bellon
Posted: Fri Mar 01, 2019 3:59 pm Post subject: Recept nul char / Bascom |
Hello,I am trying to receive characters from a LCD 4D System. Commands sent by the LCD may contain Nulls (00).For example: 01 05 00 00 00 04 but my reception function is unable to receive them!Can you help me ?
Thank you Bernard
Exemple commande recue: 01 05 00 00 00 04 , Chr_cnt affiche 4 au lieu de 6
A = Ischarwaiting()
If A = 1 Then 'Si char présent
A = Udr 'Lire Le Char
Cmd_rcv = Cmd_rcv + Chr(a) 'stocker le char
Incr Chr_cnt ' incrementer le Nbr de char.
Lcd Chr_cnt ?afficher sur un LCD le nbr. de char recu
A = 0
End If[/code]
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.8.1 ) |
hgrueneis
Posted: Fri Mar 01, 2019 5:14 pm Post subject: |
If the first character is never zero, then you can try INPUTBIN after detection of the first character.
It helps, if you know how many characters there are per transmission.
Hubert |
bellon
Posted: Fri Mar 01, 2019 5:32 pm Post subject: |
yes, the first and last character is never zero (00) but the length is not fixed (between 4 and 10 char)
in fact I'm trying to communicate with a TFT LCD from 4D Systems!
Thanks for your help ! |
Posted: Fri Mar 01, 2019 9:58 pm Post subject: |
a string may not contain a 0 byte since it is the end of string marker.
but you can also use a byte array to store the data.
or better, use buffered serial input
' 01 05 00 00 00 04
then inside the main loop, check if you have data and process it
Code: | do
if ischarwaiting() =1 then
b=waitkey() ' get the data
if state=0 then ' we did not handled data yet
state=1 ' set state so we know where we are in the process
elseif state=1 then ' we got the header byte
numofbytes=b 'this is the number of bytes that follow which is 5
state=2
elseif state=2 then
' get the actual data
end if
end if
loop |
this is just a partial example of 1 option on how to deal with the data.
another options is to just wait for enough data in the buffer and get it all at once using inputbin _________________ Mark |
Pikczu
Joined: 22 Jan 2006 Posts: 72 Location: Dublin, Ireland
Posted: Sat Mar 02, 2019 2:21 pm Post subject: |
Bellon is this for VISI Genie ?
If so data frame has fixed length 6 bytes.
I have back bone for the library almost ready I can share "As is".
I'm not sure about the magic_object as this requires extra license.
For read object command, the response always starts with 05 as highlighted in green in the table below.
************************Edit*********************************************************
What is done so far:
Read object- this need to be change to function
Write object
Write string - CR and LF need to be added
Write contrast
Report object
Report event
Obviously I need to clean it and optimize.
Code: | '$sim
'****!!! Xmega do not use $baud!!*******
$regfile = "xm128a3udef.dat"
$crystal = 32000000 '32MHz
$hwstack = 128
$swstack = 128
$framesize = 128
$projecttime = 149
$version 0 , 0 , 1143
Dim Firmware As String * 6
Firmware = "1.0A"
Config Submode = New
' ***************** SYSTEM CLOCK CONFIG ****************************************
' INTERNAL 32MHz NO PRESCALE
' ENABLING AUTOMATIC OSCILLATOR CALIBRATION
Osc_dfllctrl.0 = 1
Dfllrc32m_ctrl.0 = 1
'***************************Dynamic uart ***************************************
'Dim Buart_channel As Byte ' variable for dynamic UART channels
Const Main_bus = 1 'main RS485 bus
Const Debug_port = 2 'Debug port
Const Sensor_bus = 3 'sensors rs485 bus
Const Lcd_4d = 4 'uart port
'************ CONFIGURATION FOR COM1 UART_C0************************************
' ' TX-PORTC.3 RX-PORTC.2 com 2 tcp
Config Com1 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Open "COM1:" For Binary As #buart_channel 'no need to open any more
Config Serialin1 = Buffered , Size = 128 , Bytematch = None 'for COM1
Config Serialout1 = Buffered , Size = 128
Open "COM1:" For Binary As #1
'Config Input1 = Crlf , Echo = Cr
'Echo On
'*********** CONFIGURATION FOR COM2 UART_C1*************************************
' ' TX-PORTC.7 RX-PORTC.6 (udp com 1 )
Config Com2 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Open "COM2:" For Binary As #buart_channel
Config Serialin2 = Buffered , Size = 128 , Bytematch = None 'for COM2
Config Serialout2 = Buffered , Size = 128
Open "COM2:" For Binary As #2
' Config Input2 = Cr , Echo = Cr
'Echo On
'************ CONFIGURATION FOR COM3 UART_D0************************************
' ' TX-PORTD.3 RX-PORTD.2 wifi
Config Com3 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Open "COM3:" For Binary As #buart_channel 'no need to open any more
Config Serialin3 = Buffered , Size = 128 , Bytematch = None 'for COM1
Config Serialout3 = Buffered , Size = 128
Open "COM3:" For Binary As #3
'Echo On
'************ CONFIGURATION 'COM5 UART_E0 **************************************
' ' TX-PORTE.3 ' RX-PORTE.2 4D Systems LCD
Config Com5 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Open "COM5:" For Binary As #buart_channel 'channel 4
Config Serialin4 = Buffered , Size = 128 , Bytematch = None 'for COM4
Config Serialout4 = Buffered , Size = 128
Open "COM5:" For Binary As #4
' Echo on
'********************** CLOCK CONFIG *******************************************
' we select the internal 1 KHz clock from the 32khz Internal Oscillator
Config Clock = Soft , Rtc = 1khz_int32khz_rcosc
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled ' the RTC uses LO priority
'********************Config all ports ******************************************
'config pinA.2 = input 'index pin of encoder
Config Pina.1 = Input 'encoder B
Config Pina.0 = Input 'encoder A
'Config Xpin = PinA.2 , Outpull = pullup , Sense = low_level
