hzz
Posted: Sat Mar 09, 2019 12:46 pm Post subject: Understanding (or not) Timer freq mode |
In the following code timers E1 and E0 are configured equally; however the outputs at pin PE4 (Timer E1 compare A output) and pin PE0 (Timer E0 compare A output) are very different. Why? (BASCOM 2.0.8.1 - Board Crumb xmega128A3)
Code: | '________________________________________________________________________________
' Test frequency generation to drive a Buzzer
$regfile = "xm128A3Udef.dat"
$hwstack = 256
$swstack = 128
$framesize = 128
' CONFIG SYSTEM CLOCK
Config Osc = Disabled , Extosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_16kclk , 32khzosc = Enabled , Pllosc = Enabled , Pllsource = Extclock , Pllmul = 2 ' 16x2=32MHz
Config Sysclock = Pll , Prescalea = 1 , Prescalebc = 1_1 ' 32/1=32 MHz
$crystal = 32000000
Config Tce1 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 16
Tce1_cca = 277
Config Tce0 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 16
Tce0_cca = 277
End 'end program |
(BASCOM-AVR version : 2.0.8.1 ) |
hzz
Posted: Sat Mar 09, 2019 6:04 pm Post subject: |
But this does work as expected:
$hwstack = 256
$swstack = 128
$framesize = 128
$crystal = 32000000
Config Tce1 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 8
Tce1_cca = 88
Config Tce0 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 8
Tce0_cca = 88
End 'end program |
It seems that Resolution cannot be put =16 in frequency generation mode |
Posted: Sun Mar 10, 2019 5:12 pm Post subject: |
I'd say what you're doing raises questions, the help tells:
Quote: | RESOLUTION
Valid options : NORMAL, BYTE, SPLIT. |
Nonetheless you put 8 or 16 as option and you wonder about odd behavior?
Beside I was able to find out that by using proper arguments like RESOLUTION = BYTE/NORMAL the code works as desired.
I spared myself the effort to find out what chaotic/nonlinear/miracle side-effects the improper user configuration did create, as it is much less effort if the user simply follows parameter syntax.
In your case also a look into the data sheet would have been advisable, there you would have found:
Quote: | 14.12.5 CTRLE – Control register E
---Bit 1:0 – BYTEM[1:0]: Byte Mode
------These bits select the timer/counter operation mode according to Table 14-7 on page 166 .
---------BYTEM[1:0] Group Configuration Description
------------00 NORMAL Timer/counter is set to normal mode (timer/counter type 0)
------------01 BYTEMODE Upper byte of the counter (CNTH) will be set to zero after each counter clock cycle
------------10 SPLITMODE Timer/counter 0 is split into two 8-bit timer/counters (timer/counter type 2) |
If you compare the keywords with those from the help, it should have rang a bell not to use nonsense values like 8 or 16. |
hzz
Posted: Mon Mar 25, 2019 11:00 pm Post subject: |
Yes, stupid error :oops: |
