Can't declare new Function?
KenHorse
PostPosted: Sun Aug 04, 2019 7:43 pm    Post subject: Can't declare new Function? Reply with quote
$regfile = "m2561def.dat"
$crystal = 16000000
$hwstack = 400
$swstack = 550
$framesize = 345
$Baud = 57600
Declare Function ConvertToLog(Test) As Single
End Function
Compiling result:
Error : 26 Line : 12 AS expected [AS expected] , in File : C:\MCS Electronics\BASCOM-AVR\test_function.bas
(Notice I did install the new 2.0.8.2 into the existing directory where previous versions have resided for years. Might this cause problems?)
PostPosted: Sun Aug 04, 2019 7:58 pm    Post subject: Reply with quote
You should declare what type of variable "Test" will be...
Declare Function Converttolog(byval Test As Byte) As Single
End Function
PostPosted: Sun Aug 04, 2019 8:04 pm    Post subject: Re: Can't declare new Function? Reply with quote
Problem is: you forget faster than you learn.
The compiler simply tells you that Test needs dimensioning.
KenHorse
PostPosted: Thu Aug 08, 2019 12:42 am    Post subject: Re: Can't declare new Function? Reply with quote
Stupid oversight on my part.......
Thanks