Config Xpin = Porta.1 , Outpull = Pullup , Sense = Low_level 'enable Pull up and reaction on low level
Config Xpin = Porta.0 , Outpull = Pullup , Sense = Low_level
Config Pine.2 = Input 'index (home_1 sensor)
Config Xpin = Porte.2 , Outpull = Pullup , Sense = Falling
Config Porte.3 = Output 'buzzer
Config Xpin = Porte.3 , Outpull = Totem
'**********************************Event system config**************************
'**********************************encoder for driver_1*************************
Config Event_system = Dummy , Mux0 = Porta.0 , Qd0 = Enabled , Qdi0 = Enabled , Digflt0 = 8
'**********************************encoder for driver_2*************************
Config Tce0 = Normal , Prescale = E0 , Event_source = E0 , Event_action = Qdec
'Config Tcd0 = Normal , Prescale = E0 , Event_source = E0 , Event_action = Qdec
'************************* Variables *******************************************
Dim S_pace As Byte
Dim A As Byte
Dim Enkoder_tmp As Word 'for the encoder
Dim Enkoder_tmp_1 As Word 'for the encoder
Dim Enkoder_tmp_2 As Word 'for the encoder
Dim C As Byte
Dim R As Byte
Dim Tablica(6)as Byte
'********************************used in TX subs********************************
Dim Ack_flag As Byte ' ack byte flag setup each time we expect the ack to come form the display
Dim 4d_arr_tx(6)as Byte '
Dim 4d_helpa As Word At 4d_arr_tx(4) Overlay
Dim 4d_string_tx_arr(39) As Byte
Dim 4d_string_tx As String * 34 At 4d_string_tx_arr(1) + 3 Overlay
Dim 4d_arr_rx(6) As Byte
Dim 4d_var_rx As Word At 4d_arr_rx(4) Overlay 'overlay for rx
Dim 4d_var_rx_tmp As Word
Dim Obj_index As Byte '4d object index
'Macro
Dim Xor_crc As Byte 'xor crc for 4d
Xor_crc = 0
Dim Dipswitch_idx As Byte '0
Dim Knob_idx As Byte
Dim Rockerswitch_idx As Byte
Dim Rotaryswitch_idx As Byte
Dim Slider_idx As Byte
Dim Trackbar_idx As Byte
Dim Winbutton_idx As Byte
Dim Angularmeter_idx As Byte
Dim Coolgauge_idx As Byte
Dim Customdigits_idx As Byte
Dim Form_idx As Byte 'Used To Set The Current Form
Dim Gauge_idx As Byte '
'Dim Image_idx As Byte ' Displayed As Part Of Form , No Method To Alter
Dim Keyboard_idx As Byte ' KEYBOARD Inputs Are Always Single Bytes And Are Unsolicited
Dim Led_idx As Byte
Dim Leddigits_idx As Byte
Dim Meter_idx As Byte
Dim Strings_idx As Byte
Dim Thermometer_idx As Byte
Dim Userled_idx As Byte
Dim Video_idx As Byte
'Dim Statictext_idx As Byte ' Displayed As Part Of Form , No Method To Alter
Dim S_ound_idx As Byte
Dim T_imer_idx As Byte
Dim Spectrum_idx As Byte
Dim Scope_idx As Byte
Dim Tank_idx As Byte
Dim Userimages_idx As Byte
Dim Pinoutput_idx As Byte
Dim Pininput_idx As Byte
Dim 4dbutton_idx As Byte
Dim Anibutton_idx As Byte
Dim Colorpicker_idx As Byte
Dim Userbutton_idx As Byte
Dim Magicobject_idx As Byte 'ONLY Available When Using Genie Pro
Dim Smartgauge_idx As Byte 'ONLY Available When Using Genie Pro
Dim Smartslider_idx As Byte 'ONLY Available When Using Genie Pro
Dim Smartknob_idx As Byte 'Only Available When Using Genie Pro
Dim Dipswitch_val(2) As Byte '0
Dim Knob_val(2) As Byte
Dim Rockerswitch_val(2) As Byte
Dim Rotaryswitch_val(2) As Byte
Dim Slider_val(2) As Byte
Dim Trackbar_val(2) As Byte
Dim Winbutton_val(2) As Byte
Dim Angularmeter_val(2) As Byte
Dim Coolgauge_val(2) As Byte
Dim Customdigits_val(2) As Byte
Dim Form_val(2) As Byte 'Used To Set The Current Form
Dim Gauge_val(2) As Byte '
'Dim Image_val(2) As Byte ' Displayed As Part Of Form , No Method To Alter
Dim Keyboard_val(2) As Byte ' KEYBOARD Inputs Are Always Single Bytes And Are Unsolicited
Dim Led_val(2) As Byte
Dim Leddigits_val(2) As Byte
Dim Meter_val(2) As Byte
Dim Strings_val(2) As Byte
Dim Thermometer_val(2) As Byte
Dim Userled_val(2) As Byte
Dim Video_val(2) As Byte
'Dim Statictext_val(2) As Byte ' Displayed As Part Of Form , No Method To Alter
Dim S_ound_val(2) As Byte
Dim T_imer_val(2) As Byte
Dim Spectrum_val(2) As Byte
Dim Scope_val(2) As Byte
Dim Tank_val(2) As Byte
Dim Userimages_val(2) As Byte
Dim Pinoutput_val As Byte
Dim Pininput_val As Byte
Dim 4dbutton_val(2) As Byte
Dim Anibutton_val(2) As Byte
Dim Colorpicker_val(2) As Byte
Dim Userbutton_val(2) As Byte
Dim Magicobject_val(2) As Byte 'ONLY Available When Using Genie Pro
Dim Smartgauge_val(2) As Byte 'ONLY Available When Using Genie Pro
Dim Smartslider_val(2) As Byte 'ONLY Available When Using Genie Pro
Dim Smartknob_val(2) As Byte 'Only Available When Using Genie Pro
Const A_ck = &H06
Const Nak = &H15
'Const 4d_uart = 4 'uart port
Const 4d_max_len = 32 'maximum 4D string length
Const Dipswitch = &H00 '0
Const Knob = &H01
Const Rockerswitch = &H02
Const Rotaryswitch = &H03
Const Slider = &H04
Const Trackbar = &H05
Const Winbutton = &H06
Const Angularmeter = &H07
Const Coolgauge = &H08
Const Customdigits = &H09
Const Form = &H0A 'Used To Set The Current Form
Const Gauge = &H0B '
Const Image = &H0C ' Displayed As Part Of Form , No Method To Alter
Const Keyboard = &H0D ' KEYBOARD Inputs Are Always Single Bytes And Are Unsolicited
Const Led = &H0E
Const Leddigits = &H0F
Const Meter = &H10
Const Strings = &H11
Const Thermometer = &H12
Const Userled = &H13
Const Video = &H14
Const Statictext = &H15 ' Displayed As Part Of Form , No Method To Alter
Const S_ound = &H16
Const T_imer = &H17
Const Spectrum = &H18
Const Scope = &H19
Const Tank = &H1A
Const Userimages = &H1B
Const Pinoutput = &H1C
Const Pininput = &H1D
Const 4dbutton = &H1E
Const Anibutton = &H1F
Const Colorpicker = &H20
Const Userbutton = &H21
Const Magicobject = &H22 'ONLY Available When Using Genie Pro
Const Smartgauge = &H23 'ONLY Available When Using Genie Pro
Const Smartslider = &H24 'ONLY Available When Using Genie Pro
