Simplest Freq/Duty generator an measure
PostPosted: Wed May 22, 2019 2:52 pm    Post subject: Simplest Freq/Duty generator an measure Reply with quote
I really don know why I dont post this simplest method for generate desired square wave.
I was think that this is already shared so maybe Im belated...
This two codes and schematics enable to generate square wave you want by entering it with keypad..and second code is "complementary" Very Happy It measure but only in designed spectrum.
PostPosted: Wed May 22, 2019 8:22 pm    Post subject: Reply with quote
Thanks for sharing Very Happy
Arek2014
PostPosted: Wed Sep 25, 2019 8:56 pm    Post subject: Reply with quote
Simple generator Smile
$crystal = 8000000
Config Timer1 = Timer , Prescale = 1 ,clear timer = 1, Compare_a = Toggle    'generator frequency!!! OC1A
'Ocr1a = 500
dim freq as word
dim f as dword
enable timer1
do
f = 4000000 / freq  'f crystal / 2 !!!
print f ; "Hz"
Ocr1a = freq    'changing dim freq --> change frequency
loop
Pzx
PostPosted: Wed Sep 09, 2020 3:04 pm    Post subject: Reply with quote
Arek, thanks for your simple generatr code.
What about Timer2?
OCR2A doesnt work.
Can you do the same with Timer2?
