Unable to get DRV2605L working
CBailey
PostPosted: Sat Mar 11, 2023 7:54 am    Post subject: Unable to get DRV2605L working Reply with quote
There's an Adafruit driver for this chip at https://github.com/adafruit/Adafruit_DRV2605_Library
Can this be used with Bascom? If not, has anyone figured this chip out? I've been playing with registers for a while now, so far no output. Not sure if it's my code, a wiring issue, the multiplexer between the microcontroller and the driver, or something else. Hoping to eliminate at least one variable. Thanks!
PostPosted: Sat Mar 11, 2023 10:28 am    Post subject: Reply with quote
Maybe you can show us what you have coded so far.
Do you have pull up resistors on the i2c line's?
What cpu are you using?
CBailey
PostPosted: Sat Mar 11, 2023 5:24 pm    Post subject: Reply with quote
Well, to make things more complicated, I need to drive 8 of these chips. Since they all have the same address, I'm using a TCA9548A. I'm not sure if I'm driving that right either. I didn't add pull up resistors, but my LCD has an I2c adapter on it, and the TCA9548A came on a PCB with some other parts, so I assumed there were pullups in there somewhere. I added code to turn on internal pullups. The LCD is working fine. Below is the code I have. At this point, I'd be happy to set the driver IC to have any kind of output.
' DRV2605L Address is 5A
wait 2 ' This is to give the driver chips a chance to boot up
' We select the correct chip on the TCA9548A
i2cstart
portc.5 = 1
Portc.4 = 1
i2cWByte &H70 ' This is the TCA9548A
i2cWByte &H00 ' This sets output 0 of the TCA9548A
i2cWByte &HB4 ' This writes to the DRV2605L
i2cwbyte &H01 ' This selects register 1
i2cWByte &H00 ' This starts the output
i2cstop
i2cstart
portc.5 = 1
Portc.4 = 1
i2cWByte &H70
i2cWByte &H01
i2cstop
i2cstart
portc.5 = 1
Portc.4 = 1
i2cWByte &H70
i2cWByte &H02
i2cWByte &H0C ' This starts the output
i2cstop
i2cstart
portc.5 = 1
Portc.4 = 1
i2cWByte &H70
i2cWByte &H03
i2cWByte &H5A ' This writes to the DRV2605L
i2cstop
i2cstart
i2cWByte &H70
i2cWByte &H04
i2cwbyte &H01
i2cstop
CBailey
PostPosted: Sat Mar 11, 2023 5:26 pm    Post subject: Reply with quote
Sorry, using an Arduino Nano, ATMega328
CBailey
PostPosted: Sun Mar 12, 2023 6:35 pm    Post subject: Reply with quote
I made a little progress. I was writing to the 7 bit address of the TCA9548A. Once I wrote to the 8 bit address, I saw the DRV2605 driver IC (B4) during an I2C scan. I'm still trying to write to the DRV2605, but still no output. This is what I'm currently using:
i2cstart
portc.5 = 1
Portc.4 = 1
i2cWByte &HE0 ' This selects the TCA9548A
i2cWByte &H00 ' This selects the channel of the TCA9548A
i2cWByte &HB4 ' This selects the DRV2605L
i2cstop
PostPosted: Sun Mar 12, 2023 10:53 pm    Post subject: Reply with quote
I think you need to split the i2c bus selection and attempting to connect to the slave (DRV2605L) into 2 seperate i2c commends. I've used a Pca9546 on a project and had to program in AVR that way.
Something like :-
'Select TCA9548A & Channel
i2cstart
portc.5 = 1
Portc.4 = 1
i2cstop
'Communcate with DRV2605L
i2cstart
i2cstop
I'm not sure what is on C.5&C.4 so I just left it in the code.
In Bascom i2c addresses are 8 bit, with the lowest bit for Read/Write. Usually in the documentation for i2c chips talk about 7 bit addreses without the lowest bit which defines if the command is a read or write.
Ian Dobson
CBailey
PostPosted: Mon Mar 13, 2023 6:27 am    Post subject: Reply with quote
Thanks for the help! I think great minds think alike, as I tried splitting them as well. I also realized I was setting the TCA9548A wrong. I was loading it with 0-7 or 1-8 (Wasn't sure), but figured out it's supposed to be binary. It didn't occur to me the chip could connect more than one output at a time. The PortC.4 and PortC.5 are my I2C bus, making pullups.
