MCSbootloader and Tiny45/Tiny85
PostPosted: Wed Jul 31, 2024 10:39 am    Post subject: MCSbootloader and Tiny45/Tiny85 Reply with quote
Hello.
Tiny85 family dont have dedicated bootloader area. They have a SELFPRGEN fusebit that only enable SPM instruction.
I was curious if one have enough ROM left that MCSbootloader can be used.
So I modify bootloader code. I remove eeprom handling and add software serial.
I burn that bootloader as a main application at &H00 address and enable SELFPRGEN FuseBit.
Then I made a "proper target" application with $loader = &H260 , Bootonly so I get binary that should even service jumps.
Address results from bootloader have ~1184B. Pages they have 64B so I must use 19 pages and app starts after that.
...and everything working like a charm I can flash that uC multiple times with MCSbootloader and FT232RL with DTR signal attached into Reset pin.
$regfile = "attiny85.dat"
$hwstack = 32
$swstack = 4
$framesize = 24
'$reduceivr
'$noramclear
Config Clockdiv = 1
$projecttime = 52
Open "COMB.0:38400,8,n,1" For Output As #1                  'TX-MOSI PIN5
Open "COMB.1:38400,8,n,1" For Input As #2                   'RX-MISO PIN6
Const Maxwordbit = 5                                        'Z5 is maximum bit
Const Maxword =(2 ^ Maxwordbit) * 2
'Dim the used variables
Dim Bstatus As Byte , Bretries As Byte , Bblock As Byte , Bblocklocal As Byte
Dim J As Byte , Spmcrval As Byte                            ' self program command byte value
Dim Z As Long                                               'this is the Z pointer word
Dim Vl As Byte , Vh As Byte                                 ' these bytes are used for the data values
Dim Wrd As Word , Page As Word                              'these vars contain the page and word address
Dim Bkind As Byte , Bstarted As Byte
'19pages x 64B=1216B |/2=608
Page = 19
Const _app = 608
'some constants used in serial com
Const Nak = &H15
Const Ack = &H06
'Const Can = &H18
$timeout = 1000000                                          'we use a timeout
Bretries = 5                                                'we try 5 times
Testfor123:
Bstatus = Waitkey(#2)                                       'wait for the loader to send a byte
Print #1 , Chr(bstatus);
If Bstatus = 123 Then                                       'did we received value 123 ?
   Bkind = 0                                                'normal flash loader
   Goto Loader
Elseif Bstatus <> 0 Then
   Decr Bretries
   If Bretries <> 0 Then Goto Testfor123                    'we test again
Goto _app                                                   'goto the normal reset vector at address 0
'this is the loader routine. It is a Xmodem-checksum reception routine
Loader:
  Loop Until Bstatus = 0
  If Bkind = 0 Then
     Spmcrval = 3 : Gosub Do_spm                            ' erase  the first page
     Spmcrval = 17 : Gosub Do_spm                           ' re-enable page
Bretries = 10                                               'number of retries
  Bblocklocal = 1
  Bstarted = 0                                              ' we were not started yet
  Csum = 0                                                  'checksum is 0 when we start
  Print #1 , Chr(nak);                                      ' firt time send a nack
    Bstatus = Waitkey(#2)                                   'wait for statuse byte
    Select Case Bstatus
       Case 1:                                              ' start of heading, PC is ready to send
            Csum = 1                                        'checksum is 1
            Bblock = Waitkey(#2) : Csum = Csum + Bblock     'get block
            Bcsum1 = Waitkey(#2) : Csum = Csum + Bcsum1     'get checksum first byte
            For J = 1 To 128                                'get 128 bytes
              Buf(j) = Waitkey(#2) : Csum = Csum + Buf(j)
            Bcsum2 = Waitkey(#2)                            'get second checksum byte
            If Bblocklocal = Bblock Then                    'are the blocks the same?
               If Bcsum2 = Csum Then                        'is the checksum the same?
                  Gosub Writepage                           'yes go write the page
                  Print #1 , Chr(ack);                      'acknowledge
                  Incr Bblocklocal                          'increase local block count
               Else                                         'no match so send nak
               Print #1 , Chr(nak);                         'blocks do not match
       Case 4:                                              ' end of transmission , file is transmitted
             If Wrd > 0 And Bkind = 0 Then                  'if there was something left in the page
                 Wrd = 0                                    'Z pointer needs wrd to be 0
                 Spmcrval = 5 : Gosub Do_spm                'write page
            '  Waitms 100                                   ' OPTIONAL REMARK THIS IF THE DTR SIGNAL ARRIVES TO EARLY
             Print #1 , Chr(ack);                           ' send ack and ready
             Waitms 20
             Goto _app                                      ' start new program
       Case &H18:                                           ' PC aborts transmission
             Goto _app                                      ' ready
       Case 123 : Exit Do                                   'was probably still in the buffer
       Case Else
          Exit Do                                           ' no valid data
  If Bretries > 0 Then                                      'attempte left?
     Waitms 1000
     Decr Bretries                                          'decrease attempts
     Goto _app                                              'reset chip
'write one or more pages
Writepage:
 If Bkind = 0 Then
   For J = 1 To 128 Step 2                                  'we write 2 bytes into a page
      Vl = Buf(j) : Vh = Buf(j + 1)                         'get Low and High bytes
      !lds r0, {vl}                                         'store them into r0 and r1 registers
      !lds r1, {vh}
      Spmcrval = 1 : Gosub Do_spm                           'write value into page at word address
      Wrd = Wrd + 2                                         ' word address increases with 2 because LS bit of Z is not used
      If Wrd = Maxword Then                                 ' page is full
          Page = Page + 1                                   'next page
          Spmcrval = 3 : Gosub Do_spm                       ' erase  next page
Do_spm:
  Bitwait Spmcsr.0 , Reset                                  ' check for previous SPM complete
  Z = Page                                                  'make equal to page
  Shift Z , Left , Maxwordshift                             'shift to proper place
  Z = Z + Wrd                                               'add word
  !lds r30,{Z}
  !lds r31,{Z+1}
  Spmcsr = Spmcrval                                         'assign register
  !spm                                                      'this is an asm instruction
  Nop
  Nop
Simple test code:
$hwstack = 32
$swstack = 4
$framesize = 24
$loader = &H260 , Bootonly                                  'for proper addressing
Led Alias Portb.3 : Config Led = Output
 Gosub Jump_sub
 Waitms 500
Jump_sub:
 Toggle Led
Check B-Flash -my MCS bootloader app for Android (updated)
jaceklx
PostPosted: Sat Aug 03, 2024 9:55 am    Post subject: MCSbootloader and Tiny45/Tiny85 Reply with quote
Hi there,
Thank you for sharing this, of course it is because of my generosity Wink .
Everything works well but bootloader is hanging time to time due to below code :
Loader:
Since software uart is used there is no buffer and usually uart lines are already cleaned before we get there . Replacing "waitkey" with "inkey" fix it.
This my first post on the forum so i would like to thank you all for great community and the bascom language - simple and effective.
impossible is just a word