Const Smartknob = &H25 'Only Available When Using Genie Pro
Const Read_obj = &H00
Const Write_obj = &H01
Const Write_str = &H02
Const Write_stru = &H03
Const Write_contrast = &H04
Const Report_obj = &H05 'response to read obj command
Const Report_event = &H07 'response to evnt no no request needed
Const Write_magic_bytes = &H08
Const Write_magic_dbytes = &H09
Const Report_magic_event_bytes = &H0A
Function Xor_this(ar()as Byte ) As Byte ' Function XOR
Local Xor_ing As Byte 'temporary variable for xor value so could be a local
Xor_ing = Ar(1) Xor Ar(2) 'xoring
Xor_ing = Xor_ing Xor Ar(3)
Xor_ing = Xor_ing Xor Ar(4)
Xor_ing = Xor_ing Xor Ar(5)
'Xor_ing = Xor_ing Xor Ar(6)
Xor_this = Xor_ing 'final result assignment
End Function
'this shoul be a function not a sub
Sub 4d_read_obj(byval 4d_object_id As Byte , Byval 4d_object_index As Byte )
'this should be a fuction
4d_arr_tx(1) = Write_obj '&h00 constant
4d_arr_tx(2) = 4d_object_id 'object ID as per constants
4d_arr_tx(3) = 4d_object_index 'object index
Xor_crc = 4d_arr_tx(1) Xor 4d_arr_tx(2) 'calculate the xor check sum
Xor_crc = Xor_crc Xor 4d_arr_tx(3)
4d_arr_tx(4) = Xor_crc
Printbin #4 , 4d_arr_tx(1) ; 4 'print binary the final result
Ack_flag.1 = 1 'for feature use
'The response from the display should be Report_obj: &h05
Sub 4d_write_obj(byval 4d_object_id As Byte , Byval 4d_object_index As Byte , Byval 4d_obj_value As Word )
'Dim 4d_helpa As Word At 4d_arr_tx(4) Overlay 'copy for clarity
Swap 4d_obj_value 'little endian to big endian
4d_helpa = 4d_obj_value 'assign to overlaid variable
4d_arr_tx(1) = Write_obj '&h01 constant
'4d_arr_tx(4) as this is overlay teh values are all ready there in global array
'4d_arr_tx(5) as this is overlay teh values are all ready there in global array
Xor_crc = Xor_crc Xor 4d_arr_tx(4)
4d_arr_tx(6) = Xor_crc Xor 4d_arr_tx(5)
Printbin #lcd_4d , 4d_arr_tx(1) ; 6 'print binary the final result
Ack_flag.0 = 1 'for feature use
'The response from the display should be ACK message &h06
Sub 4d_write_str(byval 4d_str_indx As Byte , Byval 4d_string_1 As String , Byval Cr_lf As Byte )
'the body of the command is:
'code + string_index+ string_lenght + string + xorcrc
Local Index_help_a As Byte 'used to calculate the lengt of the string
Local Index_help_b As Byte 'used to calculate position of the XOR CRC in array, string lenght+3
Dim Tot_command_len As Byte 'total comand lenght
'If Cr >= 1 Then Cr = 1
'If Lf >= 1 Then Lf = 1
Select Case Cr_lf
Case 0:
'Tot_command_len = Len(4d_string_1) + 4 'string lenght(+) commad (+) string index (+) string
Tot_command_len = Len(4d_string_1) 'string lenght(+) commad (+) string index (+) string
Case 1:
Tot_command_len = Len(4d_string_1) + 5 'string lenght(+) commad (+) string index (+) string
' Insertchar 4d_string_tx , Tot_command_len
Case 2:
Tot_command_len = Len(4d_string_1) '+ 6 'string lenght(+) commad (+) string index (+) string
4d_string_tx = 4d_string_1 'copy the string in to variable overlayd at array
4d_string_tx_arr(1) = Write_str '&h02 write string command
4d_string_tx_arr(2) = 4d_str_indx 'index of the string
4d_string_tx_arr(3) = Len(4d_string_1) 'lenght of the string
For Index_help_a = 1 To Tot_command_len -1 'we need to xor this and asign at the end
'the minus (-)1 skip xor of the null termination
4d_string_tx_arr(tot_command_len) = 4d_string_tx_arr(tot_command_len) Xor 4d_string_tx_arr(index_help_a)
Next Index_help_a
Select Case Tot_command_len ' total comand lenght
Case 5:
Printbin #1 , 4d_string_tx_arr(1) ; 5 'code +string index+ string lenght + 1 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 5 'code +string index+ string lenght + 1 char + crc
Case 6:
Printbin #1 , 4d_string_tx_arr(1) ; 6 'code +string index+ string lenght + 2 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 6 'code +string index+ string lenght + 2 char + crc
Case 7:
Printbin #1 , 4d_string_tx_arr(1) ; 7 'code +string index+ string lenght + 3 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 7 'code +string index+ string lenght + 3 char + crc
Case 8:
Printbin #1 , 4d_string_tx_arr(1) ; 8 'code +string index+ string lenght + 4 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 8 'code +string index+ string lenght + 4 char + crc
Case 9:
Printbin #1 , 4d_string_tx_arr(1) ; 9 'code +string index+ string lenght + 5 char + crc
Printbin #4 , 4d_string_tx_arr(1) , 9 'code +string index+ string lenght + 5 char + crc
Case 10:
Printbin #1 , 4d_string_tx_arr(1) ; 10 'code +string index+ string lenght + 6 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 10 'code +string index+ string lenght + 6 char + crc
Case 11:
Printbin #1 , 4d_string_tx_arr(1) ; 11 'code +string index+ string lenght + 7 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 11 'code +string index+ string lenght + 7 char + crc
Case 12:
Printbin #1 , 4d_string_tx_arr(1) ; 12 'code +string index+ string lenght + 8 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 12 'code +string index+ string lenght + 8 char + crc
Case 13:
Printbin #1 , 4d_string_tx_arr(1) ; 13 'code +string index+ string lenght + 9 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 13 'code +string index+ string lenght + 9 char + crc
Case 14:
Printbin #1 , 4d_string_tx_arr(1) ; 14 'code +string index+ string lenght + 10 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 14 'code +string index+ string lenght + 10 char + crc
Case 15:
Printbin #1 , 4d_string_tx_arr(1) ; 15 'code +string index+ string lenght + 11 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 15 'code +string index+ string lenght + 11 char + crc
Case 16:
