amir.eshraghi@aii1.com
Posted: Fri Jan 31, 2020 1:46 am Post subject: XTEA encryption |
Hi
I would like to know why Bascom XTEA encryption results are different than when we try writing in C language (Such as Arduino, or Mplab- Since I am trying to communicate with another device.)
In Bascom we define key[1] to key [16] , but base on Wiki we have to define key[0] - key[3]. Then I convert 16bit to 4 bit by equaling key[0] = key[1] key[2] key[3] key[4], same thing with a massage. Is that correct?
I am using the same code as https://en.wikipedia.org/wiki/XTEA, all I just add my massage and key and run function.
Bascom Key
Key(1) = &H63
Key(2) = &H3F
Key(3) = &H89
Key(4) = &HB0
Key(5) = &HD5
Key(6) = &HD3
Key(7) = &HAE
Key( = &HC8
Key(9) = &H96
Key(10) = &H37
Key(11) = &HBE
Key(12) = &HA5
Key(13) = &H38
Key(14) = &HC4
Key(15) = &H4B
Key(16) = &H7E
C code Key and massage:
k[4] = {0xB03F8963, 0xC8AED3D5, 0xA5BE3796, 0x7E4BC438};
v[2] = {0xAF8823DC, 0x8F383F3A};
The result I am getting with C code is:
Encrypt: FA4B88ADAAA10BD2
but with Bascom, I am getting
Encrypt: 15B91B456C6367DB
Below is code from Wiki which I use to get the encrypted value in C.
Code: | #include <stdint.h>
/* take 64 bits of data in v[0] and v[1] and 128 bits of key[0] - key[3] */
void encipher(unsigned int num_rounds, uint32_t v[2], uint32_t const key[4]) {
unsigned int i;
uint32_t v0=v[0], v1=v[1], sum=0, delta=0x9E3779B9;
for (i=0; i < num_rounds; i++) {
v0 += (((v1 << 4) ^ (v1 >> 5)) + v1) ^ (sum + key[sum & 3]);
sum += delta;
v1 += (((v0 << 4) ^ (v0 >> 5)) + v0) ^ (sum + key[(sum>>11) & 3]);
v[0]=v0; v[1]=v1;
void decipher(unsigned int num_rounds, uint32_t v[2], uint32_t const key[4]) {
unsigned int i;
uint32_t v0=v[0], v1=v[1], delta=0x9E3779B9, sum=delta*num_rounds;
v1 -= (((v0 << 4) ^ (v0 >> 5)) + v0) ^ (sum + key[(sum>>11) & 3]);
sum -= delta;
v0 -= (((v1 << 4) ^ (v1 >> 5)) + v1) ^ (sum + key[sum & 3]);
v[0]=v0; v[1]=v1;
Thank you
(BASCOM-AVR version : 2.0.8.2 ) |
Posted: Fri Jan 31, 2020 2:25 pm Post subject: Re: XTEA encryption |
amir.eshraghi@aii1.com wrote: |
Key(1) = &H63
Key(2) = &H3F
Key(3) = &H89
Key(4) = &HB0 |
After these assignments the bytes in SRam follow this order:
h63 h3F h89 hB0
k[4] = {0xB03F8963, ... , ... , ...};
In this case the byte order in SRam is:
h63 h89 h3F hB0
Do you notice the difference? |
Posted: Fri Jan 31, 2020 5:18 pm Post subject: XTEA encryption |
Do you mean the typo, I put the 89 and 3F backward which I fixed and still not getting the same encryption.
below is the Arduino code I wrote to double-check the encryption and not getting same result.
Encrypt: 3648050414A63EC0
Decrypt: 8F383F3AAF8823DC
Code: |
uint32_t key[4] = {0xB0893F63, 0xC8AED3D5, 0xA5BE3796, 0x7E4BC438};
// B0893F63 C8AED3D5 A5BE3796 7E4BC438
uint32_t v[2] = {0xAF8823DC, 0x8F383F3A};
// AF8823DC 8F383F3A
void setup()
Serial.begin(9600);
Serial.print("key: ");
Serial.print(key[3], HEX);
Serial.print(key[2], HEX);
Serial.print(key[1], HEX);
Serial.println(key[0], HEX);
Serial.print("Data: ");
Serial.print(v[1], HEX);
Serial.println(v[0], HEX);
encipher(32,v,key);
Serial.print("Encrypt: ");
decipher(32,v,key);
Serial.print("Decrypt: ");
void loop()
unsigned int i;
sum += delta;
v[0]=v0; v[1]=v1;
unsigned int i;
sum -= delta;
v[0]=v0; v[1]=v1;
Thanks |
Posted: Fri Jan 31, 2020 7:33 pm Post subject: Re: XTEA encryption |
amir.eshraghi@aii1.com wrote: | Do you mean the typo, I put the 89 and 3F |
For me it was actual data, otherwise you wouldn't put it here, would you?
I see no Bascom code to test and I'm not interested to set up arduino/c-code projects.
How would anyone know, whether you have more 'typos' in your code?
If you ask for help, then do your part and show a Bascom sample which shows the effect and is simple, cleaned up and ready to run. |
Posted: Fri Jan 31, 2020 7:51 pm Post subject: XTEA encryption |
The reason I include the other code was to show how I am compering
Below is my Bascom code
Code: |
Key(1) = &H63
Key(2) = &H3F
Key(3) = &H89
Key(4) = &HB0
Key(5) = &HD5
Key(6) = &HD3
Key(7) = &HAE
Key(8) = &HC8
Key(9) = &H96
Key(10) = &H37
Key(11) = &HBE
Key(12) = &HA5
Key(13) = &H38
Key(14) = &HC4
Key(15) = &H4B
Key(16) = &H7E
Esn_array(1) = &HDC
Esn_array(2) = &H23
Esn_array(3) = &H88
Esn_array(4) = &HAF
Esn_array(5) = &H3A
Esn_array(6) = &H3F
Esn_array(7) = &H38
Esn_array(8) = &H8F
Xteaencode Esn_array(1) , Key(1) , 8
Posted: Fri Jan 31, 2020 7:59 pm Post subject: |
This can't be your code, as it does not contain variable, processor, clock or stack declaration.
You can play stupid, but then you'll be on your own. |
Posted: Sat Feb 01, 2020 11:07 am Post subject: |
The sole purpose of the XTEA routines in BASCOM is that you can encrypt and decrypt data. you can also automatic encrypt for a boot loader.
The goal was not to make it work for all different TEA variations that exist.
The asm code was based on some delphi code. and this code had memory order reversed. so while still XTEA this makes it harder to share with other platform code.
For this reason another xtea library is included with bascom. if you read the help you can find this info :
When you use other tools to encode your data, you will find differences because of memory order. You can use the xtea2.lib for using the same memory order.
Include it in your code like : $LIB "xtea2.lib"
It is not the default since once projects are compiled with the other versions (boot loader and code) it would break compatibility. _________________ Mark |
