system time conversion
jeremywilson
PostPosted: Thu Feb 20, 2020 12:21 am    Post subject: system time conversion Reply with quote
I need help converting the Bascom system time (seconds from 12:00am, 1/1/2000) to Excel/Windows system time (days from 12:00am, 1/1/1900).
My program logs data and records the Bascom system time, but I'd rather record the Excel system time so users don't have to make the change.
I believe the conversion to be:
Excel time = Bascom time / 86400 + 36526
If I record Bascom time and convert in Excel using the above formula the results are correct.
However, if I do the conversion in the micro, the results are weird.
The time resolution is 377.5 seconds instead of 1 second.
I tried splitting up the division, but no luck.
   Temp_long = syssec()
   Temp_single = Temp_long
   Temp_single = Temp_single / 86400
   Temp_single = Temp_single + 36526
   Msg = Fusing(temp_single , "#.######")
example correct numbers:
date/time: 2/19/2020 11:23:16 am
Bascom time: 635426596
Excel time: 43880.4744907407
Thanks !!!
[/code]
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.2 )
View user's profile AIM Address
laborratte
PostPosted: Thu Feb 20, 2020 1:16 am    Post subject: Reply with quote
The "Excel" time has too many significant digits for datatype single. You can use double for your calculation, but unfortunately fusing doesn't work with double - you have to figure out a formatting routine by yourself.
jeremywilson
PostPosted: Thu Feb 20, 2020 1:19 am    Post subject: Reply with quote
Thanks for the feedback!!
PostPosted: Thu Feb 20, 2020 1:44 am    Post subject: Reply with quote
This is the quote from the Help topic "Syssec". Maybe you dont need to divide but only add or sustract some magic value to/from Bascom Time Very Happy
The Return-Value is in the Range of 0 to 2147483647. 2000-01-01 at 00:00:00 starts with 0.
The Function is valid from 2000-01-01 to 2068-01-19 03:14:07. In the year 2068 a LONG – overflow will occur.
Unix time stamp starts 1-1-1970 which will limit the use till 2038.
Bascom time stamp starts 1-1-2000 giving longer working time.
If you wish to convert to NTP which starts at 1.1.1970, which is 30 years earlier, you need to subtract a value of 946684800
BASCOM DATE_TIME = NTP - 946684800
jeremywilson
PostPosted: Fri Feb 21, 2020 6:08 pm    Post subject: Reply with quote
The division is needed since Bascom time is in seconds and Excel time is in days (86,400 seconds per day).
I tried converting the long to double, do the math, then convert to single but too much resolution is still lost.
What's the best way to convert a double into a string (like fusing does for singles)?
Thanks.
PostPosted: Fri Feb 21, 2020 9:52 pm    Post subject: Reply with quote
if you want to convert to something for Excel why dont you use the DATE() and TIME() functions?
seems the best and simplest way to me.
and do not confuse with date$ and time$.
PostPosted: Fri Feb 21, 2020 10:41 pm    Post subject: Reply with quote
Thanks.
It works well with a single by using its available range solely for the decimal places of the Excel time format and the long for its integer part.
jeremywilson
PostPosted: Fri Feb 21, 2020 11:07 pm    Post subject: Reply with quote
I already have the time and date (from DS1308) and is fed into the Bascom date/time functions to get system time. Since our customers (users) are all over the world, my program allows them to choose from many different date/time regional formats to show on the screen. However, I use the system time for data logging to save space. My code logs data into a flash chip that the user can later transfer to the memory token (SD card-compatible). If the date/time aren't formatted properly when exported, the user would have to do some work before being able to plot the data.
Many of the on-screen date formats aren't recognized by Excel as a date. I'm just trying to save code space by not reformatting the date/time during export.
I'll try using the single for the decimals and long for the integer part.
Thanks!
PostPosted: Sat Feb 22, 2020 4:17 pm    Post subject: Reply with quote
As example...
Dim Temp1_long As Long
Dim Temp2_long As Long
Dim Temp3_long As Long
Dim DaySecs_single As Single
Dim predec_str As String * 10
Dim dec_str As String * 10
Dim excel_str As String * 20
Time$ = "22:25:33"
   Temp1_long = syssec()
   Temp2_long = Temp1_long / 86400
   Temp3_long = Temp2_long + 36526
   Temp2_long = Temp2_long * 86400
   Temp1_long = Temp1_long - Temp2_long
   DaySecs_single = Temp1_long / 86400
   dec_str = Fusing(DaySecs_single, "#.######")
   dec_str = Right(dec_str , 7)
   predec_str = Str(Temp3_long)
   excel_str = predec_str + dec_str
   Print excel_str
jeremywilson
PostPosted: Sat Feb 22, 2020 5:14 pm    Post subject: Reply with quote
Thanks for the post, MWS!
Have you tried the code that you posted?
It looks like this line would equal zero:
because:
therefore, Temp2_long = Temp1_long.
jeremywilson
PostPosted: Sat Feb 22, 2020 5:27 pm    Post subject: Reply with quote
I'll try this on Monday. Not sure if the MOD is needed, but it makes the numerator a whole lot smaller.
      Lcl_long2 = Lcl_long / 86400
      Lcl_long2 = Lcl_long2 + 36526                         'integer part
      Lcl_single = Lcl_long Mod 86400
      Lcl_single = Lcl_single / 86400                       'decimal part
      Msg = Fusing(lcl_single , "#.######")
      Msg = Right(msg , 7)
      Msg = Str(lcl_long2) + Msg
(Lcl_long holds the system time)
jeremywilson
PostPosted: Sat Feb 22, 2020 6:22 pm    Post subject: Reply with quote
After playing with a single precision calculator, I realized that the MOD needs to be done as Long.
https://www.binaryconvert.com/convert_float.html
635569066 would change to 635569088 when stored as a 32-bit single (a loss of 22 seconds - not acceptable).
      Lcl_long3 = Lcl_long Mod 86400
      Lcl_single = Lcl_long3
PostPosted: Sat Feb 22, 2020 8:13 pm    Post subject: Reply with quote
If you've missed it, and to answer your false assumption:
this three line sequence with integer division equals a MOD:
'(a)
but in difference to the integrated MOD, it allows to pull out the later used integer part all the same:
'(a):
Your code including MOD does the same division two times by
Lcl_long / 86400
Lcl_long Mod 86400
as a MOD is an integrated integer division/multiplication with difference building.
My code saves one division.
To answer your question:
Sure I did.
Run it in the simulator and copy the output of PRINT into an appropriate formatted Excel cell.
jeremywilson
PostPosted: Sun Feb 23, 2020 3:08 am    Post subject: Reply with quote
Got it! Thanks, MWS!
I wasn't considering the decimals truncation in the integer division.
I like your solution.