This is what I have so far. It doesn't work, as I'm not seeing any output from the drivers. I found some C code and translated it to Basic to program one of the chips, but it still didn't make a difference. I'm guessing at this point all the obvious problems are resolved and now it's just about programming the DRV2605L.
i2cstart ' Channel 1
portc.5 = 1
Portc.4 = 1
i2cWByte &H01 ' This selects channel 1 of the TCA9548A
i2cstop
I2CStart
I2CWbyte 0X5A ' // transmit to device #0x5A
I2CWbyte 0x01' // mode register
I2CWbyte 0x07' // Auto calibration Set
I2CStop ' // stop transmitting
I2CStart
I2CWbyte 0x5A' // transmit to device #0x5A a,b,c
I2CWbyte 0x1A' // set ERM_LRA\FB_BRAKE_FACTOR\LOOP_GAIN
I2CWbyte 0xB6' // LRA 4X Medium
I2CStart
I2CWbyte 0x5A' // transmit to device #0x5A d
I2CWbyte 0x16' // Rated voltage set
I2CWbyte 0x53' //
I2CStart
I2CWbyte 0x5A' // transmit to device #0x5A e
I2CWbyte 0x17' // OD_Clamp set
I2CWbyte 0x6E' //
I2CStop' // stop transmitting
I2CStart
I2CWbyte 0x5A' // transmit to device #0x5A f,k
I2CWbyte 0x1E' // Auto_cal_time & Zc_det_time set
I2CWbyte 0xA0' //
I2CStart
I2CWbyte 0x5A' // transmit to device #0x5A g
I2CWbyte 0x1B' // Drive_time set
I2CWbyte 0x93' //
i2cstart ' Channel 2
portc.5 = 1
Portc.4 = 1
i2cWByte &H02 ' This selects channel 2 of the TCA9548A
i2cstop
i2cstart
i2cstop
i2cstart ' Channel 3
portc.5 = 1
Portc.4 = 1
i2cWByte &H04 ' This selects channel 3 of the TCA9548A
i2cstop
i2cstart
i2cstop
i2cstart ' Channel 4
portc.5 = 1
Portc.4 = 1
i2cWByte &H08 ' This selects channel 4 of the TCA9548A
i2cstop
i2cstart
i2cstop
i2cstart ' Channel 5
portc.5 = 1
Portc.4 = 1
i2cWByte &H10 ' This selects channel 5 of the TCA9548A
i2cstop
i2cstart
i2cwbyte &H01
i2cstop
i2cstart ' Channel 6
portc.5 = 1
Portc.4 = 1
i2cWByte &H20 ' This selects channel 6 of the TCA9548A
i2cstop
i2cstart
i2cWByte &H02 ' This starts the output
i2cwbyte &H7f
i2cstop
i2cstart ' Channel 7
portc.5 = 1
Portc.4 = 1
i2cWByte &H40 ' This selects channel 7 of the TCA9548A
i2cstop
i2cstart
i2cwbyte &H7f
i2cstop
i2cstart ' Channel 8
portc.5 = 1
Portc.4 = 1
i2cWByte &H80 ' This selects channel 8 of the TCA9548A
i2cstop
i2cstart
i2cstop
PostPosted: Mon Mar 13, 2023 8:49 am    Post subject: Reply with quote
Let first check that the i2c bus between the AVR and the TCA9548A actually works with a simple i2c scanner. I hope you have a working serial port
AVR and the TCA9548A bus only
   Print  , "i2c bus=";
  portc.5 = 1
  Portc.4 = 1
   For Temp_byte = 0 To 254 Step 2                          'Scan every even address
      I2cstart                                              'Ping chip
      I2cwbyte Temp_byte                                    'get result
      If Err = 0 Then                                       'err=hw problem
         Print  , Temp_byte ; "," ;                       'no error so device
      End If                                                'ie. no i2c device
      I2cstop                                               'stop bus
      Waitms 1
   Next Temp_byte                                           'loop through each sensor
   Print  ,
AVR and the TCA9548A bus 1
  portc.5 = 1
  Portc.4 = 1
  Print  , "i2c bus=";
  i2cstop
      I2cstart                                              'Ping chip
      I2cstop                                               'stop bus
      Waitms 1
   Print  ,
As I said I've used a Pca9546, here's the function I'm using to select the bus.
Const Pca9546_w = 224
Const Pca9546_r = 225
Const I2c_bus_none = &B0000
Const I2c_bus_zero = &B0001
Const I2c_bus_one = &B0010
Const I2c_bus_two = &B0100
Const I2c_bus_three = &B1000
Const I2c_bus_all = &B1111
Const I2c_bus_used = &B0101
call Select_bus(I2c_bus_zero)
end
Sub Select_bus(byval Bus As Byte)
   Temp_byte = Bus
      I2cstart
      I2cwbyte Pca9546_w
      I2cwbyte Temp_byte
      I2cstop
Ian Dobson
PostPosted: Mon Mar 13, 2023 8:55 am    Post subject: Reply with quote
I would recommend that you use external pullups for all i2c buses, rather than trying to use the AVR's internal pullups.
Ian Dobson