Printbin #1 , 4d_string_tx_arr(1) ; 16 'code +string index+ string lenght + 12 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 16 'code +string index+ string lenght + 12 char + crc
Case 17:
Printbin #1 , 4d_string_tx_arr(1) ; 17 'code +string index+ string lenght + 13 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 17 'code +string index+ string lenght + 13 char + crc
Case 18:
Printbin #1 , 4d_string_tx_arr(1) ; 18 'code +string index+ string lenght + 14 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 18 'code +string index+ string lenght + 14 char + crc
Case 19:
Printbin #1 , 4d_string_tx_arr(1) ; 19 'code +string index+ string lenght + 15 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 19 'code +string index+ string lenght + 15 char + crc
Case 20:
Printbin #1 , 4d_string_tx_arr(1) ; 20 'code +string index+ string lenght + 16 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 20 'code +string index+ string lenght + 16 char + crc
Case 21:
Printbin #1 , 4d_string_tx_arr(1) ; 21 'code +string index+ string lenght + 17 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 21 'code +string index+ string lenght + 17 char + crc
Case 22:
Printbin #1 , 4d_string_tx_arr(1) ; 22 'code +string index+ string lenght + 18 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 22 'code +string index+ string lenght + 18 char + crc
Case 23:
Printbin #1 , 4d_string_tx_arr(1) ; 23 'code +string index+ string lenght + 19 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 23 'code +string index+ string lenght + 19 char + crc
Case 24:
Printbin #1 , 4d_string_tx_arr(1) ; 24 'code +string index+ string lenght + 20 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 24 'code +string index+ string lenght + 20 char + crc
Case 25:
Printbin #1 , 4d_string_tx_arr(1) ; 25 'code +string index+ string lenght + 21 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 25 'code +string index+ string lenght + 21 char + crc
Case 26:
Printbin #1 , 4d_string_tx_arr(1) ; 26 'code +string index+ string lenght + 22 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 26 'code +string index+ string lenght + 22 char + crc
Case 27:
Printbin #1 , 4d_string_tx_arr(1) ; 27 'code +string index+ string lenght + 23 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 27 'code +string index+ string lenght + 23 char + crc
Case 28:
Printbin #1 , 4d_string_tx_arr(1) ; 28 'code +string index+ string lenght + 24 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 28 'code +string index+ string lenght + 24 char + crc
Case 29:
Printbin #1 , 4d_string_tx_arr(1) ; 29 'code +string index+ string lenght + 25 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 29 'code +string index+ string lenght + 25 char + crc
Case 30:
Printbin #1 , 4d_string_tx_arr(1) ; 30 'code +string index+ string lenght + 26 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 30 'code +string index+ string lenght + 26 char + crc
Case 31:
Printbin #1 , 4d_string_tx_arr(1) ; 31 'code +string index+ string lenght + 27 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 31 'code +string index+ string lenght + 27 char + crc
Case 32:
Printbin #1 , 4d_string_tx_arr(1) ; 32 'code +string index+ string lenght + 28 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 32 'code +string index+ string lenght + 28 char + crc
Case 33:
Printbin #1 , 4d_string_tx_arr(1) ; 33 'code +string index+ string lenght + 29 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 33 'code +string index+ string lenght + 29 char + crc
Case 34:
Printbin #1 , 4d_string_tx_arr(1) ; 34 'code +string index+ string lenght + 30 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 34 'code +string index+ string lenght + 30 char + crc
Case 35:
Printbin #1 , 4d_string_tx_arr(1) ; 35 'code +string index+ string lenght + 31 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 35 'code +string index+ string lenght + 31 char + crc
Case 36:
Printbin #1 , 4d_string_tx_arr(1) ; 36 'code +string index+ string lenght + 32 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 36 'code +string index+ string lenght + 32 char + crc
Sub 4d_write_contrast(byval 4d_contrast_val As Byte)
If 4d_contrast_val => 10 Then
4d_contrast_val = 10
Dim 4d_contrast_tx(3) As Byte
4d_contrast_tx(1) = Write_contrast
4d_contrast_tx(2) = 4d_contrast_val
4d_contrast_tx(3) = Write_contrast Xor 4d_contrast_val
Printbin #4 , 4d_contrast_tx(1) ; 3
'************************* Main loop *******************************************
Enkoder_tmp = 0
Ack_flag = 0
Tablica(1) = Write_obj
Tablica(2) = Leddigits
Tablica(3) = Obj_index
Tablica(4) = Tablica(4)
Tablica(5) = 0
Print #1 , "MCU Rev. = " ; Mcu_revid 'version of the MCU
'Call 4d_write_contrast(&H07)
Call 4d_write_str(0 , "Hi there" , 0 )
'Call 4d_read_obj(leddigits , &H01 )
'drukuj na wifi
If Tce0_cnt <> Enkoder_tmp Then 'jesli zawartosc timera TCD0 jest różna od naszej zmiennej to
Enkoder_tmp = Tce0_cnt 'przepisz nową wartość z timera TCD0 do zmiennej enkoder_tmp
Enkoder_tmp_1 = Tce0_cnt / 4 ' four inpulses per one step of teh encoder so wee need only one
If Enkoder_tmp_1 <> Enkoder_tmp_2 Then
Enkoder_tmp_2 = Enkoder_tmp_1
Print #1 , Enkoder_tmp_2 'wyśli przez port szeregowy 2 (zmienna buart=2)
Call 4d_write_obj(leddigits , &H01 , Enkoder_tmp_2)
Call 4d_write_contrast(enkoder_tmp_2)
Waitms 500
Incr Tablica(5)
Tablica(6) = Xor_this(tablica(1))
'Printbin #4 , Tablica(1) ; 6
'Printbin #4 , Write_obj ; Leddigits ; &H00 ; &H00 ; Tablica(5) ; Xor_crc ;
If Ischarwaiting(#4) = 1 Then
Inputbin #4 , 4d_arr_rx(1) , 1
Print #1 , "received= " ; 4d_arr_rx(1)
Select Case 4d_arr_rx(1) 'command
Case Report_obj: '&H05
'If Ack_flag.1 = 1 Then 'for feature use
'Ack_flag.1 = 0
'Else
'Print #1 , " Error there was no &H05 request !"
