The ultimate display terminal ?
Goto page Previous  1, 2, 3, 4
Paulvk
PostPosted: Thu Nov 07, 2019 10:25 am    Post subject: Reply with quote
OK I am working out how to use the nextion.
Have made a lot of bit maps
Note the yellow dots are animated and move around the paths
showing flow of power from solar to load , to or from battery and from grid to battery and load.
Will maybe look at 4D systems when I work this one out.
Paulvk
PostPosted: Mon Nov 11, 2019 4:01 am    Post subject: Reply with quote
More progress :
Wanting to test my creation on nextion but not having to write bascom code
I used Realterm terminal program
you can send the value to the object on the screen
and then send the 255 255 255
all in the send screen of Realterm
or it will send a file to the screen
Also it is a good idea to get a Serial RS232 Serial Port to TTL Converter Module
off E-bay this enables the powering and control from a PC for testing
Regards Paul
PostPosted: Mon Nov 11, 2019 2:36 pm    Post subject: Reply with quote
It looks great. So maybe that is the way to go.
Paulvk
PostPosted: Thu Nov 14, 2019 12:38 pm    Post subject: Reply with quote
Here I have used the slider object to do animation
https://youtu.be/tSEj0gExWAI
Regards Paul
PostPosted: Fri Nov 15, 2019 11:40 am    Post subject: Reply with quote
that is a clever usage of the slider. Very Happy
Paulvk
PostPosted: Sat Nov 16, 2019 8:21 am    Post subject: Reply with quote
Now slider and picture animation for full effect.
https://youtu.be/irECmmy1-ds
The battery can be as it is charging
Or shown as a state off charge
The battery slider can be reversed showing it discharging
The directions of charge in the circle can also be reversed
When I get a bit more familiar with the nextion coding I will start a blog
and go through it step by step with the code
Then program an avr with bascom to control the animation
Note I am only using windows paint to re-do the bitmaps
Regards Paul
Pikczu
PostPosted: Sat Nov 16, 2019 12:43 pm    Post subject: Reply with quote
Hi Paul,
Is there any chance to show video of the display itself and graphic on it?
As a comparison, I can make a similar layout with D4 systems and post the video.
Regards
Pikczu
Paulvk
PostPosted: Tue Nov 19, 2019 11:12 pm    Post subject: Reply with quote
I will try and make a video
this will take time I must learn how to do it with my tablet
I do not have a mobile phone as I have no need for it
The two I posted here are my first.
More on the Nextion display.
I am working with (learning) how to use the instruction code
its not like bascom more like C which I dislike
its the reason basic was invented.
You can do pop up screens
example: pop up a keyboard to enter data/numbers
Regards Paul
Paulvk
PostPosted: Thu Nov 28, 2019 12:41 pm    Post subject: Reply with quote
Started a blog in the blog section on the Nextion display
Regards Paul
Page 4 of 4
