uga237
Posted: Sun Aug 11, 2019 4:12 pm Post subject: dooble and RAMPZ? |
No set RAMPZ for test Double with constant from CPU ROM(Flash)
$regfile = "xm256a3udef.dat"
$crystal = 32000000
Config Submode = New
$hwstack = 500
$swstack = 500
$framesize = 500
!cli
Dim D As Double
D = 0
Dim S As Single
S = 0
If D <> 0 Then
D = 1
If S <> 0 Then
S = 1
Stop
Sub: set RAMPZ
000001C2 0b.bf OUT 0x3B,R16
000001C3 0f.91 POP R16
000001C4 88.94 CLC
000001C5 08.95 RET
000001C6 0f.93 PUSH R16
000001C7 00.27 CLR R16
000001C8 f9.cf RJMP PC-0x0006
Init double and single:
D = 0
00000135 a9.e2 LDI R26,0x29
00000136 b0.e2 LDI R27,0x20
D = 0
00000137 ea.e5 LDI R30,0x5A
00000138 f4.e0 LDI R31,0x04
D = 0
00000139 0e.94.c6.01 CALL 0x000001C6 Call set RAMPZ - OK
D = 0
0000013B 0e.94.fb.01 CALL 0x000001FB Set to 0(double 8 bytes) from ROM(ELPM)
S = 0
0000013D a1.e3 LDI R26,0x31
0000013E b0.e2 LDI R27,0x20
S = 0
0000013F ea.e5 LDI R30,0x5A
00000140 f4.e0 LDI R31,0x04
S = 0
00000141 0e.94.c6.01 CALL 0x000001C6 Call set RAMPZ - OK
S = 0
00000143 0e.94.b3.01 CALL 0x000001B3 Set to 0(single 4 bytes) from ROM(ELPM)
Test single:
If S <> 0 Then
00000156 0e.94.bb.01 CALL 0x000001BB
If S <> 0 Then
00000158 e1.e3 LDI R30,0x31
00000159 f0.e2 LDI R31,0x20
If S <> 0 Then
0000015A 0e.94.1b.02 CALL 0x0000021B
If S <> 0 Then
0000015C ea.e5 LDI R30,0x5A
0000015D f4.e0 LDI R31,0x04
If S <> 0 Then
0000015E 0e.94.c6.01 CALL 0x000001C6 Call set RAMPZ - OK
If S <> 0 Then
00000160 0e.94.20.02 CALL 0x00000220 Get 0(single 4 bytes) from ROM (ELPM)
If S <> 0 Then
00000162 0e.94.02.02 CALL 0x00000202 Compare
If S <> 0 Then
00000164 11.f4 BRNE PC+0x03
00000165 0c.94.6f.01 JMP 0x0000016F
S = 1
00000167 a1.e3 LDI R26,0x31
00000168 b0.e2 LDI R27,0x20
S = 1
00000169 ea.e6 LDI R30,0x6A
0000016A f4.e0 LDI R31,0x04
S = 1
0000016B 0e.94.c6.01 CALL 0x000001C6 Call set RAMPZ - OK
S = 1
0000016D 0e.94.b3.01 CALL 0x000001B3 Set to 1(single 4 bytes) from ROM(ELPM)
And now Test double:
If D <> 0 Then
00000145 a9.e2 LDI R26,0x29
00000146 b0.e2 LDI R27,0x20
If D <> 0 Then
00000147 ea.e5 LDI R30,0x5A
00000148 f4.e0 LDI R31,0x04
If D <> 0 Then
00000149 0e.94.d4.01 CALL 0x000001D4 Get 0(double 8 bytes) from ROM 0x045A(ELPM), compare with RAM 0x2029 and NO set RAMPZ!
If D <> 0 Then
0000014B 11.f4 BRNE PC+0x03 l
0000014C 0c.94.56.01 JMP 0x00000156
D = 1
0000014E a9.e2 LDI R26,0x29
0000014F b0.e2 LDI R27,0x20
D = 1
00000150 e2.e6 LDI R30,0x62
00000151 f4.e0 LDI R31,0x04
D = 1
00000152 0e.94.c6.01 CALL 0x000001C6 Call set RAMPZ - OK
D = 1
00000154 0e.94.fb.01 CALL 0x000001FB Set to 1(double 8 bytes) from ROM(ELPM)
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.2 ) |
uga237
Posted: Sun Aug 11, 2019 5:33 pm Post subject: |
UPD:
Is this corrected in 2.0.8.2?
If D <> 0 Then
00000145 a8.e0 LDI R26,0x08
If D <> 0 Then
00000147 ee.e5 LDI R30,0x5E
If D <> 0 Then
00000149 0e.94.c8.01 CALL 0x000001C8 Added in 2.0.8.2? or in 2.0.8.1?
If D <> 0 Then
0000014B 0e.94.d6.01 CALL 0x000001D6
If D <> 0 Then
0000014D 11.f4 BRNE PC+0x03
0000014E 0c.94.58.01 JMP 0x00000158
D = 1
00000150 a8.e0 LDI R26,0x08
00000151 b0.e2 LDI R27,0x20
D = 1
00000152 e6.e6 LDI R30,0x66
00000153 f4.e0 LDI R31,0x04
D = 1
00000154 0e.94.c8.01 CALL 0x000001C8
D = 1
00000156 0e.94.fd.01 CALL 0x000001FD |