'End If
Inputbin #4 , 4d_arr_rx(2) , 5 'get next 5
Xor_crc = Xor_this(4d_arr_rx(1)) ' check the crc
If 4d_arr_rx(6) = Xor_crc Then 'if crc ok then check what came
Select Case 4d_arr_rx(2) 'object ID
Case Dipswitch: '0
Dipswitch_idx = 4d_arr_rx(3)
Dipswitch_val(1) = 4d_arr_rx(4)
Dipswitch_val(2) = 4d_arr_rx(5)
Print #1 , "Dipswitch "
Case Knob: '1
Knob_idx = 4d_arr_rx(3)
Knob_val(1) = 4d_arr_rx(4)
Knob_val(2) = 4d_arr_rx(5)
Print #1 , "Knob "
Case Rockerswitch: '2
Rockerswitch_idx = 4d_arr_rx(3)
Rockerswitch_val(1) = 4d_arr_rx(4)
Rockerswitch_val(2) = 4d_arr_rx(5)
Print #1 , "Rockerswitch "
Case Rotaryswitch: '3
Rotaryswitch_idx = 4d_arr_rx(3)
Rotaryswitch_val(1) = 4d_arr_rx(4)
Rotaryswitch_val(2) = 4d_arr_rx(5)
Print #1 , "Rotaryswitch "
Case Slider: '4
Slider_idx = 4d_arr_rx(3)
Slider_val(1) = 4d_arr_rx(4)
Slider_val(2) = 4d_arr_rx(5)
Print #1 , "Slider "
Case Trackbar: '5
Trackbar_idx = 4d_arr_rx(3)
Trackbar_val(1) = 4d_arr_rx(4)
Trackbar_val(2) = 4d_arr_rx(5)
Print #1 , "Trackbar "
Case Winbutton: '6
Winbutton_idx = 4d_arr_rx(3)
Winbutton_val(1) = 4d_arr_rx(4)
Winbutton_val(2) = 4d_arr_rx(5)
Print #1 , "Winbutton "
Case Angularmeter: '7
Angularmeter_idx = 4d_arr_rx(3)
Angularmeter_val(1) = 4d_arr_rx(4)
Angularmeter_val(2) = 4d_arr_rx(5)
Print #1 , "Angularmeter "
Case Coolgauge: '8
Coolgauge_idx = 4d_arr_rx(3)
Coolgauge_val(1) = 4d_arr_rx(4)
Coolgauge_val(2) = 4d_arr_rx(5)
Print #1 , "Coolgauge "
Case Customdigits: '9
Customdigits_idx = 4d_arr_rx(3)
Customdigits_val(1) = 4d_arr_rx(4)
Customdigits_val(2) = 4d_arr_rx(5)
Print #1 , "Customdigits "
Case Form: '10
Form_idx = 4d_arr_rx(3)
Form_val(1) = 4d_arr_rx(4)
Form_val(2) = 4d_arr_rx(5)
Print #1 , "Form "
Case Gauge: '11
Gauge_idx = 4d_arr_rx(3)
Gauge_val(1) = 4d_arr_rx(4)
Gauge_val(2) = 4d_arr_rx(5)
Print #1 , "Gauge "
Case Image: '12
'Image_idx = 4d_arr_rx(3)
'Image_val(1) = 4d_arr_rx(4)
'Image_val(2) = 4d_arr_rx(5)
Print #1 , "Image "
Case Keyboard: '13
Keyboard_idx = 4d_arr_rx(3)
Keyboard_val(1) = 4d_arr_rx(4)
Keyboard_val(2) = 4d_arr_rx(5)
Print #1 , "Keyboard "
Case Led: '14
Led_idx = 4d_arr_rx(3)
Led_val(1) = 4d_arr_rx(4)
Led_val(2) = 4d_arr_rx(5)
Print #1 , "Led "
Case Leddigits: '15
Leddigits_idx = 4d_arr_rx(3)
Leddigits_val(1) = 4d_arr_rx(4)
Leddigits_val(2) = 4d_arr_rx(5)
Print #1 , "Leddigits "
Case Meter: '16
Meter_idx = 4d_arr_rx(3)
Meter_val(1) = 4d_arr_rx(4)
Meter_val(2) = 4d_arr_rx(5)
Print #1 , "Meter "
Case Strings: '17
Strings_idx = 4d_arr_rx(3)
Strings_val(1) = 4d_arr_rx(4)
Strings_val(2) = 4d_arr_rx(5)
Print #1 , "Strings "
Case Thermometer: '18
Thermometer_idx = 4d_arr_rx(3)
Thermometer_val(1) = 4d_arr_rx(4)
Thermometer_val(2) = 4d_arr_rx(5)
Print #1 , "Thermometer "
Case Userled: '19
Userled_idx = 4d_arr_rx(3)
Userled_val(1) = 4d_arr_rx(4)
Userled_val(2) = 4d_arr_rx(5)
Print #1 , "Userled "
Case Video: '20
Video_idx = 4d_arr_rx(3)
Video_val(1) = 4d_arr_rx(4)
Video_val(2) = 4d_arr_rx(5)
Debug "Video "
Case Statictext: '21
'Statictext_idx = 4d_arr_rx(3)
'Statictext_val(1) = 4d_arr_rx(4)
'Statictext_val(2) = 4d_arr_rx(5)
Print #1 , "Statictext "
Case S_ound: '22
S_ound_idx = 4d_arr_rx(3)
S_ound_val(1) = 4d_arr_rx(4)
S_ound_val(2) = 4d_arr_rx(5)
Print #1 , "S_ound "
Case T_imer: '23
T_imer_idx = 4d_arr_rx(3)
T_imer_val(1) = 4d_arr_rx(4)
T_imer_val(2) = 4d_arr_rx(5)
Print #1 , "T_imer "
Case Spectrum: '24
Spectrum_idx = 4d_arr_rx(3)
Spectrum_val(1) = 4d_arr_rx(4)
Spectrum_val(2) = 4d_arr_rx(5)
