Where might I find the MRU List?
KenHorse
PostPosted: Tue Dec 31, 2019 1:18 am    Post subject: Where might I find the MRU List? Reply with quote
It doesn't seem to be in the Registry nor in the Bascom root directory
theo64
PostPosted: Tue Dec 31, 2019 2:28 pm    Post subject: Reply with quote
from history.txt file:
2082
- log files are stored user\appdata\roaming\mcs electronics
- xml settings file is also located in this folder
- xml settings file has a new name with the version in it : bascavr2082.xml
Always look for the best and expect the worst
KenHorse
PostPosted: Tue Dec 31, 2019 7:35 pm    Post subject: Reply with quote
Nope, it doesn't seem the MRU is in any of the xml files. In fact, if I delete the file reference entries in the xml files, the MRU remains and is written back to the xml files
PostPosted: Tue Dec 31, 2019 7:56 pm    Post subject: Reply with quote
If Bascom starts then read XML into the RAM. If you change some options then they will be written into the XML file on the Bascom closing.
So if you want to manipulate on this XML file then you must first shutdown Bascom...
KenHorse
PostPosted: Tue Dec 31, 2019 8:17 pm    Post subject: Reply with quote
Roger that, and I did as I (rightly) assumed the xml files are read in at start up
