Atmel-ICE Porgrammer
Tomek
PostPosted: Wed Jan 07, 2015 10:23 am    Post subject: Atmel-ICE Porgrammer Reply with quote
Hello!
I want to buy a new Atmel's programmer. It's call Atmel-ICE. And I have a question.
Atmel ICE here: http://www.atmel.com/webdoc/atmelice/index.html
Is Bascom support this programmer? I was looking in BASCOM options of programmer, and there wasn't this hardware.
If not, when it could be?
I have Bascom 2.0.7.8 and 2.0.7.7
Best Regards!
Tomek
ivangel
PostPosted: Thu Jan 08, 2015 12:34 pm    Post subject: Reply with quote
because on the forum the principle of responding in English, I answer that Bascom supports the programmer (I have it myself), but in console mode, I can specify parameters. This requires installation of AVR-Studio version 6.2
Pozdrawiam
www.BlasterON.pl
Tomek
PostPosted: Fri Jan 09, 2015 4:51 pm    Post subject: Reply with quote
Pozdrawiam
Thank you very much for your answer/
Which type of programmer have you set in Bascom? AVR ISP mkII? This programmer is realy very fast just like tell's in describes?
I have AVR ISP mkII (original ATMEL version) and I used AtmelStudio to install and upgrade my programmer and something I'm using it to tests...
Pozdrawiam!
ivangel
PostPosted: Thu Jan 15, 2015 9:22 am    Post subject: Reply with quote
Atmel ICE. AVR Studio 6.2 supporting this programer. This is the command line:
"C:\Program Files (x86)\Atmel\Atmel Studio 6.2\atbackend\atprogram.exe"
-t atmelice -i jtag -d {CHIP} program -c -fl --verify -f {FILE} info
, you must check Use HEX file
As you see, in my is used jtag type of interface, change to pdi if you use PDI interface.
Pozdrawiam
P.S. I forgot to add: you must chose External programer...
www.BlasterON.pl
O-Family
PostPosted: Wed May 17, 2017 1:10 am    Post subject: Reply with quote
Programmer [AVRISPmkII] seems to be discontinued.
The successor is [Atmel - ICE], but writing from the command line is hard to use.
I hope for BASCOM's IDE urgently!
PostPosted: Fri May 19, 2017 12:33 pm    Post subject: Reply with quote
you can buy them on ebay. or buy a clone, they work ok too.
i have been busy with the JTAG ICE3. (the older model however). They changed the protocol so now it is a HID device. I hope the latest also called jtag ice3 is compatible. I hope that microchip will have a smarter approach.
While i have written 99% of the code now, i am debugging to track a problem. For some reason i can not read the signature.
When i am done i will make it available to you so you can test it.
O-Family
PostPosted: Sat May 20, 2017 12:42 am    Post subject: Reply with quote
Hi Mark,
Yes, I know the existence of a clone of [AVRISPmkII].
However, being a genuine product of Atmel(microchip) is important for embedded products of AVR.
Many users were impressed when BASCOM completed IDE of [AVRISPmkII].
By all means, please also correspond to [Atmel-ICE]!
I have [Atmel-ICE], so it is possible to check the operation with SLA.
Best regards
PostPosted: Sat May 20, 2017 12:38 pm    Post subject: Reply with quote
there exist real ones too on ebay.
i also use the genuine ones. but since users buy clones, i have them too. and they work equally well, but... they requires special firmware for libusb.
since the new tiny platform also needs yet another programmer i thought it would be best to add jtag ice3. jtag first btw.
O-Family
PostPosted: Sat May 20, 2017 4:29 pm    Post subject: Reply with quote
Of course, I also have a real [AVRISPmkII].
However, new AVR users are wondering which one to choose.
Where is it?
I searched, it became a premier item and it is very expensive and traded.
PostPosted: Mon May 22, 2017 2:01 pm    Post subject: Reply with quote
I had a look. I bought it a year ago. It is not available anymore. When i do a new search i see 1 genuine programmer. The others are compliant/fake.
svein.berg@ccd.as
PostPosted: Tue Aug 15, 2017 4:53 pm    Post subject: Reply with quote
Hi.
Any news about when we can expect to use the Atmel-Ice direct ffrom Bascom??
Csuhás
PostPosted: Tue Sep 03, 2019 2:49 pm    Post subject: ATMEL ICE Reply with quote
As an ATMEL-ICE owner, I also look forward to supporting the device.
