P_Santos
Posted: Wed Mar 27, 2019 8:47 pm Post subject: Atmega644A not function with 3,3V |
Hello,
I need use a Atmega644A supplied with 3,3V but it not works, with 5V it's works good
On Datasheet is that it function between 2,7V....5V 10Mhz, i use a 7,3728Mhz crystal
Operating Voltages
̶ 1.8 - 5.5V
Speed Grades
̶ 0 - 4MHz @ 1.8 - 5.5V
̶ 0 - 10MHz @ 2.7 - 5.5V
̶ 0 - 20MHz @ 4.5 - 5.5V
Anyone know how to fix it?
The programmer i use is the AVR DIAMEX
Thanks in advance
Regards
P_Santos
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.1 ) |
Posted: Wed Mar 27, 2019 9:31 pm Post subject: |
It should work but maybe someone enable BOD FuseBit with configuration for 4.3V
In this uC BOD can be configured for reseting micro at 4.3V, 2.7V or 1.8V |
P_Santos
Posted: Wed Mar 27, 2019 11:47 pm Post subject: |
Hi EDC,
I have change the Fuses to
FE
DF
FF
and programming and it works, but programming with 5V on the programmer, after that i change to 3,3V on the programmer and try again programming the 644
and now i canīt programming the Atmega644A anymore, not with 3,3V or 5V, on the last period of programming it show the flash error
Don't know what to do
Regards
P_Santos
Posted: Thu Mar 28, 2019 1:20 am Post subject: |
Fuses LOW FE, HI DF means External Cristal >8MHz. Is that your circuit?
For <8MHz I think better Fuses will be FD D9
What frequency of the programmer you set on the "Interface settings" tab? It should be no higher than 1/4 of uC clock.
Check power supply, cristal and his capacitors or even some another programmer. If nothing help then only HighVoltageProgrammer can restore oryginal Fuses and bring to life uC again |
P_Santos
Posted: Thu Mar 28, 2019 12:08 pm Post subject: |
Hi EDC,
The Fuse programming i can change all and programm, the problem is the after programming process, the verifying of the flash show error and i'm
think the Atmega644 is not bad
The interface, i allready change for higher than 125khz and allways lower, not help
I continue search for solution, and give feedback if is sucessfull
The Diamex programmer is ok, i can programm other chips, included the Atmega644
The board is allways ok than i have programm it, the problem begin as i change the jumpers on the programmer to 3,3V and progammed the chip, now exists this problem, both voltage same error effect
Thank you to try help
Best regards
P_Santos |
enniom
Posted: Sat Mar 30, 2019 11:15 pm Post subject: |
Just in case, make sure LOCK bits are Off
e |
