Bascom ADXL345 via I²C -no response by device
autoguider
PostPosted: Fri Sep 27, 2019 2:20 pm    Post subject: Bascom ADXL345 via I²C -no response by device Reply with quote
Dear all,
I do my first steps with I²C on Bascom so it may be that I do not see the trees because of the forest.
I want to run a ADXL345 accelerometer via I²C.
The accelerometer is on a breakout board installed on a breadboard. MCU runs on Arduino UNO R3 board.
SCA,SCL are pulled HIGH to VDD=5V via 2k4 resistors.
SDO , which to my opinion is the AltAddress pin is fixed to VDD.
This has now influence on the codes for reading and writing to registers.
As I understand the datasheet the 7 bit slave address is 0011101.
To complete it to a byte the LSBit is attached to the right hand side. 1 for read ; 0 for write
So the command after the start announcing a writing access is 00111010 (3A)
So the command after the start announcing a reading access is 00111011 (3B)
I also integrated a bus scanner in the program.
No slave is found by the scan.
The code is attached.
Please be so kind to give me some advice.
Christian
PostPosted: Fri Sep 27, 2019 6:10 pm    Post subject: Reply with quote
There are some hits doing a forum search for ADXL345.
PostPosted: Fri Sep 27, 2019 7:47 pm    Post subject: Reply with quote
I've had a quick look at your code and I can't see where you configure and initalise the i2c bus.
You Need to include something like this to Setup the i2c bus before you use it:
Config Sda = portc.1                                        'setup I2C bus
Config Scl = portc.0
Config I2cdelay = 10                                        '100KHz i2c bus
I2cinit                                                     'Initalise i2c bus
Ian Dobson
