ERROR - CODE EXPLORE
Printpix52
PostPosted: Mon Nov 18, 2019 7:12 pm    Post subject: ERROR - CODE EXPLORE Reply with quote
Hello all!!
When I write 16 * 2 I get an error.
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.2 )
Printpix52
PostPosted: Mon Nov 18, 2019 7:13 pm    Post subject: Reply with quote
When I write 16x2 error disappeared and corrected
Very Happy Very Happy Very Happy Very Happy
Printpix52
PostPosted: Mon Nov 18, 2019 7:17 pm    Post subject: Reply with quote
Now the other program had them working well and why does it make me wrong? It doesn't let me study well !!
Sad Sad Sad Confused Confused Confused Shocked Shocked Shocked
Printpix52
PostPosted: Mon Nov 18, 2019 7:24 pm    Post subject: Reply with quote
I have compiled today with a different program with version 2.0.8.2 and the problems started and the previous version there was no problem, something very strange 2.0.8.2 .....
Shocked Shocked Shocked Shocked
PostPosted: Mon Nov 18, 2019 7:51 pm    Post subject: Reply with quote
Just compile the code and see what Errors the Compiler Displays.
The code Explorer/Errors is very sensitive and Displays alot of false positives.
Ian Dobson
http://www.planet-ian.com
PostPosted: Mon Nov 18, 2019 7:54 pm    Post subject: Reply with quote
If you code like you write, then I understand why your compiler is going nuts.
Trying to find out a meaning by splitting the sentence:
You have compiled with another Bascom 2.0.8.2 on a different computer?
You have compiled different code with the same Bascom 2.0.8.2 on the same computer?
What problems started?
Does that mean none of your problems, even the unspoken ones, existed in version 2.0.8.1?
PostPosted: Mon Nov 18, 2019 8:01 pm    Post subject: Reply with quote
you should start reading the help and the history.txt
And it will also help if you read the forum rules.
You hijack posts, you post unrelated things without actual questions.
This is not a blog where you can dump your stuff.
This is a forum. And when you want help, add sufficient info and be clear about the problem. pictures are a great way to show what you mean but we can not extract code from pictures so you need to include it.
PostPosted: Mon Nov 18, 2019 10:40 pm    Post subject: Reply with quote
Try use CTRL+SPACE for proper syntax. After some word make space, eual sign =, next space and then call for hint CTRL+SPACE
Printpix52
PostPosted: Tue Nov 19, 2019 12:51 am    Post subject: Reply with quote
hello all!
i.dobson:
There is no error Very Happy
i.dobson:
It is the first time that active code explore is very sensitive. Very Happy
albertsm:
Sorry and excuse me I was testing the issue of fellow EDC and there was a doubt I stopped and it worked well in 2.8.8.2
EDC:
Clarified and understood thank you very much everyone. Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
Printpix52
PostPosted: Tue Nov 19, 2019 12:58 am    Post subject: Reply with quote
Problem solved and thank you very much. Very Happy Very Happy Very Happy
PostPosted: Tue Nov 19, 2019 1:42 pm    Post subject: Reply with quote
EDC. Like the clear way you explain it.
