Joined: 25 Jan 2010 Posts: 92 Location: Kragerø,Norway
Posted: Wed Jan 23, 2019 5:22 pm Post subject: FPM10A/DY50 fingerprint reader module
I came across this module on the bay for approx. $8, found some Arduino code for it, and decided to give it a try.
The code is quit premature, but will do the job for enrolling new fingerprints and testing them later. I wasn’t able to printbin #1 larger chunks of the packet than 1 byte at a time or byte array.
Setting the password for the module seems to work, but revert back to default after a power cycle (same behavior seen with Arduino sw)
I’ve used a modified Nano (3.3V/mcs bootloader) to test with.
thanks for sharing your project. i am also interested in these readers.
printbin can send more data but it accepts a constant for the number of bytes to send.
your code is well written. thanks again for posting ! _________________ Mark