Print #1 , "Spectrum "
Case Scope: '25
Scope_idx = 4d_arr_rx(3)
Scope_val(1) = 4d_arr_rx(4)
Scope_val(2) = 4d_arr_rx(5)
Print #1 , "Scope "
Case Tank: '26
Tank_idx = 4d_arr_rx(3)
Tank_val(1) = 4d_arr_rx(4)
Tank_val(2) = 4d_arr_rx(5)
Print #1 , "Tank "
Case Userimages: '27
Userimages_idx = 4d_arr_rx(3)
Userimages_val(1) = 4d_arr_rx(4)
Userimages_val(2) = 4d_arr_rx(5)
Print #1 , "Userimages "
Case Pinoutput: '28
Pinoutput_idx = 4d_arr_rx(3)
'Pinoutput_val(1) = 4d_arr_rx(4)
Pinoutput_val = 4d_arr_rx(5)
Print #1 , "Pinoutput "
Case Pininput: '29
Pininput_idx = 4d_arr_rx(3)
'Pininput_val(1) = 4d_arr_rx(4)
Pininput_val = 4d_arr_rx(5)
Print #1 , "Pininput "
Case 4dbutton: '30
4dbutton_idx = 4d_arr_rx(3)
4dbutton_val(1) = 4d_arr_rx(4)
4dbutton_val(2) = 4d_arr_rx(5)
Print #1 , "4dbutton "
Case Anibutton: '31
Anibutton_idx = 4d_arr_rx(3)
Anibutton_val(1) = 4d_arr_rx(4)
Anibutton_val(2) = 4d_arr_rx(5)
Print #1 , "Anibutton "
Case Colorpicker: '32
Colorpicker_idx = 4d_arr_rx(3)
Colorpicker_val(1) = 4d_arr_rx(4)
Colorpicker_val(2) = 4d_arr_rx(5)
Print #1 , "Colorpicker "
Case Userbutton: '33
Userbutton_idx = 4d_arr_rx(3)
Userbutton_val(1) = 4d_arr_rx(4)
Userbutton_val(2) = 4d_arr_rx(5)
Print #1 , "Userbutton "
Case Magicobject: '34
Magicobject_idx = 4d_arr_rx(3)
Magicobject_val(1) = 4d_arr_rx(4)
Magicobject_val(2) = 4d_arr_rx(5)
Print #1 , "Magicobject "
Case Smartgauge: '35
Smartgauge_idx = 4d_arr_rx(3)
Smartgauge_val(1) = 4d_arr_rx(4)
Smartgauge_val(2) = 4d_arr_rx(5)
Print #1 , "Smartgauge "
Case Smartslider: '36
Smartslider_idx = 4d_arr_rx(3)
Smartslider_val(1) = 4d_arr_rx(4)
Smartslider_val(2) = 4d_arr_rx(5)
Print #1 , "Smartslider "
Case Smartknob: '37
Smartknob_idx = 4d_arr_rx(3)
Smartknob_val(1) = 4d_arr_rx(4)
Smartknob_val(2) = 4d_arr_rx(5)
Print #1 , "Smartknob "
Case Else:
Print #1 , "Event report wrong ID: " ; 4d_arr_rx(3)
'Clear Serialin4
Print #1 , "S_pace" ; S_pace
Print #1 , "frame error"
Case A_ck: '&H06 ACK
Print #1 , "ACK"
Ack_flag.0 = 0 'reset ack flag not really in use yet
Case Report_event: '&H07
Case Dipswitch: '0
Case Knob: '1
Print #1 , "Knob "
Case Slider: '4
Case Trackbar: '5
Case Winbutton: '6
Case Coolgauge: '8
Case Form: '10
Print #1 , "Form "
Case Gauge: '11
Print #1 , "Gauge "
Case Image: '12
Print #1 , "Image "
Case Keyboard: '13
Case Led: '14
Print #1 , "Led "
Case Leddigits: '15
Case Meter: '16
Print #1 , "Meter "
Case Strings: '17
Case Userled: '19
Case Video: '20
Debug "Video "
Case S_ound: '22
Case T_imer: '23
Case Spectrum: '24
Case Scope: '25
Print #1 , "Scope "
Case Tank: '26
Print #1 , "Tank "
Case Pinoutput: '28
Case Pininput: '29
Case 4dbutton: '30
Case Anibutton: '31
Case Smartknob: '37
Case Else:
Clear Serialin4
Case Nak:
Print #1 , "NACK" '&h15 NAK
Case Else:
Print #1 , "Error in Code =: " ; 4d_arr_rx(1)
Clear Serialin4
Print #1 , "S_pace= " ; S_pace
End |
bellon
Posted: Sat Mar 02, 2019 4:56 pm Post subject: Recept nul char / Bascom |
Hello Pikczu
yes it is for a screen visi genie. I just discovered it and I'd like to test it to display on a manometer
the distance measured with an ultrasonic sensor. While simulating manometer with Genie Test Executor I found that my serial reception routine was unable to read null characters (00). This was the subject of my basic question. I think I found the answer in your source code (you use com4 for the lcd I think) me I use an Atmega 2560, the libraries are they necessary?
