DCF77 wrong data...
uhrmacher
PostPosted: Tue May 19, 2020 11:30 am    Post subject: DCF77 wrong data... Reply with quote
Hi Folks,
My topic is the DCF-77 application which makes my hair stand up...
A DCF Receiver is connected to PortD.3 and i just looked about the incoming raw data. But not as expected, these data are completely confusing Rolling Eyes me.
I checked with Scope the pulse train in timing and amplitude and both arguments are ok, a clean 5Vpp pulse train without spikes or extra pulses.
Receiving conditions are ok, no interfering sources in the area.
I kindly would ask you to checkout the following logs, the print order is:
print Time(dcf_sec) ; " " ; Date(dcf_day) ; " " ; Bin(dcf_status) ; " " ; Bin(dcf_bits) ; " " ; DCF77Timezone()
I have done tree tests:
1. Test with Inverted = 0,
2. Test with inverted = 1,
3. last log is snipped while running after one hour
DCF is configured as usual:
Config Dcf77 = PinD.3 , Timer = 1 , Inverted = 0 , Check = 2 , Update = 0 , Timer1sec = 0 , Debug = 1 , Gosub = sectic
Config Date = Dmy , Separator = .
Thats it! But look below what confusing data comes and i have really NO clue whats going on, where my possible mistake can be.
I use the ELV module DCF-77 Receiver https://de.elv.com/dcf-empfangsmodul-dcf-2-091610
I thank you in advance for any comments or assistance how to solve. Simplest error could be between the ears Razz so please help!
Arrow Test 1
Terminal log file
Date: 19.05.2020 - 11:52:58
00:00:17 00.00.00 00000001 11111111 0
00:00:18 00.00.00 00000001 11111111 0
00:00:19 00.00.00 00000001 11111111 0
00:00:20 00.00.00 00000001 11111111 3
00:00:21 00.00.00 00000001 11111111 3
00:00:22 00.00.00 00000001 11111111 3
00:00:25 00.00.00 00000001 11011111 3
00:00:26 00.00.00 00000001 11011111 3
00:00:27 00.00.00 00000001 11110111 3
00:81:28 00.00.00 00000000 01010001 3
00:81:29 00.00.00 00000001 01010001 3
00:81:30 00.00.00 00000001 11010100 3
00:81:31 00.00.00 00000001 11101010 3
00:81:32 00.00.00 00000001 11110101 3
00:81:33 00.00.00 00000001 11111010 3
45:81:35 00.00.00 00000001 00101101 3
45:81:36 00.00.00 00000001 00101101 3
45:81:37 00.00.00 00000001 10010110 3
45:81:38 00.00.00 00000001 11100101 3
45:81:40 00.00.00 00000000 11111001 3
45:81:41 45.00.00 00000001 00101101 3
45:81:42 45.00.00 00000001 10010110 3
45:81:43 45.00.00 00000001 11001011 3
45:81:44 45.00.00 00000001 00000111 3
45:81:45 45.00.00 00000001 10000011 3
45:81:46 45.00.00 00000001 10000011 3
45:81:47 45.00.00 00000001 11100000 3
45:81:48 45.00.00 00000000 11110000 3
45:81:49 45.25.00 00000000 00011001 3
45:81:50 45.25.00 00000000 10001100 3
45:81:51 45.25.00 00000001 11000110 3
45:81:53 45.25.00 00000001 11110001 3
45:81:54 45.25.00 00000001 11110001 3
45:81:55 45.25.00 00000001 11111000 3
45:81:56 45.25.00 00000001 11111110 3
45:81:57 45.25.00 00000001 11111110 3
45:81:58 45.25.@5 00000001 10100101 3
45:81:59 45.25.@5 00000001 11101001 3
45:81:61 45.25.@5 00000001 11110100 3
45:81:62 45.25.@5 00000001 11111101 3
45:81:63 45.25.@5 00000001 11111110 3
45:81:64 45.25.@5 00000001 11111111 3
45:81:65 45.25.@5 00000001 11111111 3
45:81:66 45.25.@5 00000001 11111111 3
45:81:67 45.25.@5 00000000 11111111 3
45:81:68 45.25.@5 00000000 11111111 3
45:81:69 45.25.@5 00000001 11111111 3
