AVR DOS KILL
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS
njepsen
PostPosted: Fri Feb 22, 2019 3:40 am    Post subject: AVR DOS KILL Reply with quote
I am having trouble with the KILL command. I am logging data to an SD card., and from time to time ( and I dont know how) I end up with a file that is zero bytes long.
eg xxxxxxxx.TXT I detect these files and try to kill them thus:
( as the code is very long, only the relevant bits are shown)
   $regfile = "m1284pdef.dat"                                  'my processor
   $crystal = 9830400                                          'system crystal
   $framesize = 800                                            ' Located at top of 16k of SRAM
   $hwstack = 550                                              '
   $swstack = 550                                              '
   $frameprotect = 1
   stop watchdog
      If Msg_id = 0 Then
         Print #1 , ">> deleting " ; Myfilename
         Chdir "\"
         Chdir Cachefoldernamestr
         Kill Myfilename                                    'delete from sd card
The code works fine, and has been for several years, except when a zero file arrives, then the code hangs, immediately at "kill myfilename"
I have got round the issue but my question is - does kill not work with a zero length file?
Neil
PostPosted: Fri Feb 22, 2019 9:43 pm    Post subject: Reply with quote
you should log the Gbdoserror value.
It should be 0.
Do you know about the SIMULATE AVR DOS.bas sample in the avr-dos folder?
It is a great way to test things without hardware.
I tried this :
Print "Kill test"
Open "testx.bin" For Binary As #11
Flush #11
Close #11
Kill "testx.bin"
and i got gbDOSerror 0
So it seems to work ok.
you best log this error in your code when it is non zero in order to have a clue.
you should also make some tests like the one i did to see if it is reproducible with a small program.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS All times are GMT + 1 Hour
