Soft Serial UART hang after reconnect
acjacques
PostPosted: Fri Nov 22, 2019 3:17 pm    Post subject: Soft Serial UART hang after reconnect Reply with quote
My 328p with bellow code works fine to receiving the serial input but if there are a momentary disconnection from this input the processor hangs then only reconnecting after a reset.
I have tryed the timeout but it seems does not work.
Obs. The input pin PORTC.1 have a 1k series resistor. I dont believe this could matter in this issue.
Thanks for any help.
'============================code==================
$regfile = "m328pdef.dat"
$crystal = 16000000
$baud = 115200
$hwstack = 32
$swstack = 16
$framesize = 50
$lib "serin.lib"
Dim serin_timeout as long
Dim S As String * 8
Dim I As Word
do
serin_timeout = 50000
Serin S , 1 , PortC , 1 , 9600 , 0 , 8 , 1 'testada a saida digital no pino analogo
I = Val(s) 'isola só os numeros da string transformando para numerico
S = Str(i) 'numérico de volta para string
S = Format(s , "0000") 'formata a string
S = S + " mm" 'soma a string
Print S
Waitms 50
loop
Evert :-)
PostPosted: Fri Nov 22, 2019 11:07 pm    Post subject: Reply with quote
The serin is set as input, so if the signal is momentary disconnected then this input pickup noise etc. and will do strange things.
Try 10K pulldown resistor to hold the serin in known active state when the signal disconnect.
PostPosted: Sat Nov 23, 2019 6:22 am    Post subject: Reply with quote
Mega328P are armed with PCINT on the every pin. You can start timer for "one or more byte long for the given baudrate" and somehow handle the timeout.