45:81:70 45.25.@5 00000001 11111111 3
45:81:71 45.25.@5 00000001 11111111 3
45:81:72 45.25.@5 00000001 11111111 3
45:81:73 45.25.@5 00000001 11111111 3
45:81:74 45.25.@5 00000001 11111111 3
Date: 19.05.2020 - 11:53:50
End log file
Arrow Test 2
Configuration with Inverted = 1:
Config Dcf77 = PinD.3 , Timer = 1 , Inverted = 1 , Check = 2 , Update = 0 , Timer1sec = 0 , Debug = 1 , Gosub = sectic
enable IRQ3, run main program
00:00:02 00.00.00 00000001 10000000 0
00:00:03 00.00.00 00000001 11000000 0
00:00:05 00.00.00 00000001 11110000 0
00:00:06 00.00.00 00000001 11111000 0
00:00:08 00.00.00 00000001 11111110 0
00:00:09 00.00.00 00000001 11111111 0
00:00:10 00.00.00 00000001 11111111 0
00:00:11 00.00.00 00000001 11111111 0
00:00:12 00.00.00 00000001 11111111 0
00:00:13 00.00.00 00000001 11111111 0
00:00:14 00.00.00 00000001 11111111 0
00:00:15 00.00.00 00000001 11111111 0
00:00:20 00.00.00 00000001 11111111 0
00:00:22 00.00.00 00000001 01111111 3
00:00:23 00.00.00 00000001 10111111 3
00:00:25 00.00.00 00000001 11101111 3
00:00:26 00.00.00 00000001 11110111 3
00:00:27 00.00.00 00000001 11111011 3
00:00:28 00.00.00 00000001 11111101 3
00:84:29 00.00.00 00000001 01010100 3
00:84:31 00.00.00 00000001 01010101 3
00:84:32 00.00.00 00000001 10101010 3
00:84:33 00.00.00 00000001 11010101 3
00:84:34 00.00.00 00000001 11101010 3
00:84:35 00.00.00 00000001 11110101 3
43:84:36 00.00.00 00000001 00101011 3
43:84:37 00.00.00 00000001 10010101 3
43:84:38 00.00.00 00000001 11001010 3
43:84:40 00.00.00 00000001 11110010 3
43:84:41 00.00.00 00000001 11111001 3
43:84:42 45.00.00 00000001 00101101 3
43:84:43 45.00.00 00000001 10010110 3
43:84:44 45.00.00 00000001 11001011 3
43:84:45 45.00.00 00000001 00000111 3
Arrow Test 3
Longer duration of run shows these readings:
Terminal log file
Date: 19.05.2020 - 11:55:12
43:84:54 45.25.00 00000001 11110001 3
43:84:55 45.25.00 00000001 11111000 3
43:84:56 45.25.00 00000001 11111100 3
43:84:57 45.25.00 00000001 11111110 3
43:84:58 45.25.@5 00000001 10100101 3
43:84:59 45.25.@5 00000001 11010010 3
43:84:60 45.25.@5 00000001 11101001 3
43:84:61 45.25.@5 00000001 11110100 3
43:84:63 45.25.@5 00000001 11111101 3
43:84:64 45.25.@5 00000001 11111110 3
43:84:65 45.25.@5 00000001 11111111 3
43:84:67 45.25.@5 00000001 01111111 3
43:84:68 45.25.@5 00000001 10111111 3
43:84:69 45.25.@5 00000001 11011111 3
43:84:70 45.25.@5 00000001 11101111 3
43:84:71 45.25.@5 00000001 11110111 3
43:84:72 45.25.@5 00000001 11111011 3
43:84:74 45.25.@5 00000001 11111110 3
43:84:75 45.25.@5 00000001 11111111 3
43:84:76 45.25.@5 00000001 11111111 3
43:84:77 45.25.@5 00000001 11111111 3
43:84:78 45.25.@5 00000001 11111111 3
43:84:79 45.25.@5 00000001 11111111 3
43:84:80 45.25.@5 00000001 11111111 3
43:84:81 45.25.@5 00000001 11111111 3
43:84:82 45.25.@5 00000001 11111111 3
43:84:83 45.25.@5 00000001 11111111 3
43:84:85 45.25.@5 00000001 01111111 3
43:84:86 45.25.@5 00000001 10111111 3
43:84:87 45.25.@5 00000001 11011111 3
43:84:88 45.25.@5 00000001 11101111 3
43:84:89 45.25.@5 00000001 11110111 3
43:84:90 45.25.@5 00000001 11111011 3
43:84:91 45.25.@5 00000001 11111101 3
Date: 19.05.2020 - 11:55:46
End log file
[b][color=red](BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.2 )[/b][/color]
