Posted: Sun Jan 01, 2006 5:18 pm Post subject: 4 sessions simultanous
I would like to know how to creating a tcpip program with 4 sessions, actually i have a bug ... if i put a do / loop i can't check if others sessions are sending datas, simple because i can't exit the loop ... i tried with a timer but i have the others bugs, i check a lot of examples and i never see an example for multi sessions, it's the same thing for web server!!!
Can we do have a software with 4 sessions or it's just for fun???!!!!
Someone have a little example or idea????
Thank you for your answer
maxspeed
Case Sock_established ' Val 6
Result = Socketstat(channelx , Sel_recv) ' get number
Peer = Getdstip(channelx)
In_ip = Ipnum(peer)
In_ip = "Votre adresse IP est: " + In_ip + ", Port: " + Str(getdstport(0)) + ", Channel: " + Str(channelx)
Print "in_ip"
Result = Tcpwritestr(channelx , In_ip , 255) ' send welcome
If Result > 0 Then
==> Do
Result = Tcpread(channelx , S)
Print "Data from client: " ; " " ; S
If Lcase(s) = "exit" Then
Closesocket Channelx
===> Loop Until Result = 0