In any case, I thank you for sharing your knowledge and I will take inspiration from your example.
Cordial greetings. Bernard |
Pikczu
Posted: Sat Mar 02, 2019 5:17 pm Post subject: |
Yes I have used com 4 on xmega 128A3u and com 1 used for the debug.
As you can see code is not fully finished.
I still have to add:
Write_ STRU
Write_magic_byte
Write_magic_Dbytes
Report_magic_events_Bytes
Report_magic_events_Dbytes
I will create user friendly library and a I will post it on the 4D forum and here in MCS forum.
String has limit of 32 characters this is only because i did not found neat way of sending array with variable length.
So currently there is 36 cases of select case "Tot_command_len" for each number of characters.
Any way feel free to use it, also I'm open for any suggestions.
Pikczu
bellon
Posted: Mon Mar 04, 2019 3:34 pm Post subject: Recept nul char / Bascom |
Hello Pikczu
I more or less understood the operation of your program that I adapted for a mega 2560 processor. I can not test it for the moment because I have not received the TFT lcd yet. as I explained before, my project and display on the lcd (in an object (Coolgauge0)
the distance measured with an ultrasonic sensor. the result of this measurement is in a (word). my question is, what is the function in your program that allows to send the data to Ldc for example:
01 (object_id) (object_index) (my word) checksum?
I specify that the distance measurement routine is integrated into the program (it does not come from rs232)
If I'm abusing your time, you have to tell me!)
Sincerely Bernard |
Pikczu
Posted: Mon Mar 04, 2019 7:59 pm Post subject: |
Hi Bernard,
It is pretty simple, if you want to update some objects on the screen you need to use:
Call 4d_write_obj(object ID, object index , value )
I have created constants for object ID for easy use (table attached for clarity)
For example you would like to change value of Coolgauge index 0 to lets say value = 50
XOR crc are calculated in the sub.
Command will look like that:
Call 4d_write_obj(Coolgauge , &H00 , &h32)
Then this sub is called:
Code: | Sub 4d_write_obj(byval 4d_object_id As Byte , Byval 4d_object_index As Byte , Byval 4d_obj_value As Word )
Swap 4d_obj_value 'litle endian to big endian
'4d_arr_tx(4) for clarity this is overlay, the values are all ready there in global array
'4d_arr_tx(5) for clarity this is overlay, the values are all ready there in global array
End Sub |
PS. don't forget to change constant for your uart:
Const Lcd_4d = 4 '4d system uart |
bellon
Posted: Mon Mar 04, 2019 8:43 pm Post subject: Recept nul char / Bascom |
Hello Pikczu
Thank you for the info, between the moment I paused the question and the moment when you answer me, I found the solution. But I tested the function with the parameters: Call 4d_write_obj (Coolgauge, & H00, & h32) and GTX shows this!
Apparently he does not understand the command because I do not get an ACK!
See print sreen
Sincerely Bernard |
bellon
Posted: Mon Mar 04, 2019 8:45 pm Post subject: Recept nul char / Bascom |
GTX Attachement |
Pikczu
Posted: Mon Mar 04, 2019 9:34 pm Post subject: |
Yes that is fine be cause you sending data to Software not to the display.
You need the display for that. |
bellon
Posted: Mon Mar 04, 2019 9:57 pm Post subject: Recept nul char / Bascom |
Ok I thought that GTX emulated the display completely!
So I'm waiting for the display.
in any case I thank you and give you news
Bernard |
bellon
Posted: Wed Mar 06, 2019 7:31 pm Post subject: Recept nul char / Bascom |
hi pikczu
i got the lcd is the update function of the coolgauge with ultrasonic distance sensor works with your program !!
I would like to write text on the lcd is why I wrote:
4d_string_tx = "Little demonstration" (assign the string) and call the function:
Call 4d_write_str (4d_str_indx, 4d_string_tx, ..? ..)
what is the 3rd parameter?
Thanks for your info
Bernard |
Pikczu
Posted: Wed Mar 06, 2019 11:12 pm Post subject: |
Hi Bernard,
You can create string in the workshop4 and then just call them by write_obj command.
Or you can send new string in to it.
I don't have string sub routine ready yet. The 3td parameter should be 0 no characters added or 1 for CR or 2 LF.
I spend some time on it during Sunday evening, but then I have realized it is wrong way.
simply chr(13) should do the same job.
and all of them select cases for LF and CR are not needed.
Any way I will fix it soon.
Use this one for the moment but put zero (0) as the 3rd parameter.
Code: | Sub 4d_write_str(byval 4d_str_indx As Byte , Byval 4d_string_tmp As String , Byval Cr_lf As Byte )
'code + string_index+ string_length + string + xorcrc
Local Index_help_a As Byte 'used to calculate the length of the string
Local Index_help_b As Byte 'used to calculate position of the XOR CRC in array, string length+3
Local Str_tmp_len As Byte 'used for calculating the length before adding CR or LF
Dim Tot_command_len As Byte 'total command length
Str_tmp_len = Len(4d_string_tmp) + 1 'get the length of the original string
'if we adding CR or LF then we need to find the length.
