Posted: Fri Sep 27, 2019 2:20 pm Post subject: Bascom ADXL345 via I²C -no response by device
Dear all,
I do my first steps with I²C on Bascom so it may be that I do not see the trees because of the forest.
I want to run a ADXL345 accelerometer via I²C.
The accelerometer is on a breakout board installed on a breadboard. MCU runs on Arduino UNO R3 board.
SCA,SCL are pulled HIGH to VDD=5V via 2k4 resistors.
SDO , which to my opinion is the AltAddress pin is fixed to VDD.
This has now influence on the codes for reading and writing to registers.
As I understand the datasheet the 7 bit slave address is 0011101.
To complete it to a byte the LSBit is attached to the right hand side. 1 for read ; 0 for write
So the command after the start announcing a writing access is 00111010 (3A)
So the command after the start announcing a reading access is 00111011 (3B)
I also integrated a bus scanner in the program.
No slave is found by the scan.
The code is attached.
Please be so kind to give me some advice.
Best regards
Christian
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.2 )
