Reading data trough RS232 interface
matjazs
PostPosted: Wed Oct 30, 2019 1:06 pm    Post subject: Reading data trough RS232 interface Reply with quote
I have ATMEGA128A3U and on first port (COM1) read TXT data.
Would someone have an idea, how read this data?
First character is space, on the end of rows is CRLF.
chann rs  dBm MCC MNC BCC  C1  C2
 122  39  -71 293  41   5  40  40
 112  34  -76 293  41   0  31  31
 116  34  -76 293  41   6  35  35
 118  33  -77 293  41   5  34  34
 113  32  -78 293  41   7  29  29
 663  31  -79 293  41   1  26  26
OK
Number of rows is not constant but it is depend of situation, maximum is 10.
For me it will be good solution, that I can read each rows.
I tryed with Ischarwaiting() function and wait for "space", but it doesn't work.
This table appear each second, between this time uC read from the same COM port other data in TXT format.
With other data I don't have any problems, because each rows start with special character f.e. * or +.
Best regards M.
PostPosted: Wed Oct 30, 2019 1:51 pm    Post subject: Reply with quote
Space is a character with value 32 so rest of the values also comes like a string with these spaces like you presents?
Const Max_len = 10
Dim Mystr(10) As String * Max_len
Dim Char As Byte , Idx As Byte , Row As Byte
Dim Got_msg As Byte , Receiving As Byte , Err_flag As Byte
Open "COM1:" For Binary As #1
 If 0 < Ischarwaiting(#1) Then
   Char = Waitkey(#1)
   Select Case Char
    Case 32                                                 'space
     If Receiving = 0 Then                                  'first space
      Receiving = 1
      Row = 1 : Idx = 0
     Else                                                   'next space
      Incr Row
       If Row > 10 Then
        Err_flag = 1 : Row = 1                              'this is probably error because no enter after 10 msg`s
    Case 13                                                 'simply ignore, swallow enter
    Case 10                                                 'LF sign->Parse new data
      Got_msg = 1
    Case Else
     If Receiving = 1 Then                                  'wait for first space for synchro
      Mystr(row) = Mystr(row) + Chr(char)
       Incr Idx
         If Idx = Max_len Then
          Err_flag = 1 : Incr Row                           'error cause msg is too big
   End Select
   If Got_msg = 1 Then                                      'parse new msg
    If Err_flag = 0 Then
      'here you have array(row) of strings
    Else
      'there you can judge if you want to parse corrupted data
     Err_flag = 0
    Got_msg = 0 : Receiving = 0                             'we wait for new start after first space Wink
matjazs
PostPosted: Tue Nov 12, 2019 7:53 am    Post subject: Reply with quote
EDC Than'k you very much. You are realy expert.
I tested this code and works OK. Otherwise all spaces in row disappear, but this is not a big problem.
Troubless appear when I recieve other text on the same COM port aproximately each second.
On this COM port recive also other text information with first character f.e. "+" or "*", or "$", but sometimes text start also with space.
How make solution with this mix of text is for me big problem Smile
Best regards, Matjaz
PostPosted: Tue Nov 12, 2019 8:44 am    Post subject: Reply with quote
If every message ends with CR LF then this can be quite simple. I dont even know why I dont saw this opportunity in the previous code Very Happy
There is many, many another ways to parse data.
Const Max_msg_len = 100
Dim New_msg As String * Max_msg_len , Mystr(10) As String * 10
Dim Char As Byte , Idx As Byte , Got_msg As Byte , Tststr As String * 1
  Char = Waitkey(#1)
   Select Case Char
    Case 10 : Got_msg = 1
    Case 13                                                 'swallow/ignore
    Case Else
     New_msg = New_msg + Chr(char)
     Incr Idx : If Idx >= Max_msg_len Then Got_msg = 1      'force parsing or cancel msg. becaause it is too long
   End Select
    If Got_msg = 1 Then
      Tststr = Left(new_msg , 1)                            'take and check first character of the msg.
      Select Case Tststr
       Case " "                                             'space
         Idx = Split(new_msg , Mystr(1) , " ")              'split by spaces into the rows
       Case "+"
       Case "$"
       Case "*"
      End Select
     Got_msg = 0 : Idx = 0 : New_msg = "" 'prepare for new msg.