Select Case Cr_lf
Case 0: 'no CR or LF added
Tot_command_len = Len(4d_string_tmp) + 4 'string length(+) command (+) string index (+) string
Case 1:
Insertchar 4d_string_tmp , Str_tmp_len , &H0D 'insert CR at the end, now we have to recalculate length again
Case 2:
Insertchar 4d_string_tmp , Str_tmp_len , &H0A 'insert LF at the end, now we have to recalculate length again
4d_string_tx = 4d_string_tmp 'copy the string in to variable overlaid at array
4d_string_tx_arr(3) = Len(4d_string_tmp) 'length of the string
For Index_help_a = 1 To Tot_command_len -1 'we need to xor this and assign at the end
Next Index_help_a
Select Case Tot_command_len ' total command length
Case 5:
Printbin #1 , 4d_string_tx_arr(1) ; 5 'code +string index+ string length + 1 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 5 'code +string index+ string length + 1 char + crc
Case 6:
Printbin #1 , 4d_string_tx_arr(1) ; 6 'code +string index+ string length + 2 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 6 'code +string index+ string length + 2 char + crc
Case 7:
Printbin #1 , 4d_string_tx_arr(1) ; 7 'code +string index+ string length + 3 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 7 'code +string index+ string length + 3 char + crc
Case 8:
Printbin #1 , 4d_string_tx_arr(1) ; 8 'code +string index+ string length + 4 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 8 'code +string index+ string length + 4 char + crc
Case 9:
Printbin #1 , 4d_string_tx_arr(1) ; 9 'code +string index+ string length + 5 char + crc
Printbin #4 , 4d_string_tx_arr(1) , 9 'code +string index+ string length + 5 char + crc
Case 10:
Printbin #1 , 4d_string_tx_arr(1) ; 10 'code +string index+ string length + 6 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 10 'code +string index+ string length + 6 char + crc
Case 11:
Printbin #1 , 4d_string_tx_arr(1) ; 11 'code +string index+ string length + 7 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 11 'code +string index+ string length + 7 char + crc
Case 12:
Printbin #1 , 4d_string_tx_arr(1) ; 12 'code +string index+ string length + 8 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 12 'code +string index+ string length + 8 char + crc
Case 13:
Printbin #1 , 4d_string_tx_arr(1) ; 13 'code +string index+ string length + 9 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 13 'code +string index+ string length + 9 char + crc
Case 14:
Printbin #1 , 4d_string_tx_arr(1) ; 14 'code +string index+ string length + 10 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 14 'code +string index+ string length + 10 char + crc
Case 15:
Printbin #1 , 4d_string_tx_arr(1) ; 15 'code +string index+ string length + 11 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 15 'code +string index+ string length + 11 char + crc
Case 16:
Printbin #1 , 4d_string_tx_arr(1) ; 16 'code +string index+ string length + 12 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 16 'code +string index+ string length + 12 char + crc
Case 17:
Printbin #1 , 4d_string_tx_arr(1) ; 17 'code +string index+ string length + 13 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 17 'code +string index+ string length + 13 char + crc
Case 18:
Printbin #1 , 4d_string_tx_arr(1) ; 18 'code +string index+ string length + 14 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 18 'code +string index+ string length + 14 char + crc
Case 19:
Printbin #1 , 4d_string_tx_arr(1) ; 19 'code +string index+ string length + 15 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 19 'code +string index+ string length + 15 char + crc
Case 20:
Printbin #1 , 4d_string_tx_arr(1) ; 20 'code +string index+ string length + 16 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 20 'code +string index+ string length + 16 char + crc
Case 21:
Printbin #1 , 4d_string_tx_arr(1) ; 21 'code +string index+ string length + 17 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 21 'code +string index+ string length + 17 char + crc
Case 22:
Printbin #1 , 4d_string_tx_arr(1) ; 22 'code +string index+ string length + 18 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 22 'code +string index+ string length + 18 char + crc
Case 23:
Printbin #1 , 4d_string_tx_arr(1) ; 23 'code +string index+ string length + 19 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 23 'code +string index+ string length + 19 char + crc
Case 24:
Printbin #1 , 4d_string_tx_arr(1) ; 24 'code +string index+ string length + 20 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 24 'code +string index+ string length + 20 char + crc
Case 25:
Printbin #1 , 4d_string_tx_arr(1) ; 25 'code +string index+ string length + 21 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 25 'code +string index+ string length + 21 char + crc
Case 26:
Printbin #1 , 4d_string_tx_arr(1) ; 26 'code +string index+ string length + 22 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 26 'code +string index+ string length + 22 char + crc
Case 27:
Printbin #1 , 4d_string_tx_arr(1) ; 27 'code +string index+ string length + 23 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 27 'code +string index+ string length + 23 char + crc
Case 28:
Printbin #1 , 4d_string_tx_arr(1) ; 28 'code +string index+ string length + 24 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 28 'code +string index+ string length + 24 char + crc
Case 29:
Printbin #1 , 4d_string_tx_arr(1) ; 29 'code +string index+ string length + 25 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 29 'code +string index+ string length + 25 char + crc
Case 30:
Printbin #1 , 4d_string_tx_arr(1) ; 30 'code +string index+ string length + 26 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 30 'code +string index+ string length + 26 char + crc
Case 31:
Printbin #1 , 4d_string_tx_arr(1) ; 31 'code +string index+ string length + 27 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 31 'code +string index+ string length + 27 char + crc
Case 32:
Printbin #1 , 4d_string_tx_arr(1) ; 32 'code +string index+ string length + 28 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 32 'code +string index+ string length + 28 char + crc
Case 33:
Printbin #1 , 4d_string_tx_arr(1) ; 33 'code +string index+ string length + 29 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 33 'code +string index+ string length + 29 char + crc
Case 34:
Printbin #1 , 4d_string_tx_arr(1) ; 34 'code +string index+ string length + 30 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 34 'code +string index+ string length + 30 char + crc
Case 35:
Printbin #1 , 4d_string_tx_arr(1) ; 35 'code +string index+ string length + 31 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 35 'code +string index+ string length + 31 char + crc
Case 36:
Printbin #1 , 4d_string_tx_arr(1) ; 36 'code +string index+ string length + 32 char + crc
Printbin #4 , 4d_string_tx_arr(1) ; 36 'code +string index+ string length + 32 char + crc
PS. is there any chance you change or add 4d systems in to the topic name?
This will help search for 4D system related topic in the feature. |
