Rainbow led and code placed above 64Kb
hoogscherm
PostPosted: Mon Feb 25, 2019 8:39 pm    Post subject: Rainbow led and code placed above 64Kb Reply with quote
Is there a way to use the ws2812 rainbow leds when the code is placed in memory above 64Kb?
I want to use a rainbow-led into a bootloader-utility for the atmega1284, meaning my code needs to be placed in memory adr starting at $F000
$regfile = "m1284pdef.dat"
$crystal = 8000000
$hwstack = 60
$swstack = 128
$framesize = 128
$baud = 57600
$loader = $F000                         ' As soon as this value > $8000, the led isn't working
' using either the old or new lib makes no difference
' $lib "RainbowBSCN.lib"
'$lib "RainbowBSC.lib"
Config Rainbow = 1 , Rb0_len = 1 , Rb0_port = Portb , Rb0_pin = 0
'                                                   ^ connected to pin
'                                       ^------------ connected to port
'                         ^-------------------------- 1 leds on stripe
'              ^------------------------------------- 1 channel
Rb_selectchannel 0                      ' select first channel
Dim Rgb_blue As Dword : Rgb_blue = &HFF0000
Dim Rgb_red As Dword : Rgb_red = &H0000FF
    Print "red"
    Rb_setcolor 0 , Rgb_red : Rb_send
    Wait 1
    Print "blue"
    Rb_setcolor 0 , Rgb_blue : Rb_send
    Wait 1
Using the code on ATmega644 and $loader=$7000 works without a problem.
For the ATmega1284P my bootloader starts on $F000.
If I use $loader=$XXXX and XXXX if less then 8000, the code works.
Thanks,
LucVdV
(BASCOM-AVR version : 2.0.8.1 )
