URL2IP issues
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
Farmer
PostPosted: Sun May 28, 2017 5:12 pm    Post subject: URL2IP issues Reply with quote
i happy about the new function URL2IP in the latest Bascom revision. Thats what i never hoped to find.
Regarding to the Help its connecting to Google DNS server 8.8.8.8 , is this changeble to my own internal DNS Server so it works for my internal network.
I used the Wiz510 sample, works fine as it is.
Is the Google server maybe the reason why it does not work for all url names? It works for the "mcselec.com" url from the sample, but many URL do not work even if they respond to a manual request via my PCs command line. One not working example is my page gs400.de; WWW.Bild.de works fine.
Regards,
Tobias
plouf
PostPosted: Sun Jul 22, 2018 11:12 am    Post subject: Reply with quote
the floowing code ONLY resovles mscelec.com nothing else ! (its a copy from ping.bas example)
$regfile = "m88def.dat"                                     ' specify the used micro
$crystal = 1000000                                          ' used crystal frequency
$baud = 19200                                               ' use baud rate
$hwstack = 80                                               ' default use 64 for the hardware stack
$swstack = 64                                               ' default use 64 for the SW stack
$framesize = 180                                            ' default use 80 for the frame space
Const Cdebug = 1
'Configuration Of The SPI bus
Config Spi = Hard , Interrupt = Off , Data_order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 0
'Init the spi pins
Spiinit
'we do the usual
Print "Init TCP"                                            ' display a message
Enable Interrupts                                           ' before we use config tcpip , we need to enable the interrupts
Config Tcpip = Noint , Mac = 12.128.12.34.56.78 , Ip = 192.168.1.70 , Submask = 255.255.255.0 , Gateway = 192.168.1.250 , Localport = 1000 , Tx = $55 , Rx = $55 , Chip = W5100 , Spi = 1 , Cs = Portb.2
Print "Init done"
Dim Ip As Long
Ip = Url2ip("mcselec.com")
print Ip2str(ip)
Ip = Url2ip("www.google.com")
print Ip2str(ip)
do
loop
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
