Xpin = Portd.1 , Invertio = Enabled
Config Portd.2 = Output
Config Xpin = Portd.2 , Invertio = Enabled , Slewrate = Enabled
Bascom AVR simulator sets &H40 on PORTD PIN1CTRL and &HC0 on PORTD PIN2CTRL. It means that bits 7. are 0 and 1. PORTCFG SLRCTRL is still 0.
XMEGA E MANUAL says: "12.13.14 PINnCTRL – Pin n Control Register Bit 7 – Reserved
This bit is unused and reserved for future use. For compatibility with future devices, always write this bit to zero when this register is written."
BASCOM-AVR help CONFIG XPIN:
Example
Config Xpin = Portc.0 , Slewrate = Enabled , Outpull = Buskeeper , Sense = Low_level
It suggests that slewrtate is enabled individually for Portc.0
"12.14.4 SRLCTRL – Slew Rate Limit Control Register Bit 3 – SRLENRD: Slew Rate Limit Enable on PORTD Setting this bit will enable slew rate limiting on port D."
It means that there is only one bit for setting slew rate for whole PORTD ( bit 2 SRLENRC) and PINnCTRL register is only for setting Inverted I/O Enable, Output and Pull Configuration and Input/Sense Configuration.
I expected unchanged bit 7. and changed PORTCFG SLRCTRL.
PostPosted: Tue Apr 28, 2020 9:11 am    Post subject: Reply with quote
i will have a look at it.
The E series has some differences compared to the other Xmega series. The core is the same but with some subtle changes.
p.s.
it is always best to write to support when you find a bug.
16mk
PostPosted: Tue Apr 28, 2020 1:59 pm    Post subject: Reply with quote
Yes, I checked A series. It is exactly like Bascom-AVR help and AVR simulator described above.
