KS108 128x64 do not Initialize
MichaelB.
PostPosted: Wed Mar 13, 2019 4:20 pm    Post subject: KS108 128x64 do not Initialize Reply with quote
I have the Following problem.
$regfile = "m128def.DAT"'128L 8Mhz version
$crystal = 7372800
$baud = 19200
$eepleave
$loadersize = 512
$hwstack = 100
$swstack = 75
$framesize = 40
$lib "glcdKS108.lib"                                        'Include the library for the KS-108 controler
Config Porte.4 = Output
Config Graphlcd = 128 * 64sed , Dataport = Porta , Controlport = Portc , Ce = 0 , Ce2 = 1 , Cd = 2 , Rd = 3 , Reset = 5 , Enable = 4
'The dataport is the portname that is connected to the data lines of the LCD
'The controlport is the portname which pins are used to control the lcd
'CE =CS1  Chip select
'CE2=CS2  Chip select second chip
'CD=Data/instruction
'RD=Read
'RESET = reset
'ENABLE= Chip Enable
Config Adc = Single , Prescaler = Auto , Reference = Internal       'Setting up the a/d convertor
Config Timer1 = Timer , Prescal
......ect....
this is a code sample from the mcs Website to drive a 128x64 KS108 Display with Touchsreen.
Nothing happend. I Soldered a LED for Indication if the MCU is Running or if a Timing issue is there.
But the MCU isnt starting. The LED is still off.
So i make a new Code:
$regfile = "m128def.DAT" '128L 8Mhz version
$crystal = 7372800
$baud = 19200
$eepleave
$loadersize = 512
$hwstack = 100
$swstack = 75
$framesize = 40
'RD=Read
'RESET = reset
  Wait 1
  Porte.4 = 1
  Wait 1
  Porte.4 = 0
It still isnt running, till i Comment out the
'Config Graphlcd = 128 * 64sed , Dataport = Porta , Controlport = Portc , Ce = 0 , Ce2 = 1 , Cd = 2 , Rd = 3 , Reset = 5 , Enable = 4
Now the LED is Blinking without Config Graphlcd.
What is wrong with the Config??
I allready set Fuses:
-ext. Crystal to use a 7,372800 Mhz
-Jtag off
-M103 off
Does anyone have a Clue?
(BASCOM-AVR version : 2.0.8.1 )
PostPosted: Wed Mar 13, 2019 6:26 pm    Post subject: Reply with quote
Check wirings once again.
Routines for lcd uses some Status_checking. Status is indicated on the DB7 bit of Dataport.
Routine can wait till this bit is low so..maybe some short to VCC or bad connection.
MichaelB.
PostPosted: Wed Mar 13, 2019 6:54 pm    Post subject: Reply with quote
there is no short. When the MCU is Running the DB7 Pin is High Level.
Evert :-)
PostPosted: Wed Mar 13, 2019 7:54 pm    Post subject: Reply with quote
If you use port A as data port you need to connect AVCC(pin 64) to vcc.
Recheck you wiring again and again.
Share a link to the datasheet of your display.
MichaelB.
PostPosted: Wed Mar 13, 2019 8:40 pm    Post subject: Reply with quote
MichaelB.
PostPosted: Wed Mar 13, 2019 8:56 pm    Post subject: Reply with quote
If i Set the Overall Voltage from my Bench Powersupply to 2,56V, the white Stripe is moving from the Left side to the Right side, and repeat it. The only thing i have ever seen moving on this screen ^^
Plons
PostPosted: Wed Mar 13, 2019 10:06 pm    Post subject: Reply with quote
Michael, you haven't connected pin5, Vo. The voltage on that pin defines the LCD operating voltage. See page 10 of your datasheet.
Nard
Bascom AVR ver 2.0.8.6
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel"
MichaelB.
PostPosted: Wed Mar 13, 2019 10:28 pm    Post subject: Reply with quote
Nard
Yes you are right, all the suspect unconnected Pins like VCC , K, A, V0 , Vee ect. are Fixed externally.
I bet it is the wrong Lib for that Display controller. The Datasheet of the LCD shows something like an NT7108, but i can not find it in my Bascom Lib Folder. Confused
I have to see it, before i desolder all to replace a new Mega128L8 Shocked
kimmi
Moderator
PostPosted: Wed Mar 13, 2019 11:12 pm    Post subject: Reply with quote
Check that ALL VCC & GND are connected
see images
/ Kim
View user's profile Visit poster's website MSN Messenger
JC
PostPosted: Sun Mar 17, 2019 7:23 pm    Post subject: Reply with quote
Agree, ALL Vcc, AVcc, and Ground pins need to be connected.
Additionally, the display might require some time for its own boot-up, before the micro sends it initialization code.
It would be appropriate to put:
Waitms 500
or even
Waitms 1000
at the start of the program, before you send the initialization sequence to the display.
Alternatively, you can configure the micro's I/O pins, and then insert the wait before sending the initialization code.
Hi Nard, Haven't seen you around in a while.
Hope all is going well for you.
JC
MichaelB.
PostPosted: Thu Mar 21, 2019 12:22 pm    Post subject: Reply with quote
Waitms 500
or even
Waitms 1000
Thx for the info:
Now just the White Stripe is gone. Stll have a Bluescreen.
I found out that is the wrong Libary for this LCD. I need a Libary for a NT7108C Chipset. But i cant find anywhere a Bascom Libary for that Chipset.
kimmi
Moderator
PostPosted: Sat Mar 23, 2019 10:51 pm    Post subject: Reply with quote
NT7108C are similar with Samsung KS0108B
search forum for KS0108 lots of sample code that worked
$include "Font8x8.font"
$lib "glcdKS108.lbx"
'for Glcd Ks108
'First we define that we use a graphic LCD
Config Graphlcd = 128 * 64sed , Dataport = Porta , Controlport = Portc , Ce = 0 , Ce2 = 1 , Cd = 2 , Rd = 3 , Reset = 5 , Enable = 4 , Mode = 6
'CE     = CS1  Chip select
'CE2    = CS2  Chip select second chip
'CD     = DI Data/instruction
'RD     = R/W Read/Write
'RESET  = RST reset
'ENABLE = E Chip Enable
'And Potmeter for contrast to  +5V, V0, VEE  (V0 is center pin on pot)
Setfont Font8x8
Dim Char As Byte , L As Byte , C As Byte
'Show lcd ascii on lcd
Cls
Char = 31
For L = 1 To 8
For C = 0 To 127 Step 8
Char = Char + 1
Lcdat L , C , Chr(char)
Next C
Next L
Wait 2
Cls
Char = 128
For L = 1 To 8
Char = Char + 1
Next C
Next L
Wait 2
/ Kim
MichaelB.
PostPosted: Sun Apr 07, 2019 2:08 pm    Post subject: Reply with quote
Found the Problem, it was a Damaged Display. Sad( Rolling Eyes
