Output led fade on_led fade off and input swith.
Printpix52
PostPosted: Tue Dec 11, 2018 5:23 am    Post subject: Output led fade on_led fade off and input swith. Reply with quote
Hello everyone, I tried the program to fade a led on and off when you press a button and nothing does the led when you press the button and check the connections.
Could you correct the program?
$regfile = "m48def.dat"
$hwstack = 40
$swstack = 16
$framesize=32
Config Timer1 = Pwm , Pwm = 8 , Prescale = 1 , Compare A Pwm = Clear Up
Config Pinc.5 = Input : Sw0 Alias Pinc.5 : Portc.5 = 1
Config Portb.1 = Output                                     'OC1A pin  (Portb.1 for Atmega8) prtd.5 for atmega 16
'''''''''''''''''''''''''''' MAIN ''''''''''''''''''''''''''''''''''''
 Defbyte B
    If Sw0 = 0 Then
     Gosub Fade_on
     Gosub Fade_off
'''''''''''''''''''''''''''' END MAIN ''''''''''''''''''''''''''
 Fade_on:
    For B = 255 To 1 Step -1
     Pwm1a = B
     Waitus 1500
    Stop
 Fade_off:
    For B = 1 To 255
     Pwm1a = B
     Waitus 1500
    Stop
Sad
PostPosted: Tue Dec 11, 2018 9:04 am    Post subject: Reply with quote
This works. Tested. If not then check LED polarity.
$regfile = "m328pdef.dat"
$hwstack = 64
$swstack = 16
$framesize = 64
Led Alias Portb.1 : Config Led = Output
Sw0 Alias Pinc.5 : Config Sw0 = Input : Set Portc.5
Dim Helpb As Byte
For Helpb = 0 To 30                                         'hardware test
  Toggle Led                                                'LED should blink
  Waitms 50
Helpb = 0
Config Timer1 = Pwm , Pwm = 8 , Prescale = 64 , Compare_a_pwm = Clear_up
 If Sw0 = 0 Then
  If Helpb < 255 Then
   Incr Helpb
   Pwm1a = Helpb
  If Helpb > 0 Then
   Decr Helpb
   Pwm1a = Helpb
 Waitms 10
Printpix52
PostPosted: Tue Dec 11, 2018 4:09 pm    Post subject: Reply with quote
Resolved, thanks for helping EDC.
Very Happy Very Happy Very Happy
PostPosted: Mon Dec 17, 2018 5:00 pm    Post subject: Reply with quote
For those who will be reading this in the future ahahaha:
I think that problem in Printpix code is that Subs "Fade_on" and "Fade_off" dont have "Return" command...
Code will be executed like this : ->jump to the Fade_off or Fade_on label -> do the code -> not return, execute next command which will be 00...00...00 etc till reach end of Flash and program will start again at $00
Stop is the command for another purpose.
