Bascom AVR version history (When PWM was inverted)?
Jerry
PostPosted: Fri Nov 01, 2019 1:03 pm    Post subject: Bascom AVR version history (When PWM was inverted)? Reply with quote
I have some very old code to update. There was a change in Bascom AVR at one point to the "config PWM" function, where the PWM output was inverted when using count up/count down. I have searched all the history files I have and can't find at what Bascom version this PWM change occured. Does anyone know what version of Bascom made this change?
Thank you,
Jerry :roll:
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.8.2 )
Jerry
PostPosted: Fri Nov 01, 2019 1:33 pm    Post subject: Reply with quote
I just Downloaded latest version of Bascom AVR and the history includes all version changes. Thank you Mark, that's fantastic. I will search through that to find my answer.
Please disregard my question.
Jerry
Jerry
PostPosted: Fri Nov 01, 2019 1:39 pm    Post subject: Reply with quote
It occurred in Bascom AVR 2.0.7.1. just in case anyone else can use the information here it is.
############################ IMPORTANT ####################################################################
- compare CLEAR UP and compare CLEAR DOWN, were reversed. This mean they would select the reverse mode.
if you use timers in PWM mode with CLEAR UP/DOWN mode, you might need to check it (depending on your app)
